Hello,
I have a serious problem with my Qubes OS installation
and I need help recovering access to my encrypted disk.
What happened:
- Yesterday I logged in normally, everything worked fine
- Today the system boots into emergency mode
- LUKS passphrase is not accepted anymore
- I did not change anything manually
System info:
- Device: Lenovo ThinkPad E580
- LUKS version: 2
- Epoch: 3 (was probably modified during automatic update)
- UUID: 7fda813e-8a27-4deb-b14d-20d9fc7c97f0
- Cipher: aes-xts-plain64
- Keyslots: 0 (luks2, 512 bits)
- Two kernels in /boot: 6.12.54 and 6.12.47
Error from cryptsetup:
- “No usable token is available”
- “No key available with this passphrase”
- “Command failed with code -2 (no permission or bad passphrase)”
What I already tried:
- Qubes OS rescue mode - passphrase not accepted
- Debian rescue mode - passphrase not accepted
- Different kernels via GRUB rescue shell
- cryptsetup --disable-keyring luksOpen
- cryptsetup --key-slot 0 luksOpen
- luksHeaderRestore - backup not compatible
I am 100% sure about my passphrase as I used it
every day. The Epoch 3 suggests the header was
modified 3 times, possibly during an automatic update.
Is there any way to recover access or repair
the LUKS header?
Thank you very much for any help!
UPDATE - additional diagnostics:
Key material test: dumped keyslot area with dd,
compressed with xz. Result was NOT compressible
(265800 bytes from 256000 input) - suggests key
material is intact, not corrupted/zeroed.
Verified passphrase characters visually with “cat” -
all characters correct, ruled out keyboard layout.
The rescue ISO I used was Qubes 4.3 (cryptsetup 2.8.1),
but my system was installed around 2024, likely Qubes
4.2. I suspect a cryptsetup/kernel version mismatch.
Planning to retry rescue using a Qubes 4.2.4 ISO to
match the original cryptsetup version.
Questions: Can a newer cryptsetup (2.8.1) reject a
correct passphrase for a LUKS2 container made under an
older release? Are there known argon2/cryptsetup
regressions causing “No key available” with a correct
passphrase?
I’d be careful with the “automatic update changed the LUKS header” assumption. A normal Qubes/dom0 package update should not rewrite LUKS keyslots; the epoch only says the LUKS2 metadata changed at some point, not why. Before trying more repair commands, I would make a fresh header backup from the current disk and keep it read-only, then test only with non-destructive commands like cryptsetup luksDump --dump-json-metadata and cryptsetup open --debug --test-passphrase. If 4.2 rescue media gives the same “No key available”, the hard answer may be that there is no repair path without a matching header backup or another valid keyslot.
I’m curious - did you solve it?
