Messing around with Salt Pillars
Hello !
I’m trying to use Salt to configure my system, and I’m trying to use Pillar to have some modularity by allowing to create several qubes based on one Salt formula.
Unfortunately, I can’t manage to create any datastructure in my pillar, for now I only succeeded making tuple:
top-level:
  item: value
  item: value
When I try to add some real dictionary looking something like this:
top-level:
  item:
    key: value
    key: value
  item:
    key: value
    key: value
qubesctl throw me an error Rendering SLS failed : mapping values are not allowed in this context
Is there something specific of QubesOS enforcing this ? Or am I missing something?
Thank you for your help :slight_smile:
There must be an error in the resulting YAML… Are you using any character that could be interpreted by YAML as something else? Can you try to double-quote the values?
I checked against a yaml linter, says it’s okay…
I tried double-quoting the values.
Tabs throw a longer error than double space.
I also tried putting dash in front of the item or key…
Your items have the same name? or you call them item_1 and item_2 ?
They have different name, and I tried with same or different keys too.
I have sometimes this error message, if I mix the code with jinja. If I add a minus sign in the jinja, sometimes it is gone. Like this:
{%- endif -%}
whitespace problems
the pillar should work, mine is also like yours.
welp, it didn’t do the trick either…
I thinking about opening a bug report…
Do you use user_salt and user_pillar or where is your pillar located? Do you have a real code example what I can copy paste and try?
{% for region_name, region_data in pillar.get('regions', {}).items() %}
echo_{{ region_name }}:
  cmd.run:
    - name: echo "{{ region_data }}"
{% endfor %}
regions:
  test1:
    tunnel: template-kicksecure
    admin: template-kicksecure
  test2:
Here what I got…
same error message, I try to debug
I have to go, I’ll try it tomorrow
Here’s how I use dictionaries in pillars - it may help. This is a
fragment of my system pillar.
configs:
  test0:
    template: debian-12-xfce
    label: blue
    memory: 200
    maxmem: 2000
  test1:
    template: fedora-41-kde
    label: gray
    memory: 800
    maxmem: 8000
Then in the state:
{% for qube,args in pillar.get('configs', {}).items() %}
create_{{ qube }}:
  qvm.present:
    - name: {{ qube }}
    - template: {{ args.template }}
    - label: {{ args.label }}
prefs_{{ qube }}:
  qvm.prefs:
    - name: {{ qube }}
    - memory: {{ args.memory }}
    - maxmem: {{ args.maxmem }}
{% endfor %}
@unman got it right, your region_data is a dictonary.
I debug like this:
{% test = pillar.get('regions', {}).items() %}
{%- do salt.log.critical( 'test_data: %s'|format( test )) -%}
{% for region_name, region_data in test %}
{%- do salt.log.critical( 'region_name: %s'|format( region_name )) -%}
{%- do salt.log.critical( 'region_data: %s'|format( region_data )) -%}
{% endfor %}
Okay, you must specify direct data and not a dictionary when using {{ args.label } seems that {{ args }} is not possible.
Thanks for your help !
Yes, {{args}} will be rendered as a python dict otherwise, like this:
{'template': 'debian-12-xfce', 'label': 'blue',...}
That’s not a valid qube name :slight_smile:
