I’ve long felt that Qubes OS’s underlying design philosophy is naturally suited for “agent-driven security orchestration.”
Qubes OS achieves its core strength by putting different tasks into different virtual machines, creating isolation boundaries by default. You don’t necessarily need to fully understand what its built-in components (for example, certain agent- or remote-execution-related mechanisms) are doing internally. From a security-architecture perspective, it’s obvious: Qubes OS turns “risk” into controllable units, and it places “automation” into environments that are more appropriate for safe containment. To me, agent control works far better in a sliced, isolated world than in a single monolithic environment.
I previously explored something similar in spirit—Qubes-mcp–like setups—where they provide “safe openings” (authorized interfaces) that allow an agent inside an AppVM to control part of Qubes OS, and in more aggressive scenarios, potentially expand its influence further. That sounds dangerous, and it is—yet it’s also full of imagination. The key idea is: if the authorization granularity is sufficiently fine, the operation paths are auditable, and the isolation boundaries are truly understood, then an agent can turn complex configuration and verification workflows into repeatable, testable system capabilities.
Using this direction, I developed and tested a set of approaches. I specifically tested various “how-to” guides found on forums: not just whether the instructions look correct, but whether they genuinely work in practice. For example, with common VPN setups, I checked whether they actually prevent traffic leaks—i.e., whether the behavior matches the claim under realistic conditions rather than stopping at a “configured” state. For many tutorials, the implementation remains a black box. Trusting a description alone becomes a weakness once you’re dealing with adversarial environments or messy edge cases.
Later, I tightened the critical path by building a Qubes OS–specific gateway using Mihomo, then personalizing my DNS handling to address the DNS part of the problem. The goal wasn’t only to “route through a VPN/proxy,” but to pull the entire exit path—name resolution, forwarding, and isolation execution—into one cohesive strategy and validation framework. In effect, I tried to turn my Qubes OS into something more fortress-like: not only isolating components, but making key behaviors as testable and explainable as possible.
That leads to a practical shift in how I deal with black-box instructions. Previously, unknown implementations meant unknown risk. Now, with agent + Qubes OS working together, those black boxes become progressively observable and transparent. In my setup, I can validate what the guide really accomplishes rather than merely accept what it claims—so the risk moves from “unknown unknowns” to “known boundaries that I control.”
qubes os chinese group Telegram: View @qubeszh
