Hi everyone!
When I open pavucontrol in dom0, I can see that my USB microphone is working (the bar moves when the microphone picks up sound), and I have verified that this microphone is set as the correct recording device for the virtual machine that I need it in (“Recording” tab in pavucontrol).
In the VM itself, I have run pavucontrol and verified that “Qubes Virtual Audio Source” is not muted.
Yet, not audio appears to be arriving in the VM.
It’s an up-to-date Qubes 4.2 system, the VM is an up-to-date fedora-39. The microphone that I use is connected via USB, and I do not use a sys-usb, if that makes a difference. I’m not aware of a sys-audio existing on my system.
This used to just work a few years ago when I last needed it. I’m looking for any tips or hints on what I can do or try, or possibly what has changed in audio in Qubes OS in the last two or three years.
I’ve been using Linux for a long time, but know basically nothing about the systems that make audio work under Linux, as I really don’t like having to spend time with them. So any form of help is greatly appreciated.
