I created a windows VM, did all the steps in the gaming HVM guide, and then try to passthrough the GPU, and this error comes up – I’ve also tried this in a non-manual way, using ‘qubes-install-windows-qube’, and it still gave the same error. I looked it up and I only found one result that fits what I’m running into and it was pretty far from my current setup. What should I try to do? I really miss gaming, it’s been so long.
And to state it so you guys know, I do have secondary gpu, and I do have another monitor attached to that second GPU, of which no other displays are attached to.
If after attaching GPU’s audio device to HVM it still doesn’t work, next step would be to do the strict reset (there’s a button for it, and select both devices in a window that button opens - sorry to be trivial, I don’t know anything about the level of your skills).
Alright. So where do I reset them? Also I think part of the issue may be I didn’t pci block the audio device (was I supposed to???) – that may be part of it, after sleeping on it.
I do know all of the PCI devices that my GPU has, I just didn’t pass all of them through – just the GPU itself. My bad. Let me go edit my grub and see if it makes it work. Ty.
added the devices to the hvm, and now it’s giving the error: “qrexec-daemon startup failed: 2023-12-29 15:12:41.637 qrexec-daem,on[8642]: qrexec-daemon.c:144:sigchld_parent_handler: Connection to the VM failed” whenever I try to boot up the Windows HVM
And it says this message -immediately- after booting up, then closes down. I did try the button you were talking about, the strict reset button – and I tried it on both pci devices, and still nothing.
