Kali rolling not start
two months ago, my kali qube breaks. I tried to reinstall kali template, kali standalone, kali rolling from debian. But nothing works.
What I think is that the python version of kali rolling is not compatible with the qube agent, is it correct ? Can I resolve it ?
Below is an example of what happens when I try to install kali tools
└─# apt install kali-tools-web
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
Unsatisfied dependencies:
 qubes-core-agent : Depends: python3-qubesdb but it is not going to be installed
                    Recommends: gnome-themes-standard but it is not installable
 xen-utils-4.17 : Depends: python3 (< 3.12) but 3.12.6-1 is to be installed
Error: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
thanks a lot
