I’m running Qubes on an X230 i5 3230M 128GB SDD and am thinking of getting a new laptop.
What laptop do you peeps recommend for daily use? cost is less than £600.
x230 i7 obviously.
Is there a lot of difference between the i5 variant, which Cyber123 already has, and i7?
I havent formally compared x230.
I did compare x220 i5 and i7 - on one test, starting sys-net,TorVM,
and disposableVM web browser, the i7 was 5 secs faster on average:
34 secs against 39 secs.
That’s significant enough to be noticeable.
You can find those results on the mailing list.
The quad-core T430/T530/W530 are also all very nice (and much more responsive than my i7 x230 when starting VMs or playing video, while doing something else).
Thanks peeps! I’ll stick with Thinkpads! Apart from Thinkpads, what other laptops would you recommend?
Thanks!
I use a LIbrem 15 for travel, though it may be out of your budget. Qubes runs perfectly on it.
Apart from Thinkpads and Librem does Qubes run on almost any hardware?
Not only there are sigificant differences between i7 and i5, they are also made in **different generations i7-Xyz… and i5-Xyz… where X is ther generation. The higher the number the newer/better CPU!
You can read more on Intel_Core and choose the processor that fit your demands best!
Good luck
Qubes does not run on almost any hardware, it has a pretty specific requirements. Have a look at hardware compatibility list for more hardware options.
Sorry, let me rephrase the question: If I buy any laptop with the specific requirements will Qubes run on it?
Unfortunately, no. For example, Qubes doesn’t yet run on newer (10th- or 11th-gen) Intel processors. There’s always a risk to buying an untested computer and hoping Qubes will run on it (at least without significant issues); your best bet is to stick to something tried-and-true on the hardware compatibility list.
