Local Network in qubes
i am trying to create a local network in Qubes, so a few qubes can use a central git repo.
For this purpose i created a server and a client qube, with the server being the NetVM of the client. Pinging works fine, but as in this post
i was not able to wget/open a test website i set up on the server due to “no route”. Opening all the ports like described there didn’t help either, but no restart of dom0 was tried.
Is a virtual local network possible within Qubes in a secure way or is it just not designed to do it due to security implications?
Also using rpc seems to only work one way, so that would not work for git if i don’t misunderstand it.
Thanks for your help!
Don’t restart dom0 - it’s almost never needed.
In the case you have outlined, you simply need one rule on the server.
iptables -I INPUT -p tcp --dport 80 -j ACCEPT
Where the server has IP address 10:137.0.X, and you have bound the
webserver to that address (important), then on the client,
http://10:137.0.X is sufficient.
I don’t know what you mean about rpc being one way - qubes-rpc processes
(can) run both ways, and split-git, like split-gpg and split-ssh is
simple.
As always, the documentation is helpful: take a look at
Thank you very much unman!
This solved it for me, but i am kinda confused as i thought that i did exactly that when trying. The proposed solution works as a charm.
I will take a look at the DevOps Workflow to learn a thing or to about RPC as i clearly misunterstand it.
Is this still the way it works for Qubes 4.2? I tried these steps and it didn’t work:
I dont know what steps you took, as I cant see the images.
I suspect the mistake you have made is using iptables instead of
nftables, and not checking the documentation.
The command you probably want is:
nft insert rule qubes custom-input tcp dport 80 accept
Thank you so much!!! That worked. I now see that this is a special case of Enabling networking between two qubes which I had ignored because I had no firewall between my client and server qubes.
I really appreciate the help!!!
Glad you have it working as you want.
