I want to search for my newly create Qube’s name and get the shortcuts that the Template had, via rofi/dmenu. Or if you use XFCE, the application menus.
Currently I have no desktop shortcuts on newly created Qubes, in contrast to the Template.
The template has the applications I want in the “Applications” tab in qubes-vm-settings.
So on the qubes-vm-settings you see nothing for the AppVM on the Applications tab? What happens when you hit Refresh Applications?
The shortcuts are there, I just have to move them over manually for each VM I create. I used to have all shortcuts which were present in the Template to be inherited by the AppVMs. Don’t recall how.
