qun
October 4, 2021, 10:25pm
1
Hello,
what is about lynis hardening tool on QubesOS?
The problem I have, is to understand some entries and the things Qubes needs for it’s own working by using the suggestions of lynis.
Such things as “accounts-daemon.service / alsa-state.service” and much more, but also “qubes-firewall.service” and such things that belongs to qubes are marked as unsafe. So some of them I can surely shut down, but other I suppose I should not.
Also by “Kernel hardening / Comparing sysctl key pairs with scan profile” I can see many entries marked as “different”, such as “dev.tty.ldisc_autoload / fs.protected_fifos” and much more.
Did somebody try to harden some VMs with lynis and can help out?
Regards
qun
ppc
October 5, 2021, 2:57am
2
yes, you can do that but be careful
i tried it and i accidentally removed some qubes services so i had to reinstall it (i don’t backup it)
qun
October 5, 2021, 9:02am
3
ok, so I’ll make a backup and try it out.
What is about sysctl.conf? Can there be any problems related to Qubes if I harden the sysctl.conf or is it just the thing of the VM?
ppc
October 5, 2021, 9:28am
4
i’m not sure but qubes use customized kernel so i think you shouldn’t “harden” that
qun
October 5, 2021, 9:40am
5
oh, sorry. I mean just the kernel in the VM. I try just to harden the VMs running in Qubes.
Is there automated hardening for each VM with this “Qubes-VM-hardening”?? But as it seems it’s not for removing some services or harden the VM-kernel, isn’t it?
ppc
October 5, 2021, 10:04am
6
iirc, many vm use same kernel
i don’t know
maybe no, i haven’t tried it
qun
October 5, 2021, 10:10am
7
so, do you mean, that the templateVMs use hardened kernel made by qubes team?
What about standaloneVM which was installed via qubes?
ppc
October 5, 2021, 10:11am
8
i say many vm, not all vm use same kernel
ppc:
many vm
it not hardened kernel
qun
October 5, 2021, 10:15am
9
ok, I suppose that such VMs as fedora and debian use the same kernel and just some very special one, use their own, isn’t it?
qun
October 5, 2021, 1:55pm
11
ModemManager.service: [ MEDIUM ]
- NetworkManager.service: [ EXPOSED ]
- alsa-state.service: [ UNSAFE ]
- auditd.service: [ EXPOSED ]
- dbus-broker.service: [ EXPOSED ]
- emergency.service: [ UNSAFE ]
- flatpak-system-helper.service: [ UNSAFE ]
- haveged.service: [ PROTECTED ]
- polkit.service: [ UNSAFE ]
- qubes-db.service: [ UNSAFE ]
- qubes-firewall.service: [ UNSAFE ]
- qubes-gui-agent.service: [ UNSAFE ]
- qubes-meminfo-writer.service: [ UNSAFE ]
- qubes-qrexec-agent.service: [ UNSAFE ]
- qubes-sync-time.service: [ UNSAFE ]
- qubes-updates-proxy.service: [ UNSAFE ]
- rc-local.service: [ UNSAFE ]
- rescue.service: [ UNSAFE ]
- rtkit-daemon.service: [ MEDIUM ]
- serial-getty@hvc0.service: [ UNSAFE ]
- switcheroo-control.service: [ EXPOSED ]
- systemd-ask-password-console.service: [ UNSAFE ]
- systemd-ask-password-wall.service: [ UNSAFE ]
- systemd-homed.service: [ MEDIUM ]
- systemd-hostnamed.service: [ PROTECTED ]
- systemd-initctl.service: [ UNSAFE ]
- systemd-journald.service: [ PROTECTED ]
- systemd-logind.service: [ PROTECTED ]
- systemd-networkd.service: [ PROTECTED ]
- systemd-resolved.service: [ PROTECTED ]
- systemd-timesyncd.service: [ PROTECTED ]
- systemd-udevd.service: [ MEDIUM ]
- systemd-userdbd.service: [ PROTECTED ]
- user@1000.service: [ UNSAFE ]
- xendriverdomain.service: [ UNSAFE ]
what about these services on the standalone fedora 33?
qubes-services are surely needed for qubes itself, but whats about the rest?
And this is the kernel hardening section on the same standalone fedora 33
dev.tty.ldisc_autoload (exp: 0) [ DIFFERENT ]
fs.protected_fifos (exp: 2) [ DIFFERENT ]
fs.protected_hardlinks (exp: 1) [ OK ]
fs.protected_regular (exp: 2) [ DIFFERENT ]
fs.protected_symlinks (exp: 1) [ OK ]
fs.suid_dumpable (exp: 0) [ DIFFERENT ]
kernel.core_uses_pid (exp: 1) [ OK ]
kernel.ctrl-alt-del (exp: 0) [ OK ]
kernel.dmesg_restrict (exp: 1) [ OK ]
kernel.kptr_restrict (exp: 2) [ DIFFERENT ]
kernel.modules_disabled (exp: 1) [ DIFFERENT ]
kernel.perf_event_paranoid (exp: 3) [ DIFFERENT ]
kernel.randomize_va_space (exp: 2) [ OK ]
kernel.sysrq (exp: 0) [ DIFFERENT ]
kernel.unprivileged_bpf_disabled (exp: 1) [ DIFFERENT ]
kernel.yama.ptrace_scope (exp: 1 2 3) [ DIFFERENT ]
net.core.bpf_jit_harden (exp: 2) [ DIFFERENT ]
net.ipv4.conf.all.accept_redirects (exp: 0) [ DIFFERENT ]
net.ipv4.conf.all.accept_source_route (exp: 0) [ OK ]
net.ipv4.conf.all.bootp_relay (exp: 0) [ OK ]
net.ipv4.conf.all.forwarding (exp: 0) [ OK ]
net.ipv4.conf.all.log_martians (exp: 1) [ DIFFERENT ]
net.ipv4.conf.all.mc_forwarding (exp: 0) [ OK ]
net.ipv4.conf.all.proxy_arp (exp: 0) [ OK ]
net.ipv4.conf.all.rp_filter (exp: 1) [ DIFFERENT ]
net.ipv4.conf.all.send_redirects (exp: 0) [ DIFFERENT ]
net.ipv4.conf.default.accept_redirects (exp: 0) [ DIFFERENT ]
net.ipv4.conf.default.accept_source_route (exp: 0) [ OK ]
net.ipv4.conf.default.log_martians (exp: 1) [ DIFFERENT ]
net.ipv4.icmp_echo_ignore_broadcasts (exp: 1) [ OK ]
net.ipv4.icmp_ignore_bogus_error_responses (exp: 1) [ OK ]
net.ipv4.tcp_syncookies (exp: 1) [ OK ]
net.ipv4.tcp_timestamps (exp: 0 1) [ OK ]
net.ipv6.conf.all.accept_redirects (exp: 0) [ DIFFERENT ]
net.ipv6.conf.all.accept_source_route (exp: 0) [ OK ]
net.ipv6.conf.default.accept_redirects (exp: 0) [ DIFFERENT ]
net.ipv6.conf.default.accept_source_route (exp: 0) [ OK ]
is there any sense to fiddle on the kernel there?
ppc
October 5, 2021, 2:02pm
12
can you use preformatted text please
ppc
October 5, 2021, 2:17pm
13
there are quite safe to change
i check this on the internet and this is normal (i think no mod needed)
mostly no for this tool
qun
October 5, 2021, 6:48pm
14
sorry, I tried to post it as bockquote, but while adding the second blockquote, by editing the thread it was posted that way.
The other services has to do with system requierements?
how much points did you get via lynis?
I got just 67 (without fiddling)
And by the way… what is “/usr/sbin/xl”? Is it a xen service (I suppose)
rkhunter shows it as possible rootkit
qun
October 6, 2021, 2:37pm
16
what about dnsmasq and such things? I found this here: https://github.com/QubesOS/qubes-issues/issues/37 He talks about DNAT to DNS server, but it’s from 2015.
ppc
October 6, 2021, 2:48pm
17
it a dns server (and sometime dhcp, tftp server)
Completed ?
DNAT to DNS is Destination NAT used to forward dns which make sys-net safer because dns is processed in the vm instead of sys-net (make dnsmasq necessary in other qubes instead sys-net?)
qun
October 7, 2021, 8:49am
18
hmm… interesting, also if I don’t really understand the exact way of working between sys-net and other VMs. And how can I set DNAT to DNS, via iptables in the sys-net?
Whats about implementing dnscrypt in Qubes?
qun
October 7, 2021, 9:18am
20
so it seems to me, that the qubes team will implement dnscrypt to qubes
