Since about a month, I’m having issues with Xscreenlocker.
- When locked, the unlock ‘window’ will appear until it’s timed out, but then after about 10-20 seconds it will appear again until timed out, repeating endlessly.
- Automatic lockscreen after X minutes does not work.
So, it seems there is mouse/keyboard input detected at certain intervals which prevent automatic locking and which causes the unlock ‘window’ to appear again and and when manually locked.
I don’t know exactly when it started, but around that time I had installed dom0 updates(including kernel), but also a BIOS update. I’ve tried booting with an older kernel but it does not help.
Since then dom0 received multiple updates but that didn’t fix the issue.
Has anyone else experienced this issue?
Machine is a Thinkpad L14 gen 3 AMD.
@zaz Do you have this issue on your L14? I’m on BIOS 1.31 btw.
