Kernel panic on boot with 6.15+ kernels
Qubes 4.2
Kernels 6.15.10 and 6.17.9 panic immediately on boot (dead Tux, hard reboot required). No error output. Don’t have a console cable.
Kernels 6.12.59 and 6.12.54 boot fine.
See my HCL entry for hardware details: HCL - AMD Ryzen 9 9950X with ASUS ROG Strix X670E-A
Anyone else seeing this?
Do you have the possibility of testing this out on R4.3?
Ah, not really, this is a production box. I tried to install 4.3 when it was a clean install and ran into so many issues I made a thread here and gave up. Won’t have time this year to re-do that unfortunately, although I did eventually get a 4.3 laptop running (different hardware) which functions as a restore target for my backups.
Hi Ryzen9950x :slight_smile:
Can you try and edit the parameters for the boot process by hitting e when you see the GRUB menu and:
  1. remove quiet from the kernel parameters
  2. replace console=none with console=vga vga=,keep loglvl=all guest_loglvl=all noreboot=1 earlyprintk=xen as options to Xen
The boot process will be slooow - but might provide a bit of debug information to look at.
:slight_smile:
