KDE on Dom0: Flips my primary screen after screen saver runs
Hi Everyone,
Hope your day is going well! I have a fun problem that could use some troubleshooting suggestions. When running KDE in Dom0 on Qubes 4.3, I keep having to set the correct monitor for primary. It won’t keep the configuration I save for long. Soon after a screen save or sleep event, it flips to another monitor. Such a pain!
Let me know what you think, tips, suggestions, all appreciated! Have a good one :wink:
Klaus
After finding nothing, I thought to try and switch the monitors at the KVM. I swapped cables to the inputs to those monitors. Now its happy I suppose, since it will always want to switch to the correct monitor since there are only two! Problem solved!
