layout:
'hcl'
type:
'mini pc'
hvm:
'yes'
iommu:
'yes'
slat:
'yes'
tpm:
'unknown'
remap:
'yes'
brand: |
LENOVO
model: |
30FACTO1WW
bios: |
M4GKT21A
cpu: |
12th Gen Intel(R) Core(TM) i5-12600
cpu-short: |
FIXME
chipset: |
Intel Corporation Device [8086:4650] (rev 05)
chipset-short: |
FIXME
gpu: |
Intel Corporation Device [8086:4690] (rev 0c) (prog-if 00 [VGA controller])
gpu-short: |
FIXME
network: |
Intel Corporation Device 7af0 (rev 11)
Intel Corporation Ethernet Connection (17) I219-LM (rev 11)
Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller (rev 05)
memory: |
32449
scsi: |
usb: |
1
versions:
- works:
'FIXME:yes|no|partial'
qubes: |
R4.1
xen: |
4.14.5
kernel: |
5.15.78-1
remark: |
FIXME
credit: |
FIXAUTHOR
link: |
FIXLINK
Remarks
Note that i5-12600 is a desktop processor. It only has P cores (no E cores unlike other versions) and it has Intel UHD Graphics 770 (instead of Intel Iris Xe Graphics that laptops have).
I do not have the optional dedicated GPU.
For reference, I believe this system is pretty much the same as “Lenovo ThinkCentre M70s Gen 3”
I have limited knowledge about Linux and it’s the first time that I try Qubes OS.
I’ve been able to try a couple of basic solutions, but I haven’t managed to make the graphics work smoothly.
Ethernet card
The onboard Intel Ethernet card I219-LM did not work after the fresh install. The following error appeared:
“Start failed: internal error: Unable to reset PCI device 0000:00:1f.6”
After that, a similar error appeared when trying to start sys-net and sys-firewall.
I found that the error referred to the onboard Intel Ethernet card.
I managed to disable the Intel Ethernet card following the instructions here:
echo -n “1” > /sys/bus/pci/devices/0000:00:1f.6/remove
Fortunately, the computer has an optional “Realtek RTL8125” that seemed to work after disabling the intel card, so I managed to use the Realtek card.
Once I had network connectivity, I managed to upgrade the kernel from 5.15.52-1.fc32 to 5.15.78-1.fc32
I think that the kernel upgrade enabled the wireless card (Intel AX211) because now I can see the available networks, but I have not tested its performance.
Graphics
During installation, the GUI was very slowly, although still usable (with a lot of patience).
After installation was completed, the graphics slowness problem persisted.
However, I have not seen any artifacts in the screen as other people reported in the past.
The kernel upgrade from 5.15.52-1.fc32 to 5.15.78-1.fc32 has not helped to solve the issue, and the slowness persists, making the system unusable for other things than troubleshooting.
Extract from lspci
00:02.0 VGA compatible controller [0300]: Intel Corporation Device [8086:4690] (rev 0c) (prog-if 00 [VGA controller])
DeviceName: Onboard - Video
Subsystem: Lenovo Device [17aa:330e]
Flags: bus master, fast devsel, latency 0, IRQ 255
Memory at 6000000000 (64-bit, non-prefetchable) [size=16M]
Memory at 4000000000 (64-bit, prefetchable) [size=256M]
I/O ports at 4000 [size=64]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Capabilities: [40] Vendor Specific Information: Len=0c <?>
Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [ac] MSI: Enable- Count=1/1 Maskable+ 64bit-
Capabilities: [d0] Power Management version 2
Capabilities: [100] Process Address Space ID (PASID)
Capabilities: [200] Address Translation Service (ATS)
Capabilities: [300] Page Request Interface (PRI)
Capabilities: [320] Single Root I/O Virtualization (SR-IOV)
Kernel modules: i915
00:14.3 Network controller [0280]: Intel Corporation Device [8086:7af0] (rev 11)
DeviceName: Onboard - Ethernet
Subsystem: Intel Corporation Device [8086:0090]
Flags: bus master, fast devsel, latency 0, IRQ 18
Memory at 600113c000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [c8] Power Management version 3
Capabilities: [d0] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [40] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [80] MSI-X: Enable- Count=16 Masked-
Capabilities: [100] Latency Tolerance Reporting
Capabilities: [164] Vendor Specific Information: ID=0010 Rev=0 Len=014 <?>
Kernel driver in use: pciback
Kernel modules: iwlwifi
00:1f.6 Ethernet controller [0200]: Intel Corporation Ethernet Connection (17) I219-LM [8086:1a1c] (rev 11)
Flags: fast devsel, IRQ 17
Memory at 4fa00000 (32-bit, non-prefetchable) [size=128K]
Capabilities: [d0] MSI: Enable- Count=1/1 Maskable- 64bit+
Kernel modules: e1000e
02:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller [10ec:8125] (rev 05)
Subsystem: Bitland(ShenZhen) Information Technology Co., Ltd. Device [1642:8189]
Flags: bus master, fast devsel, latency 0, IRQ 17
I/O ports at 3000 [size=256]
Memory at 4f800000 (64-bit, non-prefetchable) [size=64K]
Memory at 4f810000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable+ Count=1/1 Maskable+ 64bit+
Capabilities: [70] Express Endpoint, MSI 01
Capabilities: [b0] MSI-X: Enable- Count=32 Masked-
Capabilities: [d0] Vital Product Data
Capabilities: [100] Advanced Error Reporting
Capabilities: [148] Virtual Channel
Capabilities: [168] Device Serial Number **
Capabilities: [178] Transaction Processing Hints
Capabilities: [204] Latency Tolerance Reporting
Capabilities: [20c] L1 PM Substates
Capabilities: [21c] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>
Kernel modules: r8169
- Qubes-HCL-LENOVO-30FACTO1WW-20221210-164000.yml (836 Bytes)
