What I did: Casual dom0 update and upgrading my nvidia (official) driver manually.
What happens: Black screen after booting, only access to tty
Why I am confused: Weirdly enough my iGPU is affected too and sddm works perfectly fine. Sddm β Xfce4 doesnβt work too.
What I tried: Reinstalling lightdm multiple times, resetting my X11 config file, trying to understand my journalctl, uninstalling my nvidia driver, researching if someone experiences the same issues currently.
Why I need help: I am just out of ideas what could cause the issue. Might the lightdm packages be broken? In this case I would not be the only one affected. Do you have any ideas?
Nov 22 12:19:06 dom0 systemd[1]: Starting lightdm.service - Light Display Manager...
ββ Subject: A start job for unit lightdm.service has begun execution
ββ Defined-By: systemd
ββ Support: https://lists.freedesktop.org/mailman/listinfo/systemd-devel
ββ
ββ A start job for unit lightdm.service has begun execution.
ββ
ββ The job identifier is 319.
Nov 22 12:19:06 dom0 systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
ββ Subject: Unit process exited
ββ
ββ An ExecStart= process belonging to unit lightdm.service has exited.
ββ
ββ The process' exit code is 'exited' and its exit status is 1.
Nov 22 12:19:06 dom0 systemd[1]: lightdm.service: Failed with result 'exit-code'.
ββ Subject: Unit failed
ββ
ββ The unit lightdm.service has entered the 'failed' state with result 'exit-code'.
Nov 22 12:19:06 dom0 systemd[1]: Failed to start lightdm.service - Light Display Manager.
ββ Subject: A start job for unit lightdm.service has failed
ββ
ββ A start job for unit lightdm.service has finished with a failure.
ββ
ββ The job identifier is 319 and the job result is failed.
Nov 22 12:19:06 dom0 systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 1.
ββ Subject: Automatic restarting of a unit has been scheduled
ββ
ββ Automatic restarting of the unit lightdm.service has been scheduled, as the result for
ββ the configured Restart= setting for the unit.
Nov 22 12:19:06 dom0 systemd[1]: Stopped lightdm.service - Light Display Manager.
ββ Subject: A stop job for unit lightdm.service has finished
ββ
ββ A stop job for unit lightdm.service has finished.
ββ
ββ The job identifier is 2653 and the job result is done.
ββ
ββ
ββ The job identifier is 2653.
ββ
ββ
ββ
ββ
ββ
ββ The job identifier is 2653 and the job result is failed.
Nov 22 12:19:06 dom0 systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 2.
ββ
ββ
ββ
ββ The job identifier is 2782 and the job result is done.
ββ
ββ
ββ The job identifier is 2782.
ββ
ββ
ββ
ββ
ββ
ββ The job identifier is 2782 and the job result is failed.
Nov 22 12:19:06 dom0 systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 3.
ββ
ββ
ββ
ββ The job identifier is 2911 and the job result is done.
ββ
ββ
ββ The job identifier is 2911.
ββ
ββ
ββ
ββ
ββ
ββ The job identifier is 2911 and the job result is failed.
Nov 22 12:19:07 dom0 systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 4.
ββ
Nov 22 12:19:07 dom0 systemd[1]: Stopped lightdm.service - Light Display Manager.
ββ
ββ
ββ The job identifier is 3040 and the job result is done.
Nov 22 12:19:07 dom0 systemd[1]: Starting lightdm.service - Light Display Manager...
ββ
ββ
ββ The job identifier is 3040.
Nov 22 12:19:07 dom0 systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
ββ
ββ
Nov 22 12:19:07 dom0 systemd[1]: lightdm.service: Failed with result 'exit-code'.
ββ
Nov 22 12:19:07 dom0 systemd[1]: Failed to start lightdm.service - Light Display Manager.
ββ
ββ
ββ The job identifier is 3040 and the job result is failed.
Nov 22 12:19:07 dom0 systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 5.
ββ
ββ
ββ
ββ The job identifier is 3169 and the job result is done.
Nov 22 12:19:07 dom0 systemd[1]: lightdm.service: Start request repeated too quickly.
ββ
ββ
ββ
ββ The job identifier is 3169 and the job result is failed.
Nov 22 12:19:07 dom0 systemd[1]: lightdm.service: Triggering OnFailure= dependencies.
