I’m using debian-11 in Qubes OS as my default TemplateVM and it occurred to me that this would be more secure if it is Kicksecure.
In that case, do I just distromorph the debian-11’s TemplateVM, or should I clone the whonix-ws-16 TemplateVM, name it Kicksecure, and set it as default?
Has anyone done the same thing? Did you encounter any problems?
Do you think this is a good idea?
Clone debian-11 (or debian-11-minimal) and morph the clone. You may still need the clean template.
Does it cause any problems if I use the Kicksecure TemplateVM for service qubes like sys-net or sys-firewall?
I haven’t encountered any issues with ks on service vms. You should be ok.
Thank you ![]()
No problem mate, if the question is resolved please mark it as such (select a solution).
As far as I know kicksecure is experimental, pre-release, and has not been audited in
any way.
just curious… if its not audited then why is it used in whonix?
That question might be more likely to receive an authoritative answer on the Whonix Forums.
Correct at the time of writing.
Update: See website for latest status.
See:
