Oh brilliant. Then you’ll know what happens if you view things on too macro a level
Those skills will serve you well once you understand how the internet truly works (you’ll know that you fully understand it because you’ll be absolutely horrified by it).
These will help get you started:
These are easy to understand, and are actually really good at explaining the concepts.
No, it doesn’t. But you asked about wireless.
At least you’re now versed on wireless threats
Basically, the rule of thumb is cables wherever possible. When a wireless antenna transmits anything, it basically screams it out at full-volume in all directions simultaneously. Yes, it is possible to send “directional” signals, but that still isn’t something that is standard across the majority of devices yet.
The thing that makes wireless communication “secure” is making sure that whatever you’re screaming out can’t be understood by anyone else except the intended recipient.
Mind you, if you don’t own/control 100% of the cables you’re using to communicate (work networks, a VPN, public networks like the internet, etc.), then the same principle applies.
Encryption, encryption, encryption
You’ll need to go deeper than “use securely” in order to get the answers you seek…
Secure against what?
The most secure laptop is one that has no electricity running through it. Fun fact: It’s also the least usable laptop in the world. So you need to find your own sweet spot somewhere in the middle, based on what you’re prepared to accept.
That’s OpSec in a nutshell
No. That’s both the greatest strength and greatest weakness of the Universal Serial Bus (USB). Only one port/plug type, but that port/plug can be ANYTHING. Also, USB doesn’t do any kind of “verification” of what a device actually is, and what a device is and what the device declares itself to the computer as. The computer will just accept whatever the device says at face value.
It has to do that for USB to actually function properly…
Because of this, there is a market for tools such as this:
If you don’t wish to click on the link, you can search “USB Rubber Ducky” or “BadUSB” on your favourite internet search engine.
So, can I remove drivers for all USB devices except keyboards and mice?
You could, but if I got into your machine, the first thing I would tell it to do would be to put all those drivers back (you know, after stealing your private keys, loading monero miners, and adding you to my botnet
Will it be “more secure”?
Stop throwing that term around like it means something
Is there a way to exploit it?
Well, if your computer will accept keystrokes, I could send keystrokes that open a terminal, install drivers, and get your USB qube to do things without your knowledge (assuming your computer blindly accepts anything coming from that USB device, which it would by default. Qubes OS is different, and that difference is explained below).
Because USB is one-size-fits-all, and is a convenience port. I’m glad it exists, but it also has its drawbacks.
If you funnel all passengers at an airport through one entrance, what about the celebrities and VIPs? What about the airport staff? How do you tell them apart?
No, you can’t issue a standardised “VIP Identity Card”. Besides, even if you did, half of them would leave that card at home and be like “Don’t you know who I am? I swear, you’ll never work in this industry again if you don’t let me in!”, etc etc.
Because of this, it’s the path of least resistance to just take their word for it. USB is somewhat similar.
Do you see how you’re kind of going in circles chasing your tail?
On the default intended configuration, Qubes OS will alert you with a big dialog box if it detects a HID (Human Interface Device), and will then ask you whether you want it accept input from it. You can then decide whether you want to or not.
For example, if you plugged in a device that you thought was a flash drive, and then that dialog box showed up, you probably wouldn’t want that device plugged into your computer pretending to be a keyboard.
If you trust the device (for example, a keyboard you built yourself and wrote the firmware yourself for), then you’d likely be alright accepting that device.
