Making tiny font bigger in navigation bar and menus?
I am a new user and very excited to start using Qubes. The installation went really well except for the tiny font size that appears on the screen (ex. the top bar). I tried changing the font size to no avail. Is there a way to make it a little bigger?
Many thanks! :slight_smile:
A Qubes newbie and enthusiast!
Welcome to Qubes. To narrow this down: where exactly did you change the font size, and which setting did you use? Is the small text limited to the top bar and menus, or does it also affect the contents of application windows?
