everything is fine except it dose not detect my TPM 2 (i used an arch USB to see if it detects it and it works fine so it seems to be a Qubes specific issue), other than that my dedicated GPU wont work but I’ve always had that issue with Linux on this laptop so that’s nothing new
but there no blueman service by default
and even if you have blueman, everything is limited in the vm you attach to (or sys-net if you use wifi+bluetooth card)
