so i tried following most recent @smrtak instructions… couldnt get it to work… trezor suite app keeps loading… downloaded trezor in cloned whonix ws template routed over sys-whonix using the trezor Ubuntu guide on website https://trezor.io/guides/trezor-suite/installing-trezor-suite-on-linux
sudo apt install trezor
used the manual download off Trezor Udev install https://trezor.io/guides/trezorctl/udev-rules into the TrezorSuite terminal
sudo curl https://data.trezor.io/udev/51-trezor.rules -o /etc/udev/rules.d/51-trezor.rules
pls lmk what you think may be causing this @smrtak …
@othmanmekhloufi @d-arcy @FranklyFlawless @Phelipe @TioJefe if y’all having any suggestions I’ll take them. thx
using a model t trying to get working on trezor suite app and to eventually use it on a different appvm with electrum and feather.
