MicroSD Card Not Showing Up at all
When i insert a MicroSD Card direct into Laptop on latest QubesOS it is Not Showing Up at all on this new laptop despite me re-booting, removing and re-inserting the card lots of times and its a new QubesOS install yet a External SSD does show up all ok.
On my old laptop on the older version of QubesOS the microSD card showed up everytime on the top USB icon drop down menu using the UI i think it started the name like mc something yet not on the new laptop.
If i had to guess as a newbie i would quess that DOM0 has it and that i need to re-direct it to show up in the menu so that i can then attach it to any qube of my liking yet IDK for sure.
I did update everything and tried a couple of CLI commands to see if i could find it such as fdisk -l but i just couldnt figure it all out nor even find any drive starting mc nor that is the same size as the microsdcard either.
Any help would be much appreciated please :heart:
I have this problem too with my Nitrokey laptop.
Check thunar in dom0 to see if it appears. The sd card reader is likely a PCI device; you may need to attach that PCI device to sys-usb.
Do not use thunar in dom0:
Thats all good as i not know how to run anything in Dom0 let alone anything thunar…lol
Would you so happen to know how we sort out the microSD Card issue please as i just cant work it out? :flushed:
You’re probably running into this issue:
that is probably so from what i read thanks, but i have no idea how to resolve the issue still?
I have a good look around the UI Global Config and just cant grasp what needs to be done :worried:
I do see a warning in there telling me Qubes U2F Proxy Service may need installing or something yet idk if this will fix the issue or not?
I have noticed in Global Config - USB Devices - USB qube option has nothing in there and doesnt allow me to click it to input anything or view any drop down list and this may well be the issue?
What about buying a sd card usb reader ? Workarounds seem to be the default in my qubes experience :slight_smile:
I only wanted to use the microsd card slot as then nothing sticks out from laptop, using a usb seems to contradict this feature for me :unamused:
Just to add to the complexity of this i tried to go to the sys-usb SETTINGS - DEVICES then i took one of the pci controllers from the list in the left and sent it over to the right column and ever since i lost all control function to the keyboard, ext mouse, trackpad, everything and i dont know how to fix that now? :cold_sweat:
did anyone figure out how to fix this issue as i seem to keep going around in a circle on this one? :cold_sweat:
The current workround is to use the sdcard reader attached to dom0 -
this carries risks, of course, but if you must use it that seems to
be the best current solution in 4.3
Attaching the reader to sys-usb is reported non-functional.
Another solution is to buy a USB adapter for microSD cards.
i don’t think we need a work around nor a alternative cumbersome solution, one just needs to know how to attach what to where in sys-USB surly?
Wait for the update(s) …
does that mean it has been or is being updated do you know and if so then is it a qubes update or do i need to do something specific to sort it pls?
It’s in the making. Please read the comments in the above posted github issue to be up to date.
