Before I open an issue I wished to check if the Qubes OS documentation was being built differently now.
Details
Following these instructions to build the website locally:
within a Fedora 35 qube. Running:
sudo make
results in:
podman start -a qubesosgithubio_jekyll_1
ruby 3.1.1p18 (2022-02-18 revision 53f5fc4236) [x86_64-linux-musl]
Configuration file: /srv/jekyll/_config.yml
Source: /srv/jekyll
Destination: /srv/jekyll/_site
Incremental build: disabled. Enable with --incremental
Generating...
GitHub Metadata: No GitHub API authentication could be found. Some fields may be missing or have incorrect data.
done in 38.795 seconds.
Auto-regeneration: enabled for '/srv/jekyll'
/usr/gem/gems/jekyll-3.9.2/lib/jekyll/commands/serve/servlet.rb:3:in `require': cannot load such file -- webrick (LoadError)
