When attempting to upgrade the Kali VM template following this article:
the last command, sudo apt dist-upgrade -y causes the VM to shutdown, but it will not boot back up
for some reason.
The error message is:
qrexec-daemon startup failed
qrexec-daemon.c
connection to the daemon failed
and some other error messages:
domain dead | qrexec-daemon[65974]: qrexec-daemon.c:340:init: cannot connect to qrexec
agent: No such file or directory
qrexec-agent
and another:
mount: can’t read ‘/proc/mounts’: No such file or directory
/sbin/init: error while loading shared libraries: libsystemd-core-252.so: cannot open
shared object file: no such file or directory
So after holding the packages, the VM boots, but it won’t launch a terminal; the logs, I mean there isn’t any sort of glaring error message, not like there was previously not having preserved the qubes packages.
The templates listed there, at Index of /Templates_4.1; when installed seem to be missing key applications. There is a listing “Application missing in template!” next to each listed app. This is not a disk space issue.
