When I tried to install the Kali template I get suspicious returns:
[user@dom0 ~]$ rpm -q qubescore-dom0-linux
qubes-core-dom0-linux-4.1.18.fc32.x86_64
[user@dom0 ~]$ sudo qubes-dom0-update --enablerepo=qubes-templates-community-testing qubes-template-kali
Redirecting to ‘qvm-template install --enablerepo=qubes-templates-community-testing qubes-template-kali’
Downloading ‘qubes-template-kali-0:4.0.6-202106171816’…
qubes-template-kali-0:4.0.6-202106171816: 4%| | 149M/3.32G [12:16<4:21:35, 202
Error canoncalizing file: Payload forged!
ERROR: [errno 2] No such file or directory: ‘/root/.cache/qvm-template/tmp4xa4_2h_/qubes-template-kali-0:4.0.6-202106171816.rpm.UNTRUSTED’
I tried the
command again and it reached 90% before returning the same as ab0ve.
UPDATE:
I retried the initial install command several times and it eventually completed the template download. I was able to fix the subsequent dom0 small pool issue with the command suggested here by fepitre: sudo journalctl --vacuum-time=1d
It cleared up enough space to allow the template to install. It updated via Qubes Update tool without issue.
I was and still am a little concerned about the errors I was getting previously such as, “Payload forged!” and “…rpm.UNTRUSTED” though… I cannot find such errors anywhere in the forum.
