Major download issues with Qubes-ISO 4.3.2
'm trying to download the latest version of Qubes OS, version 4.3.2. I’ve already tried downloading it using both a Fedora AppVM and a Windows 11 HVM, but the downloads are slow in a extrem way and reliable abort after a while.
Is there any trick to get the download to work properly?
So far, I’ve avoided downloading the file from a mirror for security reasons.
The file in question is: Qubes-R4.3.2-x86_64.iso
I’d really appreciate any help. Thanks in advance!
Which security concerns?
Downloading from mirrors is safe if you isolate the ‘download VM’ and follow the verification guide. The download button on the Qubes OS site automatically links to a mirror, but you can always use the torrent option if you have a weak connection.
How much space did you allow in the Qubes where you are doing the downloading?
Are you using Tor?
Perhaps try in the middle of your night, when the internet is less busy?
What is the speed of your internet connection. I knew someone who tried to use a cell phone plan to download. I know some WiFi public connections block connection to Linux download, but usually that has an error message. Some public WiFi, have kicked me off if I stayed on – longer than the WiFi connection manager thought proper. (??)
Thanks for the replies. I was able to download the file using a Windows HVM, so I didn’t carry out the other steps (except for verification). Thanks for your help.
I’ve got it via torrent quickly last week. Getting it directly was extremely slow.
