LattePanda IOTA + QubeOS?
Does anyone tested LattePanda IOTA with QubeOS? Plus ODROID H3 / H3+, and LattePanda-Sigm?
Qubes OS only works on x86 hardware, I’m not familiar with all these boards but I assume they use arm64 architecture. This is not possible at all as Xen is not compatible with them.
I asked ChatGPT said it is possible can work.
They are all X86 boards, so it could work. How well is another question though. SBCs generally are less powerful than standard computers, so performance will likely be poor. They all also seem to be using weak processors, and I don’t know if they support the virtualization features that qubes requires.
I wish the possibilities as small board can handle QubeOS.
