Meaningful contribution to the Qubes OS project (2 minutes or less)
Here is an easy but meaningful way to contribute that will take you less then 2 minutes!
[user@dom0] qubes-hcl-report
[user@dom0] qvm-copy-to-vm web Qubes-HCL-*
Please replace web above with whatever qube you use to participate in the forum. Then please post your HCL report (you’ll find it under ~/QubesIncoming/dom0 in that qube) to this category. If you can’t upload files (yet), then just copy & paste the contents into the post.
If you already submitted a report in the past for R3.2 or earlier, please consider sending a new report for R4.0 or R4.1!
If your machine fulfills these criteria:
  • Qubes OS R4.0.4 installs without any workarounds
  • Graphics, networking & audio work without troubleshooting
  • Recommended 16 GB RAM are possible
… please drop a quick note in this thread or call it out in your post here.
Thank you!
3 posts were split to a new topic: Lenovo ThinkPad L460
There you go. Hope it helps :slight_smile:
Thank you! It’s not necessary to link your HCL from here, since @Sven will get a notification anyway.
Me:
“Huh, is that really a real command?”
Tries it
“Cool, but now I have this file in dom0. Guess I should move it to an AppVM.”
“Now I have this HCL report file, so I suppose I could post it I guess.”
I was tricked into submitting a HCL report! xd
