I’ve tried some of the fixes on the other threads and It’s still pretty slow.
Hardware should not be an issue. I’m on Qubes certified laptop with these specs
CPU: Ultra 7 155h
GPU: IGPU Meteor-Lake-P
RAM: 96GB
Qubes ver: R4.2.4
CPU: Ultra 7 155h
RAM: 96GB
Qubes ver: R4.2.4
What machine exactly? What BIOS?
Please post the output from dom0 terminal
cat /var/log/Xorg.0.log
If you haven’t rebootet for some time, please add
cat /var/log/Xorg.0.log | grep DRI
BIOS is dasharo coreboot +UEFI v0.9.0
[ 75.512] (II) Initializing extension DRI3
[ 75.512] (II) AIGLX: Screen 0 is not DRI2 capable
[ 75.519] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 75.520] (II) Initializing extension DRI2
xrandr
and
glxinfo | grep rendering
and
glxgears
(average frames in 5secs measured over 1min)
Screen 0: minimum 320 x 200, current 5120 x 2640, maximum 16384 x 16384
eDP-1 connected primary 1920x1200+350+1440 (normal left inverted right x axis y axis) 345mm x 215mm
1920x1200 165.00*+ 60.00 + 60.00
1920x1080 60.00
1600x1200 60.00
1680x1050 60.00
1400x1050 60.00
1600x900 60.00
1280x1024 60.00
1400x900 60.00
1280x960 60.00
1440x810 60.00
1368x768 60.00
1280x800 60.00
1152x864 60.00
1280x720 60.00
1024x768 60.00
1024x768i 60.00
960x720 60.00
928x696 60.00
896x672 60.00
1024x576 60.00
960x600 60.00
832x624 60.00
960x540 60.00
800x600 60.00
840x525 60.00
864x486 60.00
700x525 60.00
800x450 60.00
640x512 60.00
700x450 60.00
640x480 60.00
720x405 60.00
720x400 60.00
684x384 60.00
640x400 60.00
576x432 60.00
640x360 60.00
640x350 60.00
512x384 60.00
512x384i 60.00
512x288 60.00
416x312 60.00
480x270 60.00
400x300 60.00
432x243 60.00
320x240 60.00
360x202 60.00
360x200 60.00
320x200 60.00
320x180 60.00
320x175 60.00
DP-1 connected 2560x1440+2560+0 (normal left inverted right x axis y axis) 597mm x 336mm
3840x2160 30.00 25.00 24.00 29.97 23.98
2560x1440 59.95*
1920x1080 120.00 119.88 60.00 60.00 50.00 59.94
1280x720 60.00 50.00 59.94
1024x768 60.00
800x600 60.32
720x576 50.00
720x480 60.00 59.94
640x480 60.00 59.94
DP-2 disconnected (normal left inverted right x axis y axis)
HDMI-1 connected 2560x1440+0+0 (normal left inverted right x axis y axis) 697mm x 392mm
2560x1440 99.95*+ 74.97 59.95
3840x2160 60.00 50.00 59.94 30.00 25.00 24.00 29.97 23.98
1920x1080 120.00 119.88 74.99 60.00 60.00 50.00 59.94
1680x1050 59.88
1600x900 60.00
1280x1024 75.02 60.02
1280x800 59.91
1152x864 59.97
1024x768 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 60.00 59.94
640x480 75.00 60.00 59.94
DP-3 disconnected (normal left inverted right x axis y axis)
direct rendering: Yes
5910 frames in 5.0 seconds = 1181.818 FPS
6003 frames in 5.0 seconds = 1200.444 FPS
6100 frames in 5.0 seconds = 1219.848 FPS
6152 frames in 5.0 seconds = 1230.123 FPS
6069 frames in 5.0 seconds = 1213.673 FPS
The only thing, that puzzles me is the DRI2-Setting.
Please try two things (one at a time):
dom0 in the file /etc/X11/xorg.conf (please create that file if it doesn’t exist):Section "Device"
Identifier "Intel iGPU"
Driver "modesetting"
EndSection
Section "Module"
Load "glamoregl"
EndSection
→ Qubes-Menu → System Settings → Window Manager Tweaks → check “enable display compositor”
Sorry I’m newish to linux would I
touch /etc/X11/xorg.conf
then
nano /etc/X11/xorg.conf
and then copy/paste what you’ve written here.
also “enable display compositor” is already checked
Yes. As an alternative (it depends on versions/distributions and my system just detects things correctly) you could add /etc/X11/xorg.conf.d/20-intel.conf and add things there.
cool i do have have a “xorg.conf.d” dir so i’ll do that
done, what’s next
Reboot and please post the output from cat /var/log/Xorg.0.log (it’ll be a few lines) here.
If something hangs, press alt + f2 and log in with your normal account. You can then edit things from the console. (Typos are my favorite …)
failed to start lightdm.service
Im in the terminal what next?
sudo nano /etc/X11/xorg.conf.d/20-intel.conf and check the settings. If you are familiar with vi use it instead of nano since it implements some syntax highlighting. Check for misspelled quotation marks, double letters etc.
If all else fails, remove that intel-conf file. Qubes should start as before.
grep for iris and DRI – that should be enough.
[ 45.005] (II) Initializing extension DRI3
[ 45.005] (II) AIGLX: Screen 0 is not DRI2 capable
[ 45.013] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 45.013] (II) Initializing extension DRI2
grep for iris returned nothing
Bad. I know … it’s a bit tedious (but in case you don’t know, you can copy from dom0’s clipboard using the global clipboard in the taskbar). But could you get all the output from the last start, starting with the lines
X.Org X Server 1.20.14
X Protocol Version 11, Revision 0
[ 25.602] Build Operating System: 6.6.54-1.qubes.fc37.x86_64
[ 25.602] Current Operating System: Linux dom0 6.12.21-1.qubes.fc37.x86_64 #1 SMP PREEMPT_DYNAMIC Mon Mar 31 11:38:40 GMT 2025 x86_64
And just to clarify why we (most likely) need it: There’s an OpenGL setting in LibreOffice that is disabled by default. Enabling it drastically improved refresh times over here when dealing with letters with data fields and tabulars in Writer or some 3D drawing (rotation, lights, etc.) within Draw. Without the iris driver, I could throw 8 CPUs at the sh** and further prioritize dom0, but nothing “substantial” happened.
Edith says: Maybe it works for you already …
LibreOffice-App → Extras → Options → LibreOffice → Advanced → Open Expert Configuration → “search for: OpenGL” → Setting: org.openoffice.Office.common → VCL → Disable OpenGL → FALSE
[ 44.690] Build Operating System: 6.6.54-1.qubes.fc37.x86_64
[ 44.690] Current Operating System: Linux dom0 6.13.7-1.qubes.fc37.x86_64 #1 SMP PREEMPT_DYNAMIC Tue Mar 18 22:17:29 GMT 2025 x86_64
[ 44.690] Build Date: 08 December 2024 12:00:00AM
[ 44.690] Build ID: xorg-x11-server 1.20.14-27.fc37
[ 44.690] Current version of pixman: 0.40.0
[ 44.690] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 44.690] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 44.690] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Apr 24 17:58:02 2025
[ 44.692] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 44.692] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 44.694] (==) No Layout section. Using the first Screen section.
[ 44.694] (==) No screen section available. Using defaults.
[ 44.694] (**) |-->Screen "Default Screen Section" (0)
[ 44.694] (**) | |-->Monitor "<default monitor>"
[ 44.694] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 44.694] (**) | |-->Device "Intel iGPU"
[ 44.694] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 44.694] (==) Automatically adding devices
[ 44.694] (==) Automatically enabling devices
[ 44.694] (==) Automatically adding GPU devices
[ 44.694] (==) Automatically binding GPU devices
[ 44.694] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 44.694] (==) FontPath set to:
catalogue:/etc/X11/fontpath.d,
built-ins
[ 44.694] (==) ModulePath set to "/usr/lib64/xorg/modules"
[ 44.694] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 44.694] (II) Loader magic: 0x5fe9c80f6a40
[ 44.694] (II) Module ABI versions:
[ 44.694] X.Org ANSI C Emulation: 0.4
[ 44.694] X.Org Video Driver: 24.1
[ 44.694] X.Org XInput driver : 24.1
[ 44.694] X.Org Server Extension : 10.0
[ 44.695] (++) using VT number 1
[ 44.695] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 44.696] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 44.703] (--) PCI:*(0@0:2:0) 8086:7d55:8086:7d55 rev 8, Mem @ 0x98000000/16777216, 0x80000000/268435456, BIOS @ 0x????????/131072
[ 44.703] (II) "glx" will be loaded by default.
[ 44.703] (II) LoadModule: "glamoregl"
[ 44.704] (II) Loading /usr/lib64/xorg/modules/libglamoregl.so
[ 44.712] (II) Module glamoregl: vendor="X.Org Foundation"
[ 44.712] compiled for 1.20.14, module version = 1.0.1
[ 44.712] ABI class: X.Org ANSI C Emulation, version 0.4
[ 44.712] (II) LoadModule: "glx"
[ 44.712] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[ 44.723] (II) Module glx: vendor="X.Org Foundation"
[ 44.723] compiled for 1.20.14, module version = 1.0.0
[ 44.723] ABI class: X.Org Server Extension, version 10.0
[ 44.723] (II) LoadModule: "modesetting"
[ 44.723] (II) Loading /usr/lib64/xorg/modules/drivers/modesetting_drv.so
[ 44.724] (II) Module modesetting: vendor="X.Org Foundation"
[ 44.724] compiled for 1.20.14, module version = 1.20.14
[ 44.724] Module class: X.Org Video Driver
[ 44.724] ABI class: X.Org Video Driver, version 24.1
[ 44.724] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 44.725] (II) modeset(0): using drv /dev/dri/card0
[ 44.726] (II) modeset(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 44.726] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 44.726] (==) modeset(0): RGB weight 888
[ 44.726] (==) modeset(0): Default visual is TrueColor
[ 44.726] (II) Loading sub module "glamoregl"
[ 44.726] (II) LoadModule: "glamoregl"
[ 44.726] (II) Loading /usr/lib64/xorg/modules/libglamoregl.so
[ 44.726] (II) Module glamoregl: vendor="X.Org Foundation"
[ 44.726] compiled for 1.20.14, module version = 1.0.1
[ 44.726] ABI class: X.Org ANSI C Emulation, version 0.4
[ 44.943] (II) modeset(0): Refusing to try glamor on llvmpipe
[ 44.948] (EE) modeset(0): glamor initialization failed
[ 44.948] (II) modeset(0): ShadowFB: preferred YES, enabled YES
[ 44.948] (II) modeset(0): Double-buffered shadow updates: off
[ 44.953] (II) modeset(0): Output eDP-1 has no monitor section
[ 44.953] (II) modeset(0): Output DP-1 has no monitor section
[ 44.953] (II) modeset(0): Output DP-2 has no monitor section
[ 44.958] (II) modeset(0): Output HDMI-1 has no monitor section
[ 44.958] (II) modeset(0): Output DP-3 has no monitor section
[ 44.961] (II) modeset(0): EDID for output eDP-1
Sorry I wouldn’t be using qubes if i wasnt gonna read through the entire output to check if i wasnt positng something on the internet that ididnt want to be there lol
Seems like glamor failed to initialize
That’s a good thing. I don’t trust either.
The bad thing is: glamor is not initialized. (You were faster.) What gives xdriinfo?
