Enable UTF-8 in dom0 title bars
You can enable UTF-8 characters in the title bar for all (non-Windows) qubes or on a per-qube basis. For an individual qube, this can be done using the Qube Manager’s Advanced tab or, in a dom0 terminal, via the command
qvm-features <VMname> gui-allow-utf8-titles true
To change this given GUI option globally, set this feature in the Qube Manager’s Global Settings plane, which will apply to all qubes using the GuiVM under which Qube Manager is running (usually dom0, or possibly in one of the alternative GuiVMs sys-gui or sys-gui-gpu). To set this property globally for all qubes running under a certain GuiVM, e.g. dom0, use the command
qvm-features dom0 gui-default-allow-utf8-titles true
or accordingly.
Note: This does not work for Windows qubes.
Changing the language of dom0
In order to install an additional language in dom0, e.g. German: In a dom0 terminal, execute
sudo qubes-dom0-update langpacks-de
Then reboot.
Before logging in, the task panel will show - usually far to the right - the current language, e.g. C.UTF-8. Clicking on this value will open a menu where you can select the GUI language, i.e. the interface language of Qubes used in dom0 and in the menus, like Whiskers. Note, however, that the language of some Qubes utilities like the Qube Manager does not change, and any Templates and AppVMs based on these Templates retain their language.
This need only be done once; the selected language survives logging out and reboot.
Changing the language of Templates and the AppVMs based on them
To change the language of existing Templates, you have to install the language packs in these Templates.
For Fedora-based Templates, this is done (for German as an example) via
sudo dnf install langpacks-de
For debian-based Templates, the corresponding command is
sudo apt-get install language-pack-de language-pack-gnome-de language-pack-de-base language-pack-gnome-de-base
For other languages, the corresponding code has to be used, e.g. fr for French. After installing a language, it has to be selected/enabled via the settings of the Template.
New Templates will be installed in their default language, usually English, and they have to be changed just like existing Templates. This could be alleviated by installing a “clean” Template from the repository, with nothing but the needed language packs before starting to create a new template–clone using one of these languages. For instance, when you need a totally new Template (e.g., Debian 12 when it comes out), you’ll have to create debian-12-de and regenerate all other Templates from that.
The language of Windows Templates is determined at the installation of the operating system and can be changed afterwards if the installed edition is a multi-language edition; otherwise the language stays fixed.
AppVMs started after this change will inherit the language from the corresponsing Template.
How to set up pinyin input in Qubes
The pinyin input method will be installed in a TemplateVM to make it available after restarts and across multiple AppVMs.
In a TemplateVM, install
ibus-pinyinvia the package manager or terminal. If the template is Fedora-based, runsudo dnf install ibus-pinyin. If the template is Debian-based, runsudo apt install ibus-pinyin -
Shut down the TemplateVM.
Start or restart an AppVM based on the template in which you installed
ibus-pinyinand open a terminal. -
Run
ibus-setup. -
You will likely get an error message telling you to paste the following into your bashrc:
export GTK_IM_MODULE=ibus export XMODIFIERS=@im=ibus export QT_IM_MODULE=ibusCopy the text into your
~/.bashrcfile with your favorite text editor. You will need to do this for any AppVM in which you wish to use pinyin input. -
Set up ibus input as you like using the graphical menu (add pinyin or intelligent pinyin to selections). You can bring the menu back by issuing
ibus-setupfrom a terminal. -
Set up your shortcut for switching between inputs. By default it is super-space.
If ibus-pinyin is not enabled when you restart one of these AppVMs, open a terminal and run ibus-setup to activate ibus again.
For further discussion, see this qubes-users thread.
- Page archive
- First commit: 08 Dec 2020. Last commit: 03 Sep 2022.
- Applicable Qubes OS releases based on commit dates and supported releases: 4.0, 4.1
- Original author(s) (GitHub usernames): GWeck
- Original author(s) (forum usernames): @GWeck
- Document license: CC BY 4.0
