It’s a long log but this is the end of it:
[2024-09-29 16:25:38] pcifront pci-0: Rescanning PCI Frontend Bus 0000:00
[2024-09-29 16:25:38] pci_bus 0000:00: busn_res: [bus 00-ff] is released
[2024-09-29 16:25:38] ------------[ cut here ]------------
[2024-09-29 16:25:38] sysfs group 'power' not found for kobject '0000:00'
[2024-09-29 16:25:38] WARNING: CPU: 0 PID: 10 at 0xffffffff810e970b
[2024-09-29 16:25:38] CPU: 0 PID: 10 Comm: xenwatch Tainted: G T 5.10.200-xen-stubdom #1
[2024-09-29 16:25:38] RIP: e030:0xffffffff810e970b
[2024-09-29 16:25:38] Code: f6 74 2e 49 89 fc 48 89 df e8 ab fc ff ff 48 89 c3 48 85 c0 75 23 49 8b 14 24 48 8b 75 00 48 c7 c7 7f de 84 81 e8 4c 85 16 00 <0f> 0b 5b 5d 41 5c c3 48 89 df e8 fe cf ff [2024-09-29 16:28:37] Logfile Opened
[2024-09-29 16:28:37] Linux version 5.10.200-xen-stubdom (mockbuild@2bdb0b26ea884dc8be0a7e1546b60a6a) (gcc (GCC) 12.3.1 20230508 (Red Hat 12.3.1-1), GNU ld version 2.38-27.fc37) #1 Sun May 12 14:03:17 GMT 2024
[2024-09-29 16:28:37] Command line:
[2024-09-29 16:28:37] Released 0 page(s)
[2024-09-29 16:28:37] BIOS-provided physical RAM map:
[2024-09-29 16:28:37] Xen: [mem 0x0000000000000000-0x000000000009ffff] usable
[2024-09-29 16:28:37] Xen: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[2024-09-29 16:28:37] Xen: [mem 0x0000000000100000-0x0000000008ffffff] usable
[2024-09-29 16:28:37] NX (Execute Disable) protection: active
[2024-09-29 16:28:37] Hypervisor detected: Xen PV
[2024-09-29 16:28:37] tsc: Fast TSC calibration failed
[2024-09-29 16:28:37] tsc: Detected 4391.700 MHz processor
[2024-09-29 16:28:37] last_pfn = 0x9000 max_arch_pfn = 0x400000000
[2024-09-29 16:28:37] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[2024-09-29 16:28:37] RAMDISK: [mem 0x02000000-0x036fdfff]
[2024-09-29 16:28:37] Zone ranges:
[2024-09-29 16:28:37] DMA32 [mem 0x0000000000001000-0x0000000008ffffff]
[2024-09-29 16:28:37] Normal empty
[2024-09-29 16:28:37] Movable zone start for each node
[2024-09-29 16:28:37] Early memory node ranges
[2024-09-29 16:28:37] node 0: [mem 0x0000000000001000-0x000000000009ffff]
[2024-09-29 16:28:37] node 0: [mem 0x0000000000100000-0x0000000008ffffff]
[2024-09-29 16:28:37] Initmem setup node 0 [mem 0x0000000000001000-0x0000000008ffffff]
[2024-09-29 16:28:37] On node 0, zone DMA32: 1 pages in unavailable ranges
[2024-09-29 16:28:37] On node 0, zone DMA32: 96 pages in unavailable ranges
[2024-09-29 16:28:37] On node 0, zone DMA32: 28672 pages in unavailable ranges
[2024-09-29 16:28:37] p2m virtual area at (____ptrval____), size is 200000
[2024-09-29 16:28:37] Remapped 0 page(s)
[2024-09-29 16:28:37] [mem 0x09000000-0xffffffff] available for PCI devices
[2024-09-29 16:28:37] Booting paravirtualized kernel on Xen
[2024-09-29 16:28:37] Xen version: 4.17.4 (preserve-AD)
[2024-09-29 16:28:37] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[2024-09-29 16:28:37] Built 1 zonelists, mobility grouping on. Total pages: 36170
[2024-09-29 16:28:37] Kernel command line: clocksource=tsc
[2024-09-29 16:28:37] Dentry cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[2024-09-29 16:28:37] Inode-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[2024-09-29 16:28:37] mem auto-init: stack:byref_all(zero), heap alloc:off, heap free:off
[2024-09-29 16:28:37] Memory: 105660K/147068K available (6145K kernel code, 836K rwdata, 428K rodata, 708K init, 472K bss, 41156K reserved, 0K cma-reserved)
[2024-09-29 16:28:37] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[2024-09-29 16:28:37] Using NULL legacy PIC
[2024-09-29 16:28:37] NR_IRQS: 4352, nr_irqs: 24, preallocated irqs: 0
[2024-09-29 16:28:37] xen:events: Using FIFO-based ABI
[2024-09-29 16:28:37] random: crng init done
[2024-09-29 16:28:37] printk: console [hvc0] enabled
[2024-09-29 16:28:37] clocksource: xen: mask: 0xffffffffffffffff max_cycles: 0x1cd42e4dffb, max_idle_ns: 881590591483 ns
[2024-09-29 16:28:37] installing Xen timer for CPU 0
[2024-09-29 16:28:37] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x3f4dc4ceef5, max_idle_ns: 440795225486 ns
[2024-09-29 16:28:37] Calibrating delay loop (skipped), value calculated using timer frequency.. 8783.40 BogoMIPS (lpj=17566800)
[2024-09-29 16:28:37] Last level iTLB entries: 4KB 512, 2MB 512, 4MB 256
[2024-09-29 16:28:37] Last level dTLB entries: 4KB 3072, 2MB 3072, 4MB 1536, 1GB 0
[2024-09-29 16:28:37] CPU: AMD Ryzen 9 7900X3D 12-Core Processor (family: 0x19, model: 0x61, stepping: 0x2)
[2024-09-29 16:28:37] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[2024-09-29 16:28:37] Spectre V2 : Kernel not compiled with retpoline; no mitigation available!
[2024-09-29 16:28:37] Spectre V2 : Vulnerable
[2024-09-29 16:28:37] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[2024-09-29 16:28:37] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[2024-09-29 16:28:37] Speculative Store Bypass: Vulnerable
[2024-09-29 16:28:37] Speculative Return Stack Overflow: IBPB-extending microcode not applied!
[2024-09-29 16:28:37] Speculative Return Stack Overflow: WARNING: See https://kernel.org/doc/html/latest/admin-guide/hw-vuln/srso.html for mitigation options.
[2024-09-29 16:28:37] Speculative Return Stack Overflow: WARNING: kernel not compiled with CPU_SRSO.
[2024-09-29 16:28:37] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[2024-09-29 16:28:37] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[2024-09-29 16:28:37] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[2024-09-29 16:28:37] x86/fpu: Supporting XSAVE feature 0x020: 'AVX-512 opmask'
[2024-09-29 16:28:37] x86/fpu: Supporting XSAVE feature 0x040: 'AVX-512 Hi256'
[2024-09-29 16:28:37] x86/fpu: Supporting XSAVE feature 0x080: 'AVX-512 ZMM_Hi256'
[2024-09-29 16:28:37] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[2024-09-29 16:28:37] x86/fpu: xstate_offset[5]: 832, xstate_sizes[5]: 64
[2024-09-29 16:28:37] x86/fpu: xstate_offset[6]: 896, xstate_sizes[6]: 512
[2024-09-29 16:28:37] x86/fpu: xstate_offset[7]: 1408, xstate_sizes[7]: 1024
[2024-09-29 16:28:37] x86/fpu: Enabled xstate features 0xe7, context size is 2432 bytes, using 'standard' format.
[2024-09-29 16:28:37] pid_max: default: 4096 minimum: 301
[2024-09-29 16:28:37] Mount-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
[2024-09-29 16:28:37] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
[2024-09-29 16:28:37] Performance Events: PMU not available due to virtualization, using software events only.
[2024-09-29 16:28:37] devtmpfs: initialized
[2024-09-29 16:28:37] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[2024-09-29 16:28:37] futex hash table entries: 16 (order: -4, 384 bytes, linear)
[2024-09-29 16:28:37] NET: Registered protocol family 16
[2024-09-29 16:28:37] xen:grant_table: Grant tables using version 1 layout
[2024-09-29 16:28:37] Grant table initialized
[2024-09-29 16:28:37] PCI: setting up Xen PCI frontend stub
[2024-09-29 16:28:37] xen:balloon: Initialising balloon driver
[2024-09-29 16:28:37] PCI: System does not support PCI
[2024-09-29 16:28:37] clocksource: Switched to clocksource xen
[2024-09-29 16:28:37] NET: Registered protocol family 2
[2024-09-29 16:28:37] IP idents hash table entries: 4096 (order: 3, 32768 bytes, linear)
[2024-09-29 16:28:37] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
[2024-09-29 16:28:37] TCP established hash table entries: 2048 (order: 2, 16384 bytes, linear)
[2024-09-29 16:28:37] TCP bind hash table entries: 2048 (order: 2, 16384 bytes, linear)
[2024-09-29 16:28:37] TCP: Hash tables configured (established 2048 bind 2048)
[2024-09-29 16:28:37] UDP hash table entries: 128 (order: 0, 4096 bytes, linear)
[2024-09-29 16:28:37] UDP-Lite hash table entries: 128 (order: 0, 4096 bytes, linear)
[2024-09-29 16:28:37] Unpacking initramfs...
[2024-09-29 16:28:37] Freeing initrd memory: 23544K
[2024-09-29 16:28:37] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x3f4dc4ceef5, max_idle_ns: 440795225486 ns
[2024-09-29 16:28:37] clocksource: Switched to clocksource tsc
[2024-09-29 16:28:37] workingset: timestamp_bits=62 max_order=15 bucket_order=0
[2024-09-29 16:28:37] xen:xen_evtchn: Event-channel device installed
[2024-09-29 16:28:37] Invalid max_queues (4), will use default max: 1.
[2024-09-29 16:28:37] tun: Universal TUN/TAP device driver, 1.6
[2024-09-29 16:28:37] xen_netfront: Initialising Xen virtual ethernet driver
[2024-09-29 16:28:37] NET: Registered protocol family 17
[2024-09-29 16:28:37] sched_clock: Marking stable (71187279, 288564)->(73444295, -1968452)
[2024-09-29 16:28:37] pcifront pci-0: Installing PCI frontend
[2024-09-29 16:28:37] xen:swiotlb_xen: Warning: only able to allocate 4 MB for software IO TLB
[2024-09-29 16:28:37] software IO TLB: mapped [mem 0x0000000003000000-0x0000000003400000] (4MB)
[2024-09-29 16:28:37] pcifront pci-0: Creating PCI Frontend Bus 0000:00
[2024-09-29 16:28:37] pcifront pci-0: PCI host bridge to bus 0000:00
[2024-09-29 16:28:37] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[2024-09-29 16:28:37] pci_bus 0000:00: root bus resource [mem 0x00000000-0x3fffffffffff]
[2024-09-29 16:28:37] pci_bus 0000:00: root bus resource [bus 00-ff]
[2024-09-29 16:28:38] pci 0000:00:00.0: [10de:2203] type 00 class 0x030000
[2024-09-29 16:28:38] pci 0000:00:00.0: reg 0x10: [mem 0xfb000000-0xfbffffff]
[2024-09-29 16:28:38] pci 0000:00:00.0: reg 0x14: [mem 0xf000000000-0xf7ffffffff 64bit pref]
[2024-09-29 16:28:38] pci 0000:00:00.0: reg 0x1c: [mem 0xf800000000-0xf801ffffff 64bit pref]
[2024-09-29 16:28:38] pci 0000:00:00.0: reg 0x24: [io 0xf000-0xf07f]
[2024-09-29 16:28:38] pci 0000:00:00.0: reg 0x30: [mem 0xfc000000-0xfc07ffff pref]
[2024-09-29 16:28:38] pci 0000:00:00.1: [10de:1aef] type 00 class 0x040300
[2024-09-29 16:28:38] pci 0000:00:00.1: reg 0x10: [mem 0xfc080000-0xfc083fff]
[2024-09-29 16:28:38] pcifront pci-0: claiming resource 0000:00:00.0/0
[2024-09-29 16:28:38] pcifront pci-0: claiming resource 0000:00:00.0/1
[2024-09-29 16:28:38] pcifront pci-0: claiming resource 0000:00:00.0/3
[2024-09-29 16:28:38] pcifront pci-0: claiming resource 0000:00:00.0/5
[2024-09-29 16:28:38] pcifront pci-0: claiming resource 0000:00:00.0/6
[2024-09-29 16:28:38] pcifront pci-0: claiming resource 0000:00:00.1/0
[2024-09-29 16:28:38] xen_netfront: backend supports XDP headroom
[2024-09-29 16:28:38] vif vif-0: bouncing transmitted data to zeroed pages
[2024-09-29 16:28:38] blkfront: xvda: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
[2024-09-29 16:28:38] blkfront: xvdb: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
[2024-09-29 16:28:38] blkfront: xvdc: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
[2024-09-29 16:28:38] Freeing unused kernel image (initmem) memory: 708K
[2024-09-29 16:28:38] Write protecting the kernel read-only data: 10240k
[2024-09-29 16:28:38] Freeing unused kernel image (text/rodata gap) memory: 2044K
[2024-09-29 16:28:38] Freeing unused kernel image (rodata/data gap) memory: 1620K
[2024-09-29 16:28:38] Run /init as init process
[2024-09-29 16:28:38] + mount -t devtmpfs none /dev
[2024-09-29 16:28:38] + mount -t sysfs /sys /sys
[2024-09-29 16:28:38] + mount -t proc /proc /proc
[2024-09-29 16:28:38] + mount -t tmpfs -o 'size=1m,nodev,noexec' /tmp /tmp
[2024-09-29 16:28:38] + mkdir /dev/shm
[2024-09-29 16:28:38] + mount -t tmpfs -o 'size=1m,nodev,noexec' tmpfs /dev/shm
[2024-09-29 16:28:38] + mount -o remount,ro /
[2024-09-29 16:28:38] + echo 1
[2024-09-29 16:28:38] + printf '%d\n' 1073741824
[2024-09-29 16:28:38] + /bin/xenstore-read target
[2024-09-29 16:28:38] + domid=21
[2024-09-29 16:28:38] + xenstore-read /local/domain/21/vm
[2024-09-29 16:28:38] + vm_path=/vm/58897c43-f898-45c1-a700-9aa392c8d1d8
[2024-09-29 16:28:38] + sort
[2024-09-29 16:28:38] + xenstore-list -p /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv
[2024-09-29 16:28:38] + xenstore-read /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/001 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/002 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/003 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/004 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/005 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/006 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/007 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/008 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/009 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/010 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/011 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/012 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/013 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/014 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/015 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/016 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/017 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/018 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/019 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/020 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/021 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/022 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/023 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/024 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/025 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/026 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/027 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/028 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/029 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/030 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/031 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/032 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/033 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/034 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/035 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/036 /vm/58897c43-f898-45c1-a700-9aa392c8d1d8/image/dm-argv/037
[2024-09-29 16:28:38] + dm_args='-xen-domid
[2024-09-29 16:28:38] 21
[2024-09-29 16:28:38] -no-shutdown
[2024-09-29 16:28:38] -nodefaults
[2024-09-29 16:28:38] -no-user-config
[2024-09-29 16:28:38] -name
[2024-09-29 16:28:38] windows
[2024-09-29 16:28:38] -display
[2024-09-29 16:28:38] none
[2024-09-29 16:28:38] -device
[2024-09-29 16:28:38] VGA,vgamem_mb=16
[2024-09-29 16:28:38] -boot
[2024-09-29 16:28:38] order=dc
[2024-09-29 16:28:38] usb-ehci,id=ehci
[2024-09-29 16:28:38] usb-tablet,bus=ehci.0
[2024-09-29 16:28:38] -smp
[2024-09-29 16:28:38] 8,maxcpus=8
[2024-09-29 16:28:38] rtl8139,id=nic0,netdev=net0,mac=00:16:3e:5e:6c:00
[2024-09-29 16:28:38] -netdev
[2024-09-29 16:28:38] type=tap,id=net0,ifname=vif21.0-emu,br=xenbr0,script=no,downscript=no
[2024-09-29 16:28:38] qubes-gui,domid=0,log-level=0
[2024-09-29 16:28:38] -machine
[2024-09-29 16:28:38] xenfv,suppress-vmdesc=on
[2024-09-29 16:28:38] -qubes-audio:audiovm_xid=0
[2024-09-29 16:28:38] -qubes-net:client_ip=10.137.0.7,dns_0=10.139.1.1,dns_1=10.139.1.2,gw=10.138.35.96,netmask=255.255.255.255
[2024-09-29 16:28:38] 15984
[2024-09-29 16:28:38] -drive
[2024-09-29 16:28:38] file=/dev/xvda,if=ide,index=0,media=disk,format=host_device,cache=writeback
[2024-09-29 16:28:38] file=/dev/xvdb,if=ide,index=1,media=disk,format=host_device,cache=writeback
[2024-09-29 16:28:38] file=/dev/xvdc,if=ide,index=2,media=disk,format=host_device,cache=writeback'
[2024-09-29 16:28:38] + usb_args=
[2024-09-29 16:28:38] + test -e /bin/qrexec-agent
[2024-09-29 16:28:38] + sed -n /^-qubes-audio:/p
[2024-09-29 16:28:38] + echo '-xen-domid
[2024-09-29 16:28:38] + audio_args='-qubes-audio:audiovm_xid=0'
[2024-09-29 16:28:38] + sed /^-qubes-audio:/d
[2024-09-29 16:28:38] + '[' -z '-qubes-audio:audiovm_xid=0' ]
[2024-09-29 16:28:38] + sed -n 's/^.*[:,]audiovm_xid=\([^,]\+\).*$/\1/p'
[2024-09-29 16:28:38] + echo '-qubes-audio:audiovm_xid=0'
[2024-09-29 16:28:38] + domid=0
[2024-09-29 16:28:38] + sed -n '/^\(intel-hda\|ac97\|adlib\|es1370\|cs4231a\|gus\|sb16\)$/ {p}'
[2024-09-29 16:28:38] + audio_model=
[2024-09-29 16:28:38] + '[' -n ]
[2024-09-29 16:28:38] + sed -n /^-qubes-net:/p
[2024-09-29 16:28:38] + net_args='-qubes-net:client_ip=10.137.0.7,dns_0=10.139.1.1,dns_1=10.139.1.2,gw=10.138.35.96,netmask=255.255.255.255'
[2024-09-29 16:28:38] + sed /^-qubes-net:/d
[2024-09-29 16:28:38] + test -e /sys/class/net/eth0
[2024-09-29 16:28:38] + ip link set eth0 address fe:ff:ff:ff:ff:fe
[2024-09-29 16:28:38] + ip addr flush eth0
[2024-09-29 16:28:38] + ip link set eth0 up
[2024-09-29 16:28:38] + brctl addbr br0
[2024-09-29 16:28:38] + brctl addif br0 eth0
[2024-09-29 16:28:38] br0: port 1(eth0) entered blocking state
[2024-09-29 16:28:38] br0: port 1(eth0) entered disabled state
[2024-09-29 16:28:38] device eth0 entered promiscuous mode
[2024-09-29 16:28:38] + ip link set br0 up
[2024-09-29 16:28:38] br0: port 1(eth0) entered forwarding state
[2024-09-29 16:28:38] + get_net_arg dns_0
[2024-09-29 16:28:38] + sed -n 's/^.*[:,]dns_0=\([^,]\+\).*$/\1/p'
[2024-09-29 16:28:38] + echo '-qubes-net:client_ip=10.137.0.7,dns_0=10.139.1.1,dns_1=10.139.1.2,gw=10.138.35.96,netmask=255.255.255.255'
[2024-09-29 16:28:38] + net_dns_0=10.139.1.1
[2024-09-29 16:28:38] + get_net_arg dns_1
[2024-09-29 16:28:38] + sed -n 's/^.*[:,]dns_1=\([^,]\+\).*$/\1/p'
[2024-09-29 16:28:38] + net_dns_1=10.139.1.2
[2024-09-29 16:28:38] + get_net_arg client_ip
[2024-09-29 16:28:38] + sed -n 's/^.*[:,]client_ip=\([^,]\+\).*$/\1/p'
[2024-09-29 16:28:38] + net_client_ip=10.137.0.7
[2024-09-29 16:28:38] + get_net_arg netmask
[2024-09-29 16:28:38] + sed -n 's/^.*[:,]netmask=\([^,]\+\).*$/\1/p'
[2024-09-29 16:28:38] + net_netmask=255.255.255.255
[2024-09-29 16:28:38] + get_net_arg gw
[2024-09-29 16:28:38] + sed -n 's/^.*[:,]gw=\([^,]\+\).*$/\1/p'
[2024-09-29 16:28:38] + net_gw=10.138.35.96
[2024-09-29 16:28:38] + xenstore-read target
[2024-09-29 16:28:38] + target=21
[2024-09-29 16:28:38] + device_model=device-model/21
[2024-09-29 16:28:38] + mkdir /tmp/qmp
[2024-09-29 16:28:38] + udhcpd -f -I 10.138.35.96 -
[2024-09-29 16:28:38] + kernel=
[2024-09-29 16:28:38] udhcpd: started, v1.31.1
[2024-09-29 16:28:38] + grep -q ^-append
[2024-09-29 16:28:38] + mkfifo /tmp/qmp/qemu.in /tmp/qmp/qemu.out
[2024-09-29 16:28:38] + set +x
[2024-09-29 16:28:38] Clearing kmsg buffer...
[2024-09-29 16:28:38] + sed 's/\$STUBDOM_RESTORE_INCOMING_ARG/fd:3/'
[2024-09-29 16:28:38] + xenstore-read device/console/2
[2024-09-29 16:28:38] + xenstore-read device/console/1
[2024-09-29 16:28:38] + IFS='
[2024-09-29 16:28:38] '
[2024-09-29 16:28:38] + set -f
[2024-09-29 16:28:38] + set +f
[2024-09-29 16:28:38] + unset IFS
[2024-09-29 16:28:38] + qemu_pid=260
[2024-09-29 16:28:38] + '[' '!' -e /tmp/qemu.qmp ]
[2024-09-29 16:28:38] + sleep 0.1
[2024-09-29 16:28:38] + qemu -sandbox 'on,obsolete=deny,elevateprivileges=deny,spawn=deny,resourcecontrol=deny' -chardev 'pipe,path=/tmp/qmp/qemu,id=m' -mon 'chardev=m,mode=control' -chardev 'socket,server,nowait,path=/tmp/qemu.qmp,id=m2' -mon 'chardev=m2,mode=control' -xen-domid 21 -no-shutdown -nodefaults -no-user-config -name windows -display none -device 'VGA,vgamem_mb=16' -boot 'order=dc' -device 'usb-ehci,id=ehci' -device 'usb-tablet,bus=ehci.0' -smp '8,maxcpus=8' -device 'rtl8139,id=nic0,netdev=net0,mac=00:16:3e:5e:6c:00' -netdev 'type=tap,id=net0,ifname=vif21.0-emu,br=xenbr0,script=no,downscript=no' -display 'qubes-gui,domid=0,log-level=0' -machine 'xenfv,suppress-vmdesc=on' -m 15984 -drive 'file=/dev/xvda,if=ide,index=0,media=disk,format=host_device,cache=writeback' -drive 'file=/dev/xvdb,if=ide,index=1,media=disk,format=host_device,cache=writeback' -drive 'file=/dev/xvdc,if=ide,index=2,media=disk,format=host_device,cache=writeback'
[2024-09-29 16:28:38] qemu: -chardev socket,server,nowait,path=/tmp/qemu.qmp,id=m2: warning: short-form boolean option 'server' deprecated
[2024-09-29 16:28:38] Please use server=on instead
[2024-09-29 16:28:38] qemu: -chardev socket,server,nowait,path=/tmp/qemu.qmp,id=m2: warning: short-form boolean option 'nowait' deprecated
[2024-09-29 16:28:38] Please use wait=off instead
[2024-09-29 16:28:38] + tee /proc/self/fd/2
[2024-09-29 16:28:38] + echo '{"execute": "qmp_capabilities"}'
[2024-09-29 16:28:38] {"execute": "qmp_capabilities"}
[2024-09-29 16:28:38] {"QMP": {"version": {"qemu": {"micro": 2, "minor": 1, "major": 8}, "package": ""}, "capabilities": ["oob"]}}
[2024-09-29 16:28:38] qubes_gui/init: 574
[2024-09-29 16:28:38] qubes_gui/init: 583
[2024-09-29 16:28:38] qubes_gui/init: 585
[2024-09-29 16:28:38] qubes_gui/init[612]: version sent, waiting for xorg conf
[2024-09-29 16:28:38] {"return": {}}
[2024-09-29 16:28:38] br0: port 2(vif21.0-emu) entered blocking state
[2024-09-29 16:28:38] br0: port 2(vif21.0-emu) entered disabled state
[2024-09-29 16:28:38] device vif21.0-emu entered promiscuous mode
[2024-09-29 16:28:38] br0: port 2(vif21.0-emu) entered forwarding state
[2024-09-29 16:28:38] + '[' -e /proc/self/fd/4 ]
[2024-09-29 16:28:38] + '[' -e /proc/self/fd/3 ]
[2024-09-29 16:28:38] + true
[2024-09-29 16:28:38] + printf '==== Press enter for shell ====\n'
[2024-09-29 16:28:38] ==== Press enter for shell ====
[2024-09-29 16:28:38] + read
[2024-09-29 16:28:38] + vchan-socket-proxy '--mode=server' '--reconnect-marker=1' --verbose 0 device-model/21/qmp-vchan /tmp/qemu.qmp
[2024-09-29 16:28:38] from-unix: {"QMP": {"version": {"qemu": {"micro": 2, "minor": 1, "major": 8}, "package": ""}, "capabilities": ["oob"]}}
[2024-09-29 16:28:38] wrote 110 bytes to vchan
[2024-09-29 16:28:38] from-vchan:
[2024-09-29 16:28:38] from-vchan: {"execute":"qmp_capabilities","id":2020372737}
[2024-09-29 16:28:38] from-unix: {"return": {}, "id": 2020372737}
[2024-09-29 16:28:38] wrote 34 bytes to vchan
[2024-09-29 16:28:38] from-vchan: {"execute":"device_add","id":2020372736,"arguments":{"driver":"xen-pci-passthrough","id":"pci-pt-01_00.0","hostaddr":"0000:01:00.0"}}
[2024-09-29 16:28:38] [00:06.0] xen_pt_realize: Assigning real physical device 01:00.0 to devfn 0x30
[2024-09-29 16:28:38] [00:06.0] xen_pt_register_regions: IO region 0 registered (size=0x01000000 base_addr=0xfb000000 type: 0x0)
[2024-09-29 16:28:38] [00:06.0] xen_pt_register_regions: IO region 1 registered (size=0x800000000 base_addr=0xf000000000 type: 0x4)
[2024-09-29 16:28:38] [00:06.0] xen_pt_register_regions: IO region 3 registered (size=0x02000000 base_addr=0xf800000000 type: 0x4)
[2024-09-29 16:28:38] [00:06.0] xen_pt_register_regions: IO region 5 registered (size=0x00000080 base_addr=0x0000f000 type: 0x1)
[2024-09-29 16:28:38] [00:06.0] xen_pt_register_regions: Expansion ROM registered (size=0x00080000 base_addr=0xfc000000)
[2024-09-29 16:28:38] [00:06.0] xen_pt_config_reg_init: Offset 0x0010 mismatch! Emulated=0x0000, host=0xfb000000, syncing to 0xfb000000.
[2024-09-29 16:28:38] [00:06.0] xen_pt_config_reg_init: Offset 0x0014 mismatch! Emulated=0x0000, host=0x000c, syncing to 0x000c.
[2024-09-29 16:28:38] [00:06.0] xen_pt_config_reg_init: Offset 0x0018 mismatch! Emulated=0x0000, host=0x00f0, syncing to 0x00f0.
[2024-09-29 16:28:38] [00:06.0] xen_pt_config_reg_init: Offset 0x001c mismatch! Emulated=0x0000, host=0x000c, syncing to 0x000c.
[2024-09-29 16:28:38] [00:06.0] xen_pt_config_reg_init: Offset 0x0020 mismatch! Emulated=0x0000, host=0x00f8, syncing to 0x00f8.
[2024-09-29 16:28:38] [00:06.0] xen_pt_config_reg_init: Offset 0x0024 mismatch! Emulated=0x0000, host=0xf001, syncing to 0xf001.
[2024-09-29 16:28:38] [00:06.0] xen_pt_config_reg_init: Offset 0x0062 mismatch! Emulated=0x0000, host=0x0003, syncing to 0x0003.
[2024-09-29 16:28:38] [00:06.0] xen_pt_pm_ctrl_reg_init_off: PCI power management control passthrough is off
[2024-09-29 16:28:38] [00:06.0] xen_pt_config_reg_init: Offset 0x006a mismatch! Emulated=0x0000, host=0x0080, syncing to 0x0080.
[2024-09-29 16:28:38] [00:06.0] xen_pt_config_reg_init: Offset 0x007c mismatch! Emulated=0x0000, host=0x112c8de1, syncing to 0x12c8de1.
[2024-09-29 16:28:38] [00:06.0] xen_pt_config_reg_init: Offset 0x008a mismatch! Emulated=0x0000, host=0x1104, syncing to 0x1104.
[2024-09-29 16:28:38] [00:06.0] xen_pt_pci_intx: intx=1
[2024-09-29 16:28:38] [00:06.0] xen_pt_realize: Real physical device 01:00.0 registered successfully
[2024-09-29 16:28:38] from-unix: {"return": {}, "id": 2020372736}
[2024-09-29 16:28:38] from-vchan: {"execute":"query-pci","id":2020372738}
[2024-09-29 16:28:38] from-unix: {"return": [{"bus": 0, "devices": [{"irq_pin": 0, "bus": 0, "qdev_id": "", "slot": 0, "class_info": {"class": 1536, "desc": "Host bridge"}, "id": {"device": 4663, "subsystem-vendor": 6900, "vendor": 32902, "subsystem": 4352}, "function": 0, "regions": []}, {"irq_pin": 0, "bus": 0, "qdev_id": "", "slot": 1, "class_info": {"class": 1537, "desc": "ISA bridge"}, "id": {"device": 28672, "subsystem-vendor": 6900, "vendor": 32902, "subsystem": 4352}, "function": 0, "regions": []}, {"irq_pin": 0, "bus": 0, "qdev_id": "", "slot": 1, "class_info": {"class": 257, "desc": "IDE controller"}, "id": {"device": 28688, "subsystem-vendor": 6900, "vendor": 32902, "subsystem": 4352}, "function": 1, "regions": [{"bar": 4, "size": 16, "address": -1, "type": "io"}]}, {"irq_pin": 1, "bus": 0, "qdev_id": "", "irq": 0, "slot": 1, "class_info": {"class": 1664, "desc": "Bridge"}, "id": {"device": 28947, "subsystem-vendor": 6900, "vendor": 32902, "subsystem": 4352}, "function": 3, "regions": []}, {"irq_pin": 1, "bus": 0, "qdev_id": "", "irq": 0, "slot": 2, "class_info": {"class": 65408}, "id": {"device": 1, "subsystem-vendor": 22611, "vendor": 22611, "subsystem": 1}, "function": 0, "regions": [{"bar": 0, "size": 256, "address": -1, "type": "io"}, {"prefetch": true, "mem_type_64": false, "bar": 1, "size": 16777216, "address": -1, "type": "memory"}]}, {"irq_pin": 0, "bus": 0, "qdev_id": "", "slot": 3, "class_info": {"class": 768, "desc": "VGA controller"}, "id": {"device": 4369, "subsystem-vendor": 6900, "vendor": 4660, "subsystem": 4352}, "function": 0, "regions": [{"prefetch": true, "mem_type_64": false, "bar": 0, "size": 16777216, "address": -1, "type": "memory"}, {"prefetch": false, "mem_type_64": false, "bar": 2, "size": 4096, "address": -1, "type": "memory"}, {"prefetch": false, "mem_type_64": false, "bar": 6, "size": 65536, "address": -1, "type": "memory"}]}, {"irq_pin": 4, "bus": 0, "qdev_id": "ehci", "irq": 0, "slot": 4, "class_info": {"class": 3075, "desc": "USB controller"}, "id": {"device": 9421, "subsystem-vendor": 6900, "vendor": 32902, "subsystem": 4352}, "function": 0, "regions": [{"prefetch": false, "mem_type_64": false, "bar": 0, "size": 4096, "address": -1, "type": "memory"}]}, {"irq_pin": 1, "bus": 0, "qdev_id": "nic0", "irq": 0, "slot": 5, "class_info": {"class": 512, "desc": "Ethernet controller"}, "id": {"device": 33081, "subsystem-vendor": 6900, "vendor": 4332, "subsystem": 4352}, "function": 0, "regions": [{"bar": 0, "size": 256, "address": -1, "type": "io"}, {"prefetch": false, "mem_type_64": false, "bar": 1, "size": 256, "address": -1, "type": "memory"}]}, {"irq_pin": 1, "bus": 0, "qdev_id": "pci-pt-01_00.0", "irq": 0, "slot": 6, "class_info": {"class": 0}, "id": {"device": 8707, "subsystem-vendor": 0, "vendor": 4318, "subsystem": 0}, "function": 0, "regions": [{"prefetch": false, "mem_type_64": false, "bar": 0, "size": 16777216, "address": -1, "type": "memory"}, {"prefetch": false, "mem_type_64": true, "bar": 1, "size": 34359738368, "address": -1, "type": "memory"}, {"prefetch": false, "mem_type_64": true, "bar": 3, "size": 33554432, "address": -1, "type": "memory"}, {"bar": 5, "size": 128, "address": -1, "type": "io"}, {"prefetch": true, "mem_type_64": false, "bar": 6, "size": 524288, "address": -1, "type": "memory"}]}]}], "id": 2020372738}
[2024-09-29 16:28:38] wrote 2048 bytes to vchan
[2024-09-29 16:28:38] wrote 1252 bytes to vchan
[2024-09-29 16:28:38] vchan client disconnected
[2024-09-29 16:28:38] from-vchan: {"execute":"device_add","id":2020372736,"arguments":{"driver":"xen-pci-passthrough","id":"pci-pt-01_00.1","hostaddr":"0000:01:00.1"}}
[2024-09-29 16:28:38] [00:07.0] xen_pt_realize: Assigning real physical device 01:00.1 to devfn 0x38
[2024-09-29 16:28:38] [00:07.0] xen_pt_register_regions: IO region 0 registered (size=0x00004000 base_addr=0xfc080000 type: 0x0)
[2024-09-29 16:28:38] [00:07.0] xen_pt_config_reg_init: Offset 0x0010 mismatch! Emulated=0x0000, host=0xfc080000, syncing to 0xfc080000.
[2024-09-29 16:28:38] [00:07.0] xen_pt_config_reg_init: Offset 0x0062 mismatch! Emulated=0x0000, host=0x0003, syncing to 0x0003.
[2024-09-29 16:28:38] [00:07.0] xen_pt_pm_ctrl_reg_init_off: PCI power management control passthrough is off
[2024-09-29 16:28:38] [00:07.0] xen_pt_config_reg_init: Offset 0x006a mismatch! Emulated=0x0000, host=0x0080, syncing to 0x0080.
[2024-09-29 16:28:38] [00:07.0] xen_pt_config_reg_init: Offset 0x007c mismatch! Emulated=0x0000, host=0x12c8de1, syncing to 0x12c8de1.
[2024-09-29 16:28:38] [00:07.0] xen_pt_config_reg_init: Offset 0x008a mismatch! Emulated=0x0000, host=0x1104, syncing to 0x1104.
[2024-09-29 16:28:38] [00:07.0] xen_pt_pci_intx: intx=2
[2024-09-29 16:28:38] [00:07.0] xen_pt_realize: Real physical device 01:00.1 registered successfully
[2024-09-29 16:28:38] from-unix: {"return": [{"bus": 0, "devices": [{"irq_pin": 0, "bus": 0, "qdev_id": "", "slot": 0, "class_info": {"class": 1536, "desc": "Host bridge"}, "id": {"device": 4663, "subsystem-vendor": 6900, "vendor": 32902, "subsystem": 4352}, "function": 0, "regions": []}, {"irq_pin": 0, "bus": 0, "qdev_id": "", "slot": 1, "class_info": {"class": 1537, "desc": "ISA bridge"}, "id": {"device": 28672, "subsystem-vendor": 6900, "vendor": 32902, "subsystem": 4352}, "function": 0, "regions": []}, {"irq_pin": 0, "bus": 0, "qdev_id": "", "slot": 1, "class_info": {"class": 257, "desc": "IDE controller"}, "id": {"device": 28688, "subsystem-vendor": 6900, "vendor": 32902, "subsystem": 4352}, "function": 1, "regions": [{"bar": 4, "size": 16, "address": -1, "type": "io"}]}, {"irq_pin": 1, "bus": 0, "qdev_id": "", "irq": 0, "slot": 1, "class_info": {"class": 1664, "desc": "Bridge"}, "id": {"device": 28947, "subsystem-vendor": 6900, "vendor": 32902, "subsystem": 4352}, "function": 3, "regions": []}, {"irq_pin": 1, "bus": 0, "qdev_id": "", "irq": 0, "slot": 2, "class_info": {"class": 65408}, "id": {"device": 1, "subsystem-vendor": 22611, "vendor": 22611, "subsystem": 1}, "function": 0, "regions": [{"bar": 0, "size": 256, "address": -1, "type": "io"}, {"prefetch": true, "mem_type_64": false, "bar": 1, "size": 16777216, "address": -1, "type": "memory"}]}, {"irq_pin": 0, "bus": 0, "qdev_id": "", "slot": 3, "class_info": {"class": 768, "desc": "VGA controller"}, "id": {"device": 4369, "subsystem-vendor": 6900, "vendor": 4660, "subsystem": 4352}, "function": 0, "regions": [{"prefetch": true, "mem_type_64": false, "bar": 0, "size": 16777216, "address": -1, "type": "memory"}, {"prefetch": false, "mem_type_64": false, "bar": 2, "size": 4096, "address": -1, "type": "memory"}, {"prefetch": false, "mem_type_64": false, "bar": 6, "size": 65536, "address": -1, "type": "memory"}]}, {"irq_pin": 4, "bus": 0, "qdev_id": "ehci", "irq": 0, "slot": 4, "class_info": {"class": 3075, "desc": "USB controller"}, "id": {"device": 9421, "subsystem-vendor": 6900, "vendor": 32902, "subsystem": 4352}, "function": 0, "regions": [{"prefetch": false, "mem_type_64": false, "bar": 0, "size": 4096, "address": -1, "type": "memory"}]}, {"irq_pin": 1, "bus": 0, "qdev_id": "nic0", "irq": 0, "slot": 5, "class_info": {"class": 512, "desc": "Ethernet controller"}, "id": {"device": 33081, "subsystem-vendor": 6900, "vendor": 4332, "subsystem": 4352}, "function": 0, "regions": [{"bar": 0, "size": 256, "address": -1, "type": "io"}, {"prefetch": false, "mem_type_64": false, "bar": 1, "size": 256, "address": -1, "type": "memory"}]}, {"irq_pin": 1, "bus": 0, "qdev_id": "pci-pt-01_00.0", "irq": 0, "slot": 6, "class_info": {"class": 0}, "id": {"device": 8707, "subsystem-vendor": 0, "vendor": 4318, "subsystem": 0}, "function": 0, "regions": [{"prefetch": false, "mem_type_64": false, "bar": 0, "size": 16777216, "address": -1, "type": "memory"}, {"prefetch": false, "mem_type_64": true, "bar": 1, "size": 34359738368, "address": -1, "type": "memory"}, {"prefetch": false, "mem_type_64": true, "bar": 3, "size": 33554432, "address": -1, "type": "memory"}, {"bar": 5, "size": 128, "address": -1, "type": "io"}, {"prefetch": true, "mem_type_64": false, "bar": 6, "size": 524288, "address": -1, "type": "memory"}]}, {"irq_pin": 2, "bus": 0, "qdev_id": "pci-pt-01_00.1", "irq": 0, "slot": 7, "class_info": {"class": 0}, "id": {"device": 6895, "subsystem-vendor": 0, "vendor": 4318, "subsystem": 0}, "function": 0, "regions": [{"prefetch": false, "mem_type_64": false, "bar": 0, "size": 16384, "address": -1, "type": "memory"}]}]}], "id": 2020372738}
[2024-09-29 16:28:38] wrote 1564 bytes to vchan
[2024-09-29 16:28:38] qubes_gui/init[623]: got xorg conf, creating window
[2024-09-29 16:28:38] qubes_gui/init: 633
[2024-09-29 16:28:38] configure msg, x/y 0 55 (was 0 0), w/h 640 480
[2024-09-29 16:28:47] pcifront pci-0: Rescanning PCI Frontend Bus 0000:00
[2024-09-29 16:28:47] pci_bus 0000:00: busn_res: [bus 00-ff] is released
[2024-09-29 16:28:47] ------------[ cut here ]------------
[2024-09-29 16:28:47] sysfs group 'power' not found for kobject '0000:00'
[2024-09-29 16:28:47] WARNING: CPU: 0 PID: 10 at 0xffffffff810e970b
[2024-09-29 16:28:47] CPU: 0 PID: 10 Comm: xenwatch Tainted: G T 5.10.200-xen-stubdom #1
[2024-09-29 16:28:47] RIP: e030:0xffffffff810e970b
[2024-09-29 16:29:01] Logfile Opened
[2024-09-29 16:29:01] Linux version 5.10.200-xen-stubdom (mockbuild@2bdb0b26ea884dc8be0a7e1546b60a6a) (gcc (GCC) 12.3.1 20230508 (Red Hat 12.3.1-1), GNU ld version 2.38-27.fc37) #1 Sun May 12 14:03:17 GMT 2024
[2024-09-29 16:29:01] Command line:
[2024-09-29 16:29:01] Released 0 page(s)
[2024-09-29 16:29:01] BIOS-provided physical RAM map:
[2024-09-29 16:29:01] Xen: [mem 0x0000000000000000-0x000000000009ffff] usable
[2024-09-29 16:29:01] Xen: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[2024-09-29 16:29:01] Xen: [mem 0x0000000000100000-0x0000000008ffffff] usable
[2024-09-29 16:29:01] NX (Execute Disable) protection: active
[2024-09-29 16:29:01] Hypervisor detected: Xen PV
[2024-09-29 16:29:01] tsc: Fast TSC calibration failed
[2024-09-29 16:29:01] tsc: Detected 4391.700 MHz processor
[2024-09-29 16:29:01] last_pfn = 0x9000 max_arch_pfn = 0x400000000
[2024-09-29 16:29:01] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[2024-09-29 16:29:01] RAMDISK: [mem 0x02000000-0x036fdfff]
[2024-09-29 16:29:01] Zone ranges:
[2024-09-29 16:29:01] DMA32 [mem 0x0000000000001000-0x0000000008ffffff]
[2024-09-29 16:29:01] Normal empty
[2024-09-29 16:29:01] Movable zone start for each node
[2024-09-29 16:29:01] Early memory node ranges
[2024-09-29 16:29:01] node 0: [mem 0x0000000000001000-0x000000000009ffff]
[2024-09-29 16:29:01] node 0: [mem 0x0000000000100000-0x0000000008ffffff]
[2024-09-29 16:29:01] Initmem setup node 0 [mem 0x0000000000001000-0x0000000008ffffff]
[2024-09-29 16:29:01] On node 0, zone DMA32: 1 pages in unavailable ranges
[2024-09-29 16:29:01] On node 0, zone DMA32: 96 pages in unavailable ranges
[2024-09-29 16:29:01] On node 0, zone DMA32: 28672 pages in unavailable ranges
[2024-09-29 16:29:01] p2m virtual area at (____ptrval____), size is 200000
[2024-09-29 16:29:01] Remapped 0 page(s)
[2024-09-29 16:29:01] [mem 0x09000000-0xffffffff] available for PCI devices
[2024-09-29 16:29:01] Booting paravirtualized kernel on Xen
[2024-09-29 16:29:01] Xen version: 4.17.4 (preserve-AD)
[2024-09-29 16:29:01] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[2024-09-29 16:29:01] Built 1 zonelists, mobility grouping on. Total pages: 36170
[2024-09-29 16:29:01] Kernel command line: clocksource=tsc
[2024-09-29 16:29:01] Dentry cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[2024-09-29 16:29:01] Inode-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[2024-09-29 16:29:01] mem auto-init: stack:byref_all(zero), heap alloc:off, heap free:off
[2024-09-29 16:29:01] Memory: 105660K/147068K available (6145K kernel code, 836K rwdata, 428K rodata, 708K init, 472K bss, 41156K reserved, 0K cma-reserved)
[2024-09-29 16:29:01] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[2024-09-29 16:29:01] Using NULL legacy PIC
[2024-09-29 16:29:01] NR_IRQS: 4352, nr_irqs: 24, preallocated irqs: 0
[2024-09-29 16:29:01] xen:events: Using FIFO-based ABI
[2024-09-29 16:29:01] random: crng init done
[2024-09-29 16:29:01] printk: console [hvc0] enabled
[2024-09-29 16:29:01] clocksource: xen: mask: 0xffffffffffffffff max_cycles: 0x1cd42e4dffb, max_idle_ns: 881590591483 ns
[2024-09-29 16:29:01] installing Xen timer for CPU 0
[2024-09-29 16:29:01] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x3f4dc4ceef5, max_idle_ns: 440795225486 ns
[2024-09-29 16:29:01] Calibrating delay loop (skipped), value calculated using timer frequency.. 8783.40 BogoMIPS (lpj=17566800)
[2024-09-29 16:29:01] Last level iTLB entries: 4KB 512, 2MB 512, 4MB 256
[2024-09-29 16:29:01] Last level dTLB entries: 4KB 3072, 2MB 3072, 4MB 1536, 1GB 0
[2024-09-29 16:29:01] CPU: AMD Ryzen 9 7900X3D 12-Core Processor (family: 0x19, model: 0x61, stepping: 0x2)
[2024-09-29 16:29:01] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[2024-09-29 16:29:01] Spectre V2 : Kernel not compiled with retpoline; no mitigation available!
[2024-09-29 16:29:01] Spectre V2 : Vulnerable
[2024-09-29 16:29:01] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[2024-09-29 16:29:01] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[2024-09-29 16:29:01] Speculative Store Bypass: Vulnerable
[2024-09-29 16:29:01] Speculative Return Stack Overflow: IBPB-extending microcode not applied!
[2024-09-29 16:29:01] Speculative Return Stack Overflow: WARNING: See https://kernel.org/doc/html/latest/admin-guide/hw-vuln/srso.html for mitigation options.
[2024-09-29 16:29:01] Speculative Return Stack Overflow: WARNING: kernel not compiled with CPU_SRSO.
[2024-09-29 16:29:01] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[2024-09-29 16:29:01] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[2024-09-29 16:29:01] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[2024-09-29 16:29:01] x86/fpu: Supporting XSAVE feature 0x020: 'AVX-512 opmask'
[2024-09-29 16:29:01] x86/fpu: Supporting XSAVE feature 0x040: 'AVX-512 Hi256'
[2024-09-29 16:29:01] x86/fpu: Supporting XSAVE feature 0x080: 'AVX-512 ZMM_Hi256'
[2024-09-29 16:29:01] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[2024-09-29 16:29:01] x86/fpu: xstate_offset[5]: 832, xstate_sizes[5]: 64
[2024-09-29 16:29:01] x86/fpu: xstate_offset[6]: 896, xstate_sizes[6]: 512
[2024-09-29 16:29:01] x86/fpu: xstate_offset[7]: 1408, xstate_sizes[7]: 1024
[2024-09-29 16:29:01] x86/fpu: Enabled xstate features 0xe7, context size is 2432 bytes, using 'standard' format.
[2024-09-29 16:29:01] pid_max: default: 4096 minimum: 301
[2024-09-29 16:29:01] Mount-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
[2024-09-29 16:29:01] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
[2024-09-29 16:29:01] Performance Events: PMU not available due to virtualization, using software events only.
[2024-09-29 16:29:01] devtmpfs: initialized
[2024-09-29 16:29:01] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[2024-09-29 16:29:01] futex hash table entries: 16 (order: -4, 384 bytes, linear)
[2024-09-29 16:29:01] NET: Registered protocol family 16
[2024-09-29 16:29:01] xen:grant_table: Grant tables using version 1 layout
[2024-09-29 16:29:01] Grant table initialized
[2024-09-29 16:29:01] PCI: setting up Xen PCI frontend stub
[2024-09-29 16:29:01] xen:balloon: Initialising balloon driver
[2024-09-29 16:29:01] PCI: System does not support PCI
[2024-09-29 16:29:01] clocksource: Switched to clocksource xen
[2024-09-29 16:29:01] NET: Registered protocol family 2
[2024-09-29 16:29:01] IP idents hash table entries: 4096 (order: 3, 32768 bytes, linear)
[2024-09-29 16:29:01] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
[2024-09-29 16:29:01] TCP established hash table entries: 2048 (order: 2, 16384 bytes, linear)
[2024-09-29 16:29:01] TCP bind hash table entries: 2048 (order: 2, 16384 bytes, linear)
[2024-09-29 16:29:01] TCP: Hash tables configured (established 2048 bind 2048)
[2024-09-29 16:29:01] UDP hash table entries: 128 (order: 0, 4096 bytes, linear)
[2024-09-29 16:29:01] UDP-Lite hash table entries: 128 (order: 0, 4096 bytes, linear)
[2024-09-29 16:29:01] Unpacking initramfs...
[2024-09-29 16:29:01] Freeing initrd memory: 23544K
[2024-09-29 16:29:01] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x3f4dc4ceef5, max_idle_ns: 440795225486 ns
[2024-09-29 16:29:01] clocksource: Switched to clocksource tsc
[2024-09-29 16:29:01] workingset: timestamp_bits=62 max_order=15 bucket_order=0
[2024-09-29 16:29:01] xen:xen_evtchn: Event-channel device installed
[2024-09-29 16:29:01] Invalid max_queues (4), will use default max: 1.
[2024-09-29 16:29:01] tun: Universal TUN/TAP device driver, 1.6
[2024-09-29 16:29:01] xen_netfront: Initialising Xen virtual ethernet driver
[2024-09-29 16:29:01] NET: Registered protocol family 17
[2024-09-29 16:29:01] sched_clock: Marking stable (66785648, 278214)->(68866560, -1802698)
[2024-09-29 16:29:01] pcifront pci-0: Installing PCI frontend
[2024-09-29 16:29:01] xen:swiotlb_xen: Warning: only able to allocate 4 MB for software IO TLB
[2024-09-29 16:29:01] software IO TLB: mapped [mem 0x0000000003000000-0x0000000003400000] (4MB)
[2024-09-29 16:29:01] pcifront pci-0: Creating PCI Frontend Bus 0000:00
[2024-09-29 16:29:01] pcifront pci-0: PCI host bridge to bus 0000:00
[2024-09-29 16:29:01] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[2024-09-29 16:29:01] pci_bus 0000:00: root bus resource [mem 0x00000000-0x3fffffffffff]
[2024-09-29 16:29:01] pci_bus 0000:00: root bus resource [bus 00-ff]
[2024-09-29 16:29:01] pci 0000:00:00.0: [10de:2203] type 00 class 0x030000
[2024-09-29 16:29:01] pci 0000:00:00.0: reg 0x10: [mem 0xfb000000-0xfbffffff]
[2024-09-29 16:29:01] pci 0000:00:00.0: reg 0x14: [mem 0xf000000000-0xf7ffffffff 64bit pref]
[2024-09-29 16:29:01] pci 0000:00:00.0: reg 0x1c: [mem 0xf800000000-0xf801ffffff 64bit pref]
[2024-09-29 16:29:01] pci 0000:00:00.0: reg 0x24: [io 0xf000-0xf07f]
[2024-09-29 16:29:01] pci 0000:00:00.0: reg 0x30: [mem 0xfc000000-0xfc07ffff pref]
[2024-09-29 16:29:01] pci 0000:00:00.1: [10de:1aef] type 00 class 0x040300
[2024-09-29 16:29:01] pci 0000:00:00.1: reg 0x10: [mem 0xfc080000-0xfc083fff]
[2024-09-29 16:29:01] pcifront pci-0: claiming resource 0000:00:00.0/0
[2024-09-29 16:29:01] pcifront pci-0: claiming resource 0000:00:00.0/1
[2024-09-29 16:29:01] pcifront pci-0: claiming resource 0000:00:00.0/3
[2024-09-29 16:29:01] pcifront pci-0: claiming resource 0000:00:00.0/5
[2024-09-29 16:29:01] pcifront pci-0: claiming resource 0000:00:00.0/6
[2024-09-29 16:29:01] pcifront pci-0: claiming resource 0000:00:00.1/0
[2024-09-29 16:29:01] xen_netfront: backend supports XDP headroom
[2024-09-29 16:29:01] vif vif-0: bouncing transmitted data to zeroed pages
[2024-09-29 16:29:01] blkfront: xvda: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
[2024-09-29 16:29:01] blkfront: xvdb: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
[2024-09-29 16:29:01] blkfront: xvdc: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
[2024-09-29 16:29:31] xenbus_probe_frontend: Waiting for devices to initialise: 25s...20s...15s...10s...5s...0s...
[2024-09-29 16:29:31] pcifront pci-0: Rescanning PCI Frontend Bus 0000:00
