Nothing that I’m able to spot…
May 28 19:29:07 dom0 systemd[1]: systemd-hostnamed.service: Deactivated successfully.
May 28 19:29:07 dom0 kernel: audit: type=1131 audit(1716917347.070:525): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 28 19:29:07 dom0 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 28 19:29:07 dom0 audit: BPF prog-id=74 op=UNLOAD
May 28 19:29:07 dom0 audit: BPF prog-id=73 op=UNLOAD
May 28 19:29:07 dom0 audit: BPF prog-id=72 op=UNLOAD
May 28 19:29:07 dom0 kernel: audit: type=1334 audit(1716917347.104:526): prog-id=74 op=UNLOAD
May 28 19:29:07 dom0 kernel: audit: type=1334 audit(1716917347.104:527): prog-id=73 op=UNLOAD
May 28 19:29:07 dom0 kernel: audit: type=1334 audit(1716917347.104:528): prog-id=72 op=UNLOAD
May 28 19:29:22 dom0 qubesd[2957]: vm.sys-usb: Starting sys-usb
May 28 19:29:22 dom0 audit[2930]: USER_DEVICE pid=2930 uid=0 auid=4294967295 ses=4294967295 msg='op="removed-device" device="/devices/pci0000:00/0000:00:08.1/0000:c1:00.3/usb2/2-2" device_rule=616C6C6F7720696420303565333A30363235206E616D652022555342332E322048756222207669612D706F72742022322D322220776974682D696E746572666163652030393A30303A303020776974682D636F6E6E6563742D74797065202268617264776972656422 exe="/usr/sbin/usbguard-daemon" hostname=? addr=? terminal=? res=success'
May 28 19:29:22 dom0 kernel: xhci_hcd 0000:c1:00.3: remove, state 4
May 28 19:29:22 dom0 kernel: usb usb2: USB disconnect, device number 1
May 28 19:29:22 dom0 kernel: usb 2-2: USB disconnect, device number 2
May 28 19:29:22 dom0 kernel: audit: type=1137 audit(1716917362.591:529): pid=2930 uid=0 auid=4294967295 ses=4294967295 msg='op="removed-device" device="/devices/pci0000:00/0000:00:08.1/0000:c1:00.3/usb2/2-2" device_rule=616C6C6F7720696420303565333A30363235206E616D652022555342332E322048756222207669612D706F72742022322D322220776974682D696E746572666163652030393A30303A303020776974682D636F6E6E6563742D74797065202268617264776972656422 exe="/usr/sbin/usbguard-daemon" hostname=? addr=? terminal=? res=success'
May 28 19:29:22 dom0 audit[2930]: USER_DEVICE pid=2930 uid=0 auid=4294967295 ses=4294967295 msg='op="removed-device" device="/devices/pci0000:00/0000:00:08.1/0000:c1:00.3/usb2" device_rule=616C6C6F7720696420316436623A30303033206E616D6520227848434920486F737420436F6E74726F6C6C657222207669612D706F72742022757362322220776974682D696E746572666163652030393A30303A303020776974682D636F6E6E6563742D74797065202222 exe="/usr/sbin/usbguard-daemon" hostname=? addr=? terminal=? res=success'
May 28 19:29:22 dom0 kernel: xhci_hcd 0000:c1:00.3: USB bus 2 deregistered
May 28 19:29:22 dom0 kernel: audit: type=1137 audit(1716917362.595:530): pid=2930 uid=0 auid=4294967295 ses=4294967295 msg='op="removed-device" device="/devices/pci0000:00/0000:00:08.1/0000:c1:00.3/usb2" device_rule=616C6C6F7720696420316436623A30303033206E616D6520227848434920486F737420436F6E74726F6C6C657222207669612D706F72742022757362322220776974682D696E746572666163652030393A30303A303020776974682D636F6E6E6563742D74797065202222 exe="/usr/sbin/usbguard-daemon" hostname=? addr=? terminal=? res=success'
May 28 19:29:22 dom0 kernel: xhci_hcd 0000:c1:00.3: remove, state 1
May 28 19:29:22 dom0 kernel: usb usb1: USB disconnect, device number 1
May 28 19:29:22 dom0 kernel: usb 1-1: USB disconnect, device number 2
May 28 19:29:22 dom0 kernel: usb 1-2: USB disconnect, device number 3
May 28 19:29:22 dom0 kernel: audit: type=1137 audit(1716917362.596:531): pid=2930 uid=0 auid=4294967295 ses=4294967295 msg='op="removed-device" device="/devices/pci0000:00/0000:00:08.1/0000:c1:00.3/usb1/1-1" device_rule=626C6F636B20696420333261633A30303033206E616D652022446973706C6179506F727420457870616E73696F6E204361726422207669612D706F72742022312D312220776974682D696E74657266616365207B2031313A30303A30302030333A30303A3030207D20776974682D636F6E6E6563742D747970652022686F74706C756722 exe="/usr/sbin/usbguard-daemon" hostname=? addr=? terminal=? res=success'
May 28 19:29:22 dom0 kernel: audit: type=1137 audit(1716917362.596:532): pid=2930 uid=0 auid=4294967295 ses=4294967295 msg='op="removed-device" device="/devices/pci0000:00/0000:00:08.1/0000:c1:00.3/usb1/1-2" device_rule=616C6C6F7720696420303565333A30363130206E616D652022555342322E312048756222207669612D706F72742022312D322220776974682D696E74657266616365207B2030393A30303A30312030393A30303A3032207D20776974682D636F6E6E6563742D74797065202268617264776972656422 exe="/usr/sbin/usbguard-daemon" hostname=? addr=? terminal=? res=success'
May 28 19:29:22 dom0 audit[2930]: USER_DEVICE pid=2930 uid=0 auid=4294967295 ses=4294967295 msg='op="removed-device" device="/devices/pci0000:00/0000:00:08.1/0000:c1:00.3/usb1/1-1" device_rule=626C6F636B20696420333261633A30303033206E616D652022446973706C6179506F727420457870616E73696F6E204361726422207669612D706F72742022312D312220776974682D696E74657266616365207B2031313A30303A30302030333A30303A3030207D20776974682D636F6E6E6563742D747970652022686F74706C756722 exe="/usr/sbin/usbguard-daemon" hostname=? addr=? terminal=? res=success'
May 28 19:29:22 dom0 audit[2930]: USER_DEVICE pid=2930 uid=0 auid=4294967295 ses=4294967295 msg='op="removed-device" device="/devices/pci0000:00/0000:00:08.1/0000:c1:00.3/usb1/1-2" device_rule=616C6C6F7720696420303565333A30363130206E616D652022555342322E312048756222207669612D706F72742022312D322220776974682D696E74657266616365207B2030393A30303A30312030393A30303A3032207D20776974682D636F6E6E6563742D74797065202268617264776972656422 exe="/usr/sbin/usbguard-daemon" hostname=? addr=? terminal=? res=success'
May 28 19:29:22 dom0 kernel: usb 1-3: USB disconnect, device number 4
May 28 19:29:22 dom0 kernel: usb 1-3.2: USB disconnect, device number 7
May 28 19:29:23 dom0 kernel: audit: type=1137 audit(1716917363.072:533): pid=2930 uid=0 auid=4294967295 ses=4294967295 msg='op="removed-device" device="/devices/pci0000:00/0000:00:08.1/0000:c1:00.3/usb1/1-3/1-3.2" device_rule=616C6C6F7720696420333261633A30303134206E616D6520224C6170746F70203136204E756D706164204D6F64756C6522207669612D706F72742022312D332E322220776974682D696E74657266616365207B2030333A30313A30312030333A30303A30302030333A30303A30302030333A30303A3030207D20776974682D636F6E6E6563742D7479706520226E6F74207573656422 exe="/usr/sbin/usbguard-daemon" hostname=? addr=? terminal=? res=success'
May 28 19:29:23 dom0 audit[2930]: USER_DEVICE pid=2930 uid=0 auid=4294967295 ses=4294967295 msg='op="removed-device" device="/devices/pci0000:00/0000:00:08.1/0000:c1:00.3/usb1/1-3/1-3.2" device_rule=616C6C6F7720696420333261633A30303134206E616D6520224C6170746F70203136204E756D706164204D6F64756C6522207669612D706F72742022312D332E322220776974682D696E74657266616365207B2030333A30313A30312030333A30303A30302030333A30303A30302030333A30303A3030207D20776974682D636F6E6E6563742D7479706520226E6F74207573656422 exe="/usr/sbin/usbguard-daemon" hostname=? addr=? terminal=? res=success'
May 28 19:29:23 dom0 audit[2930]: USER_DEVICE pid=2930 uid=0 auid=4294967295 ses=4294967295 msg='op="removed-device" device="/devices/pci0000:00/0000:00:08.1/0000:c1:00.3/usb1/1-3" device_rule=616C6C6F7720696420303565333A30363130206E616D652022555342322E302048756222207669612D706F72742022312D332220776974682D696E74657266616365207B2030393A30303A30312030393A30303A3032207D20776974682D636F6E6E6563742D74797065202268617264776972656422 exe="/usr/sbin/usbguard-daemon" hostname=? addr=? terminal=? res=success'
May 28 19:29:23 dom0 kernel: audit: type=1137 audit(1716917363.092:534): pid=2930 uid=0 auid=4294967295 ses=4294967295 msg='op="removed-device" device="/devices/pci0000:00/0000:00:08.1/0000:c1:00.3/usb1/1-3" device_rule=616C6C6F7720696420303565333A30363130206E616D652022555342322E302048756222207669612D706F72742022312D332220776974682D696E74657266616365207B2030393A30303A30312030393A30303A3032207D20776974682D636F6E6E6563742D74797065202268617264776972656422 exe="/usr/sbin/usbguard-daemon" hostname=? addr=? terminal=? res=success'
May 28 19:29:23 dom0 kernel: usb 1-4: USB disconnect, device number 5
May 28 19:29:23 dom0 kernel: usb 1-4.1: USB disconnect, device number 8
May 28 19:29:23 dom0 kernel: usb 1-4.2: USB disconnect, device number 9
May 28 19:29:23 dom0 kernel: audit: type=1137 audit(1716917363.124:535): pid=2930 uid=0 auid=4294967295 ses=4294967295 msg='op="removed-device" device="/devices/pci0000:00/0000:00:08.1/0000:c1:00.3/usb1/1-4/1-4.1" device_rule=626C6F636B20696420323763363A36303963206E616D652022476F6F64697820555342322E30204D49534322207669612D706F72742022312D342E312220776974682D696E746572666163652066663A30303A303020776974682D636F6E6E6563742D7479706520226E6F74207573656422 exe="/usr/sbin/usbguard-daemon" hostname=? addr=? terminal=? res=success'
May 28 19:29:23 dom0 audit[2930]: USER_DEVICE pid=2930 uid=0 auid=4294967295 ses=4294967295 msg='op="removed-device" device="/devices/pci0000:00/0000:00:08.1/0000:c1:00.3/usb1/1-4/1-4.1" device_rule=626C6F636B20696420323763363A36303963206E616D652022476F6F64697820555342322E30204D49534322207669612D706F72742022312D342E312220776974682D696E746572666163652066663A30303A303020776974682D636F6E6E6563742D7479706520226E6F74207573656422 exe="/usr/sbin/usbguard-daemon" hostname=? addr=? terminal=? res=success'
May 28 19:29:23 dom0 audit[2930]: USER_DEVICE pid=2930 uid=0 auid=4294967295 ses=4294967295 msg='op="removed-device" device="/devices/pci0000:00/0000:00:08.1/0000:c1:00.3/usb1/1-4/1-4.2" device_rule=616C6C6F7720696420333261633A30303138206E616D6520224C6170746F70203136204B6579626F617264204D6F64756C65202D2049534F22207669612D706F72742022312D342E322220776974682D696E74657266616365207B2030333A30313A30312030333A30303A30302030333A30303A30302030333A30303A3030207D20776974682D636F6E6E6563742D7479706520226E6F74207573656422 exe="/usr/sbin/usbguard-daemon" hostname=? addr=? terminal=? res=success'
May 28 19:29:23 dom0 kernel: audit: type=1137 audit(1716917363.571:536): pid=2930 uid=0 auid=4294967295 ses=4294967295 msg='op="removed-device" device="/devices/pci0000:00/0000:00:08.1/0000:c1:00.3/usb1/1-4/1-4.2" device_rule=616C6C6F7720696420333261633A30303138206E616D6520224C6170746F70203136204B6579626F617264204D6F64756C65202D2049534F22207669612D706F72742022312D342E322220776974682D696E74657266616365207B2030333A30313A30312030333A30303A30302030333A30303A30302030333A30303A3030207D20776974682D636F6E6E6563742D7479706520226E6F74207573656422 exe="/usr/sbin/usbguard-daemon" hostname=? addr=? terminal=? res=success'
May 28 19:29:23 dom0 audit[2930]: USER_DEVICE pid=2930 uid=0 auid=4294967295 ses=4294967295 msg='op="removed-device" device="/devices/pci0000:00/0000:00:08.1/0000:c1:00.3/usb1/1-4" device_rule=616C6C6F7720696420303565333A30363130206E616D652022555342322E302048756222207669612D706F72742022312D342220776974682D696E74657266616365207B2030393A30303A30312030393A30303A3032207D20776974682D636F6E6E6563742D74797065202268617264776972656422 exe="/usr/sbin/usbguard-daemon" hostname=? addr=? terminal=? res=success'
May 28 19:29:23 dom0 kernel: audit: type=1137 audit(1716917363.604:537): pid=2930 uid=0 auid=4294967295 ses=4294967295 msg='op="removed-device" device="/devices/pci0000:00/0000:00:08.1/0000:c1:00.3/usb1/1-4" device_rule=616C6C6F7720696420303565333A30363130206E616D652022555342322E302048756222207669612D706F72742022312D342220776974682D696E74657266616365207B2030393A30303A30312030393A30303A3032207D20776974682D636F6E6E6563742D74797065202268617264776972656422 exe="/usr/sbin/usbguard-daemon" hostname=? addr=? terminal=? res=success'
May 28 19:29:23 dom0 kernel: usb 1-5: USB disconnect, device number 6
May 28 19:29:23 dom0 audit[2930]: USER_DEVICE pid=2930 uid=0 auid=4294967295 ses=4294967295 msg='op="removed-device" device="/devices/pci0000:00/0000:00:08.1/0000:c1:00.3/usb1/1-5" device_rule=626C6F636B20696420306538643A65363136206E616D652022576972656C6573735F44657669636522207669612D706F72742022312D352220776974682D696E74657266616365207B2065303A30313A30312065303A30313A30312065303A30313A30312065303A30313A30312065303A30313A30312065303A30313A30312065303A30313A30312065303A30313A30312065303A30313A30312065303A30313A3031207D20776974682D636F6E6E6563742D74797065202268617264776972656422 exe="/usr/sbin/usbguard-daemon" hostname=? addr=? terminal=? res=success'
May 28 19:29:23 dom0 audit[2930]: USER_DEVICE pid=2930 uid=0 auid=4294967295 ses=4294967295 msg='op="removed-device" device="/devices/pci0000:00/0000:00:08.1/0000:c1:00.3/usb1" device_rule=616C6C6F7720696420316436623A30303032206E616D6520227848434920486F737420436F6E74726F6C6C657222207669612D706F72742022757362312220776974682D696E746572666163652030393A30303A303020776974682D636F6E6E6563742D74797065202222 exe="/usr/sbin/usbguard-daemon" hostname=? addr=? terminal=? res=success'
May 28 19:29:23 dom0 kernel: audit: type=1137 audit(1716917363.636:538): pid=2930 uid=0 auid=4294967295 ses=4294967295 msg='op="removed-device" device="/devices/pci0000:00/0000:00:08.1/0000:c1:00.3/usb1/1-5" device_rule=626C6F636B20696420306538643A65363136206E616D652022576972656C6573735F44657669636522207669612D706F72742022312D352220776974682D696E74657266616365207B2065303A30313A30312065303A30313A30312065303A30313A30312065303A30313A30312065303A30313A30312065303A30313A30312065303A30313A30312065303A30313A30312065303A30313A30312065303A30313A3031207D20776974682D636F6E6E6563742D74797065202268617264776972656422 exe="/usr/sbin/usbguard-daemon" hostname=? addr=? terminal=? res=success'
May 28 19:29:23 dom0 kernel: xhci_hcd 0000:c1:00.3: USB bus 1 deregistered
May 28 19:29:23 dom0 kernel: pciback 0000:c1:00.3: xen_pciback: seizing device
May 28 19:29:23 dom0 kernel: xen: registering gsi 37 triggering 0 polarity 1
May 28 19:29:23 dom0 kernel: Already setup the GSI :37
May 28 19:29:23 dom0 audit[2930]: USER_DEVICE pid=2930 uid=0 auid=4294967295 ses=4294967295 msg='op="removed-device" device="/devices/pci0000:00/0000:00:08.1/0000:c1:00.4/usb4" device_rule=616C6C6F7720696420316436623A30303033206E616D6520227848434920486F737420436F6E74726F6C6C657222207669612D706F72742022757362342220776974682D696E746572666163652030393A30303A303020776974682D636F6E6E6563742D74797065202222 exe="/usr/sbin/usbguard-daemon" hostname=? addr=? terminal=? res=success'
May 28 19:29:23 dom0 kernel: xhci_hcd 0000:c1:00.4: remove, state 4
May 28 19:29:23 dom0 kernel: usb usb4: USB disconnect, device number 1
May 28 19:29:23 dom0 kernel: xhci_hcd 0000:c1:00.4: USB bus 4 deregistered
May 28 19:29:23 dom0 kernel: xhci_hcd 0000:c1:00.4: remove, state 1
May 28 19:29:23 dom0 kernel: usb usb3: USB disconnect, device number 1
May 28 19:29:23 dom0 kernel: usb 3-1: USB disconnect, device number 2
May 28 19:29:23 dom0 kernel: xhci_hcd 0000:c1:00.4: USB bus 3 deregistered
May 28 19:29:23 dom0 audit[2930]: USER_DEVICE pid=2930 uid=0 auid=4294967295 ses=4294967295 msg='op="removed-device" device="/devices/pci0000:00/0000:00:08.1/0000:c1:00.4/usb3/3-1" device_rule=626C6F636B20696420306264613A35363334206E616D6520224C6170746F702043616D65726122207669612D706F72742022332D312220776974682D696E74657266616365207B2030653A30313A30302030653A30323A30302030653A30323A30302030653A30323A30302030653A30323A30302030653A30323A30302030653A30323A30302030653A30323A30302030653A30323A3030207D20776974682D636F6E6E6563742D74797065202268617264776972656422 exe="/usr/sbin/usbguard-daemon" hostname=? addr=? terminal=? res=success'
May 28 19:29:23 dom0 audit[2930]: USER_DEVICE pid=2930 uid=0 auid=4294967295 ses=4294967295 msg='op="removed-device" device="/devices/pci0000:00/0000:00:08.1/0000:c1:00.4/usb3" device_rule=616C6C6F7720696420316436623A30303032206E616D6520227848434920486F737420436F6E74726F6C6C657222207669612D706F72742022757362332220776974682D696E746572666163652030393A30303A303020776974682D636F6E6E6563742D74797065202222 exe="/usr/sbin/usbguard-daemon" hostname=? addr=? terminal=? res=success'
May 28 19:29:23 dom0 kernel: pciback 0000:c1:00.4: xen_pciback: seizing device
May 28 19:29:23 dom0 kernel: xen: registering gsi 38 triggering 0 polarity 1
May 28 19:29:23 dom0 kernel: Already setup the GSI :38
May 28 19:29:23 dom0 audit[2930]: USER_DEVICE pid=2930 uid=0 auid=4294967295 ses=4294967295 msg='op="removed-device" device="/devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb6" device_rule=616C6C6F7720696420316436623A30303033206E616D6520227848434920486F737420436F6E74726F6C6C657222207669612D706F72742022757362362220776974682D696E746572666163652030393A30303A303020776974682D636F6E6E6563742D74797065202222 exe="/usr/sbin/usbguard-daemon" hostname=? addr=? terminal=? res=success'
May 28 19:29:23 dom0 kernel: xhci_hcd 0000:c3:00.3: remove, state 4
May 28 19:29:23 dom0 kernel: usb usb6: USB disconnect, device number 1
May 28 19:29:23 dom0 kernel: xhci_hcd 0000:c3:00.3: USB bus 6 deregistered
May 28 19:29:23 dom0 kernel: xhci_hcd 0000:c3:00.3: remove, state 1
May 28 19:29:23 dom0 kernel: usb usb5: USB disconnect, device number 1
May 28 19:29:23 dom0 kernel: usb 5-1: USB disconnect, device number 2
May 28 19:29:23 dom0 kernel: xhci_hcd 0000:c3:00.3: USB bus 5 deregistered
May 28 19:29:23 dom0 kernel: pciback 0000:c3:00.3: xen_pciback: seizing device
May 28 19:29:23 dom0 kernel: xen: registering gsi 46 triggering 0 polarity 1
May 28 19:29:23 dom0 kernel: Already setup the GSI :46
May 28 19:29:23 dom0 audit[2930]: USER_DEVICE pid=2930 uid=0 auid=4294967295 ses=4294967295 msg='op="removed-device" device="/devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb5/5-1" device_rule=626C6F636B20696420333261633A30303033206E616D652022446973706C6179506F727420457870616E73696F6E204361726422207669612D706F72742022352D312220776974682D696E74657266616365207B2031313A30303A30302030333A30303A3030207D20776974682D636F6E6E6563742D747970652022686F74706C756722 exe="/usr/sbin/usbguard-daemon" hostname=? addr=? terminal=? res=success'
May 28 19:29:23 dom0 audit[2930]: USER_DEVICE pid=2930 uid=0 auid=4294967295 ses=4294967295 msg='op="removed-device" device="/devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb5" device_rule=616C6C6F7720696420316436623A30303032206E616D6520227848434920486F737420436F6E74726F6C6C657222207669612D706F72742022757362352220776974682D696E746572666163652030393A30303A303020776974682D636F6E6E6563742D74797065202222 exe="/usr/sbin/usbguard-daemon" hostname=? addr=? terminal=? res=success'
May 28 19:29:23 dom0 kernel: xhci_hcd 0000:c3:00.4: remove, state 4
May 28 19:29:23 dom0 kernel: usb usb8: USB disconnect, device number 1
May 28 19:29:23 dom0 kernel: xhci_hcd 0000:c3:00.4: USB bus 8 deregistered
May 28 19:29:23 dom0 audit[2930]: USER_DEVICE pid=2930 uid=0 auid=4294967295 ses=4294967295 msg='op="removed-device" device="/devices/pci0000:00/0000:00:08.3/0000:c3:00.4/usb8" device_rule=616C6C6F7720696420316436623A30303033206E616D6520227848434920486F737420436F6E74726F6C6C657222207669612D706F72742022757362382220776974682D696E746572666163652030393A30303A303020776974682D636F6E6E6563742D74797065202222 exe="/usr/sbin/usbguard-daemon" hostname=? addr=? terminal=? res=success'
May 28 19:29:23 dom0 kernel: usb usb7: USB disconnect, device number 1
May 28 19:29:23 dom0 kernel: xhci_hcd 0000:c3:00.4: USB bus 7 deregistered
May 28 19:29:23 dom0 kernel: pciback 0000:c3:00.4: xen_pciback: seizing device
May 28 19:29:23 dom0 kernel: xen: registering gsi 47 triggering 0 polarity 1
May 28 19:29:23 dom0 kernel: Already setup the GSI :47
May 28 19:29:23 dom0 audit[2930]: USER_DEVICE pid=2930 uid=0 auid=4294967295 ses=4294967295 msg='op="removed-device" device="/devices/pci0000:00/0000:00:08.3/0000:c3:00.4/usb7" device_rule=616C6C6F7720696420316436623A30303032206E616D6520227848434920486F737420436F6E74726F6C6C657222207669612D706F72742022757362372220776974682D696E746572666163652030393A30303A303020776974682D636F6E6E6563742D74797065202222 exe="/usr/sbin/usbguard-daemon" hostname=? addr=? terminal=? res=success'
May 28 19:29:23 dom0 kernel: pciback 0000:c3:00.5: xen_pciback: seizing device
May 28 19:29:23 dom0 kernel: xen: registering gsi 44 triggering 0 polarity 1
May 28 19:29:23 dom0 kernel: Already setup the GSI :44
May 28 19:29:23 dom0 kernel: pciback 0000:c3:00.6: xen_pciback: seizing device
May 28 19:29:23 dom0 kernel: xen: registering gsi 45 triggering 0 polarity 1
May 28 19:29:23 dom0 kernel: Already setup the GSI :45
May 28 19:29:24 dom0 lvm[2177]: No longer monitoring thin pool qubes_dom0-vm--pool-tpool.
May 28 19:29:24 dom0 lvm[2177]: Monitoring thin pool qubes_dom0-vm--pool-tpool.
May 28 19:29:24 dom0 kernel: pciback 0000:c3:00.3: xen_pciback: seizing device
May 28 19:29:24 dom0 kernel: xen: registering gsi 46 triggering 0 polarity 1
May 28 19:29:24 dom0 kernel: Already setup the GSI :46
May 28 19:29:24 dom0 kernel: pciback 0000:c3:00.4: xen_pciback: seizing device
May 28 19:29:24 dom0 kernel: xen: registering gsi 47 triggering 0 polarity 1
May 28 19:29:24 dom0 kernel: Already setup the GSI :47
May 28 19:29:24 dom0 kernel: loop4: detected capacity change from 0 to 1244600
May 28 19:29:25 dom0 kernel: loop5: detected capacity change from 0 to 1244600
May 28 19:29:25 dom0 kernel: pciback 0000:c1:00.3: xen_pciback: vpci: assign to virtual slot 0
May 28 19:29:25 dom0 kernel: pciback 0000:c1:00.3: registering for 6
May 28 19:29:25 dom0 kernel: pciback 0000:c1:00.4: xen_pciback: vpci: assign to virtual slot 0 func 4
May 28 19:29:25 dom0 kernel: pciback 0000:c1:00.4: registering for 6
May 28 19:29:25 dom0 kernel: pciback 0000:c3:00.3: xen_pciback: vpci: assign to virtual slot 1
May 28 19:29:25 dom0 kernel: pciback 0000:c3:00.3: registering for 6
May 28 19:29:25 dom0 kernel: pciback 0000:c3:00.4: xen_pciback: vpci: assign to virtual slot 1 func 4
May 28 19:29:25 dom0 kernel: pciback 0000:c3:00.4: registering for 6
May 28 19:29:25 dom0 kernel: pciback 0000:c3:00.5: xen_pciback: vpci: assign to virtual slot 1 func 5
May 28 19:29:25 dom0 kernel: pciback 0000:c3:00.5: registering for 6
May 28 19:29:25 dom0 kernel: pciback 0000:c3:00.6: xen_pciback: vpci: assign to virtual slot 1 func 6
May 28 19:29:25 dom0 kernel: pciback 0000:c3:00.6: registering for 6
May 28 19:29:25 dom0 kernel: xen-blkback: backend/vbd/6/51712: using 1 queues, protocol 1 (x86_64-abi) persistent grants
May 28 19:29:25 dom0 kernel: xen-blkback: backend/vbd/6/51728: using 1 queues, protocol 1 (x86_64-abi) persistent grants
May 28 19:29:25 dom0 kernel: xen: registering gsi 37 triggering 0 polarity 1
May 28 19:29:25 dom0 kernel: Already setup the GSI :37
May 28 19:29:25 dom0 kernel: xen-blkback: backend/vbd/6/51744: using 1 queues, protocol 1 (x86_64-abi) persistent grants
May 28 19:29:25 dom0 kernel: pciback 0000:c1:00.3: xen-pciback: Driver tried to write to a read-only configuration space field at offset 0x2a6, size 2. This may be harmless, but if you have problems with your device:
1) see permissive attribute in sysfs
2) report problems to the xen-devel mailing list along with details of your device obtained from lspci.
May 28 19:29:25 dom0 kernel: xen: registering gsi 38 triggering 0 polarity 1
May 28 19:29:25 dom0 kernel: Already setup the GSI :38
May 28 19:29:25 dom0 kernel: xen-blkback: backend/vbd/6/51760: using 1 queues, protocol 1 (x86_64-abi) persistent grants
May 28 19:29:25 dom0 kernel: pciback 0000:c1:00.4: xen-pciback: Driver tried to write to a read-only configuration space field at offset 0x2a6, size 2. This may be harmless, but if you have problems with your device:
May 28 19:29:25 dom0 kernel: xen: registering gsi 46 triggering 0 polarity 1
May 28 19:29:25 dom0 kernel: Already setup the GSI :46
May 28 19:29:25 dom0 kernel: pciback 0000:c3:00.3: xen-pciback: Driver tried to write to a read-only configuration space field at offset 0x2a6, size 2. This may be harmless, but if you have problems with your device:
May 28 19:29:25 dom0 kernel: xen: registering gsi 47 triggering 0 polarity 1
May 28 19:29:25 dom0 kernel: Already setup the GSI :47
May 28 19:29:25 dom0 kernel: pciback 0000:c3:00.4: xen-pciback: Driver tried to write to a read-only configuration space field at offset 0x2a6, size 2. This may be harmless, but if you have problems with your device:
May 28 19:29:25 dom0 kernel: xen: registering gsi 44 triggering 0 polarity 1
May 28 19:29:25 dom0 kernel: Already setup the GSI :44
May 28 19:29:25 dom0 kernel: pciback 0000:c3:00.5: xen-pciback: Driver tried to write to a read-only configuration space field at offset 0x2a6, size 2. This may be harmless, but if you have problems with your device:
May 28 19:29:25 dom0 kernel: xen: registering gsi 45 triggering 0 polarity 1
May 28 19:29:25 dom0 kernel: Already setup the GSI :45
May 28 19:29:25 dom0 kernel: pciback 0000:c3:00.6: xen-pciback: Driver tried to write to a read-only configuration space field at offset 0x2a6, size 2. This may be harmless, but if you have problems with your device:
May 28 19:29:27 dom0 qubesd[2957]: vm.sys-usb: Setting Qubes DB info for the VM
May 28 19:29:27 dom0 qubesd[2957]: vm.sys-usb: Starting Qubes DB
May 28 19:29:27 dom0 audit[6218]: CRED_ACQ pid=6218 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_rootok acct="USERNAME" exe="/usr/sbin/runuser" hostname=? addr=? terminal=? res=success'
May 28 19:29:27 dom0 runuser[6218]: pam_unix(runuser:session): session opened for user USERNAME(uid=1000) by (uid=0)
May 28 19:29:27 dom0 audit[6218]: USER_START pid=6218 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_open grantors=pam_keyinit,pam_limits,pam_unix acct="USERNAME" exe="/usr/sbin/runuser" hostname=? addr=? terminal=? res=success'
May 28 19:29:27 dom0 runuser[6218]: pam_unix(runuser:session): session closed for user USERNAME
May 28 19:29:27 dom0 audit[6218]: USER_END pid=6218 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_keyinit,pam_limits,pam_unix acct="USERNAME" exe="/usr/sbin/runuser" hostname=? addr=? terminal=? res=success'
May 28 19:29:27 dom0 audit[6218]: CRED_DISP pid=6218 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_rootok acct="USERNAME" exe="/usr/sbin/runuser" hostname=? addr=? terminal=? res=success'
May 28 19:29:27 dom0 qubesd[2957]: vm.sys-usb: Activating the sys-usb VM
May 28 19:29:27 dom0 audit[6222]: CRED_ACQ pid=6222 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_rootok acct="USERNAME" exe="/usr/sbin/runuser" hostname=? addr=? terminal=? res=success'
May 28 19:29:27 dom0 runuser[6222]: pam_unix(runuser:session): session opened for user USERNAME(uid=1000) by (uid=0)
May 28 19:29:27 dom0 audit[6222]: USER_START pid=6222 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_open grantors=pam_keyinit,pam_limits,pam_unix acct="USERNAME" exe="/usr/sbin/runuser" hostname=? addr=? terminal=? res=success'
May 28 19:29:29 dom0 kernel: xen-blkback: backend/vbd/5/51712: using 2 queues, protocol 1 (x86_64-abi) persistent grants
May 28 19:29:29 dom0 kernel: xen-blkback: backend/vbd/5/51728: using 2 queues, protocol 1 (x86_64-abi) persistent grants
May 28 19:29:29 dom0 kernel: xen-blkback: backend/vbd/5/51744: using 2 queues, protocol 1 (x86_64-abi) persistent grants
May 28 19:29:29 dom0 kernel: xen-blkback: backend/vbd/5/51760: using 2 queues, protocol 1 (x86_64-abi) persistent grants
May 28 19:29:31 dom0 runuser[6222]: pam_unix(runuser:session): session closed for user USERNAME
May 28 19:29:31 dom0 kernel: kauditd_printk_skb: 15 callbacks suppressed
May 28 19:29:31 dom0 kernel: audit: type=1106 audit(1716917371.934:554): pid=6222 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_keyinit,pam_limits,pam_unix acct="USERNAME" exe="/usr/sbin/runuser" hostname=? addr=? terminal=? res=success'
May 28 19:29:31 dom0 kernel: audit: type=1104 audit(1716917371.934:555): pid=6222 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_rootok acct="USERNAME" exe="/usr/sbin/runuser" hostname=? addr=? terminal=? res=success'
May 28 19:29:31 dom0 audit[6222]: USER_END pid=6222 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_keyinit,pam_limits,pam_unix acct="USERNAME" exe="/usr/sbin/runuser" hostname=? addr=? terminal=? res=success'
May 28 19:29:31 dom0 audit[6222]: CRED_DISP pid=6222 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_rootok acct="USERNAME" exe="/usr/sbin/runuser" hostname=? addr=? terminal=? res=success'
May 28 19:29:33 dom0 qrexec-policy-daemon[3044]: qrexec: qubes.WindowIconUpdater+: sys-usb -> @adminvm: allowed to dom0
May 28 19:30:09 dom0 qrexec-policy-daemon[3044]: qrexec: qubes.GetDate+nanoseconds: sys-usb -> @default: allowed to dom0
May 28 19:30:09 dom0 audit: BPF prog-id=75 op=LOAD
May 28 19:30:09 dom0 kernel: audit: type=1334 audit(1716917409.181:556): prog-id=75 op=LOAD
May 28 19:30:09 dom0 kernel: audit: type=1334 audit(1716917409.181:557): prog-id=76 op=LOAD
May 28 19:30:09 dom0 kernel: audit: type=1334 audit(1716917409.181:558): prog-id=77 op=LOAD
May 28 19:30:09 dom0 audit: BPF prog-id=76 op=LOAD
May 28 19:30:09 dom0 audit: BPF prog-id=77 op=LOAD
May 28 19:30:09 dom0 systemd[1]: Starting systemd-hostnamed.service - Hostname Service...
May 28 19:30:09 dom0 systemd[1]: Started systemd-hostnamed.service - Hostname Service.
May 28 19:30:09 dom0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 28 19:30:09 dom0 kernel: audit: type=1130 audit(1716917409.235:559): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 28 19:30:10 dom0 systemd[1]: /usr/lib/systemd/system/qubes-suspend.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
For reference
$ sudo lspci
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14e8
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Device 14e9
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14ea
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14ea
00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14ee
00:02.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14ee
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14ea
00:03.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 19h USB4/Thunderbolt PCIe tunnel
00:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14ea
00:04.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 19h USB4/Thunderbolt PCIe tunnel
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14ea
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14eb
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14eb
00:08.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14eb
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 71)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14f0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14f1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14f2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14f3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14f4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14f5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14f6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14f7
01:00.0 Network controller: MEDIATEK Corp. MT7922 802.11ax PCI Express Wireless Network Adapter
02:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller S4LV008[Pascal]
c1:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Phoenix1 (rev c1)
c1:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Rembrandt Radeon High Definition Audio Controller
c1:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 19h (Model 74h) CCP/PSP 3.0 Device
c1:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Device 15b9
c1:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Device 15ba
c1:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] ACP/ACP3X/ACP6x Audio Coprocessor (rev 63)
c1:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h/19h HD Audio Controller
c2:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Device 14ec
c2:00.1 Signal processing controller: Advanced Micro Devices, Inc. [AMD] AMD IPU Device
c3:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Device 14ec
c3:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Device 15c0
c3:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Device 15c1
c3:00.5 USB controller: Advanced Micro Devices, Inc. [AMD] Pink Sardine USB4/Thunderbolt NHI controller #1
c3:00.6 USB controller: Advanced Micro Devices, Inc. [AMD] Pink Sardine USB4/Thunderbolt NHI controller #2
$ sudo lsusb
Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 002: ID 32ac:0003 Framework DisplayPort Expansion Card
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 002: ID 0bda:5634 Realtek Semiconductor Corp. Laptop Camera
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 002: ID 05e3:0625 Genesys Logic, Inc. USB3.2 Hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 006: ID 0e8d:e616 MediaTek Inc. Wireless_Device
Bus 001 Device 009: ID 32ac:0018 Framework Laptop 16 Keyboard Module - ISO
Bus 001 Device 008: ID 27c6:609c Shenzhen Goodix Technology Co.,Ltd. Goodix USB2.0 MISC
Bus 001 Device 005: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 001 Device 007: ID 32ac:0014 Framework Laptop 16 Numpad Module
Bus 001 Device 004: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 001 Device 003: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 001 Device 002: ID 32ac:0003 Framework DisplayPort Expansion Card
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
$ sudo lsusb -t
/: Bus 08.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 10000M
/: Bus 07.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 480M
/: Bus 06.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 10000M
/: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 480M
/: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 10000M
/: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 480M
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 10000M
|__ Port 2: Dev 2, If 0, Class=Hub, Driver=hub/3p, 10000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/5p, 480M
|__ Port 2: Dev 3, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 3: Dev 4, If 0, Class=Hub, Driver=hub/3p, 480M
|__ Port 2: Dev 7, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 2: Dev 7, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 2: Dev 7, If 2, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 2: Dev 7, If 3, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 4: Dev 5, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 2: Dev 9, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 2: Dev 9, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 2: Dev 9, If 2, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 2: Dev 9, If 3, Class=Human Interface Device, Driver=usbhid, 12M
