I tried to install it as a service, but I get this error when trying to download Patrick’s signing key
–2024-01-9 07:17:14-- https://www.whonix.org/patrick.asc
Resolving www.whonix.org (www.whonix.org)…
Connecting to www.whonix.org (www.whonix.org) connected.
HTTP request sent, awaiting response… 404 Not Found
2024-01-9 07:17:14 ERROR 404: Not Found.
I have seen many forum posts discussing how it wont work (unless it is installed in dom0?)
When I add Whonix’s Debian hosts repository and then execute
sudo apt install kloak
I get this :
○ kloak.service - kloak anti keystroke deanonymization tool
Loaded: loaded (/lib/systemd/system/kloak.service; enabled; preset: enabled)
Active: inactive (dead)
Condition: start condition failed
└─ ConditionPathExists=!/run/qubes/this-is-templatevm was not met
Docs: GitHub - vmonaco/kloak: Keystroke-level online anonymization kernel: obfuscates typing behavior at the device level.
Jan 9 016:55:25 installer systemd[1]: kloak.service - kloak anti keystroke deanonymization tool was skipped because of an unmet condition check (ConditionPathExists=!/run/qubes/this-is-templatevm).
I’m not sure if kloak can be installed at all for qubes (either systemwide or just for a template or qube)
If it helps, I created a debian template and tried the install from there in the example above.
Any help would be greatly appreciated, thanks.
