Kill Intel ME Whisky Lake
Does anyone know a way to disable the Intel ME for the Whisky Lake ( i5-8265U)?
The me_cleaner does not work unfortunately, also the more current forks dont work
so how do you know it doesn’t work?
I tryed it severall times with all give options. After flashing the me is still alive and active.
On older CPUs it worked for me (thinkpad T450s)
but how you know it still active?
me_cleaner works up to Kabylake - I’m not aware of anything that will
work on WhiskeyLake.
Yet another reason not to rush for the latest hardware.
That said, Purism offer a 14 with CometLake and claim that the IME is
disabled. AS they did for the 13, and that had WhiskeyLake.
I had a quick check on github and don’t see anything on how they did this
Thank you, ill take a look
If you find the answer can you posy back here?
I looked at the 13 script for building coreboot and it just called
me_cleaner. Go figure.
So i tried it right now, i used the forked me_cleaner from dt-zero . I have used the -S -O option. It said the HAP AltMeDisable bit is set. So i dumped the status:
MEI found: [8086:9de0] Cannon Point-LP MEI Controller #1
ME Status   : 0x94000245
ME Status 2 : 0xf18506
ME: FW Partition Table      : OK
ME: Bringup Loader Failure  : NO
ME: Firmware Init Complete  : YES
ME: Manufacturing Mode      : NO
ME: Boot Options Present    : NO
ME: Update In Progress      : NO
ME: Current Working State   : Normal
ME: Current Operation State : M0 with UMA
ME: Current Operation Mode  : Normal
ME: Error Code              : No Error
ME: Progress Phase          : ROM Phase
ME: Power Management Event  : Clean Moff->Mx wake
ME: Progress Phase State    : (null)
ME: Extend Register not valid
ME: Firmware Version 12.0.1606.68 (code) 12.0.1606.68 (recovery) 12.0.1524.47 (fitc)
ME Capability: Full Network manageability                 : OFF
ME Capability: Regular Network manageability              : OFF
ME Capability: Manageability                              : OFF
ME Capability: Small business technology                  : OFF
ME Capability: Level III manageability                    : OFF
ME Capability: IntelR Anti-Theft (AT)                     : OFF
ME Capability: IntelR Capability Licensing Service (CLS)  : ON
ME Capability: IntelR Power Sharing Technology (MPC)      : OFF
ME Capability: ICC Over Clocking                          : OFF
ME Capability: Protected Audio Video Path (PAVP)          : ON
ME Capability: IPV6                                       : OFF
ME Capability: KVM Remote Control (KVM)                   : OFF
ME Capability: Outbreak Containment Heuristic (OCH)       : OFF
ME Capability: Virtual LAN (VLAN)                         : ON
ME Capability: TLS                                        : ON
ME Capability: Wireless LAN (WLAN)                        : OFF
Im confused, because the ME status differs . Is it sill alive? I also have the correct ME Version showed up in the BIOS. On my older T450 the firmware version is gone
