Lenovo Thinkstation P360 Ultra
Remarks
Ethernet works
Suspend works
Speaker works
The mouse, keyboard, and graphics experienced significant lag during and after the installation. However, after executing “sudo qubes-dom0-update kernel-latest” in dom0 terminal and setting the default kernel in the qubes global settings to 6.1.12-1.fc32 from 5.15.94-1.fc32, followed by a reboot, the system now runs smoothly without any lag.
Qubes-HCL-LENOVO-30G10046GE-20230405-124722.yml (792 Bytes)
Thank you @Hug1985 for your HCL report, which is online now!
Installation
  • Disable SecureBoot
Basic Input
  • Keyboard - works
  • External USB mouse - works
  • Touch-pad - device has no Touch-Pad
  • Display brightness change shortcuts, - no built-in display
  • Keyboard led and keyboard brightness change shortcuts, - no built-in keyboard
  • Output of xinput --list from terminal of dom0 - bash: xinput: command not found
Internet and bluetooth
  • Ethernet cable connection - works out of the box
  • Ethernet cable connection - N/A
  • Wifi connection - works out of the box
  • Wifi connection - speed, is reliable over the time? - Reliable
  • Bluetooth - works out of the box or actions were required? - unknown
  • Bluetooth - shows devices, connection process works, sound output or copying works. - unknown
Suspend
  • Suspend/Resume works - does not resume from suspend, hard reboot required. Adding mem_sleep_default=deep kernel option and updating the grub config file did not help. Changing from deep to s2idle got suspend/resume working (sudo bash -c “echo s2idle > /sys/power/mem_sleep”).
  • Does resume breaks WiFi, if it does, how to recover it? - No
  • Does resume breaks Bluetooth, if it does, how to recover it? - unknown
Video [increase VCPU to the qube before test]
  • Fullscreen and windowed video playback of youtube - 720p/1080p/2K/4K in Firefox. Does it drop frames? - works, both with dom0 and sys-audio
  • Video file playback of file using mpv/mplayer/smplayer - 1080p? Higher resolutions and bitrates? - untested
  • Multiple displays configuration works (using available DP/Thunderbolt, HDMI or other video ports, - unkown
Audio
  • Speakers (sound playback) (was sys-audio used?), - works with and without sys-audio
  • Head-phones via 3.5" jack (works, automatically turns off speakers?) - untested
  • Sound output via HDMI - untested
  • Audio-optical (S/PDIF) output - untested
Fans
  • Are fans silent on idle? - Yes
  • Are fans noisier than on Windows/Linux?. - No
Other
  • Have you tried running Windows 10 HVM qubes? - Yes, works
  • Does CPU boost seem to be working properly? - unknown
Specs:
  • Display native resolution, - 3440x1440
  • Maximum possible RAM memory, - 128GB
  • CPU score (from PassMark - CPU Comparison), - unknown
  • Number of USB Controllers - 1 USB Controller (assigned to sys-usb)
  • Internal TPM
    TPM Version 2.0 not yet supported
Qubes-HCL-LENOVO-30G10046GE-20240313-150341.yml (904 Bytes)
