I fixed. but this HVM is too slow.
there is any alternative ?
Thanks for this, it fixed my issues !
Try increasing the amount of RAM in the HVM qube settings. It worked for me.
Hello, thank you for the tip !
How do you upgrade your firmware ?
In firmware process the usb “restart” to install and I loose the USB connection.
I’m spamming this on all the Trezor threads I can find. I could never get a good solution, so I worked with AI to diagnose and create a working solution. It’s a python script, it depends on python3-trezor and python3-libusb1. The flow is 1) plug trezor in, unlock, and attach to qube, 2) run script, 3) use trezor suite, or launch a chrome-based browser with “–disable-features=LocalNetworkAccessChecks“ and then the trezor website and metamask should work. The script has nice long comment docs explaining everything in it. I don’t know how long this will be viable for, but at least for the moment, it’s a relatively easy solution for getting the trezor to work.
Hi @tmp.lLDDirZ2Rg , you should post this into Trezor’s github/forums to see if they can integrate this script in trezorctl / Trezor-Suite or standalone utility package in order to have an official solution for us using Qubes.
Can you tell me how you fixed it ? Have same issue, when attaching PCI USB to any on my cube I can’t start qubes because this device is in use
