You do have to select the NetVM of choice for either the AppVM/DispVM based on the awesome-signal-template.
Ah, one package that’s not install installed by default for minimal is qubes-core-agent-networking, you’ll definitely want that if you would like to use as opposed to just install (for debiuging/reversing etc.) signal-desktop.
So, within awesome-signal-template you can run the following with root level permissions:
apt install qubes-core-agent-networking -y
Re: `attack surface`
Never mind the about that non-sense mentioned up-thread, those postulations are baseless FUD born of confusion.
Thanks! Yeah i like signal. Moxie seems cool… whisper systems, etc. But i have issues still with my system setup… When i try to pass the built in mic i get this message: “pulseaudio agent not running”
I also have issues with usb on this laptop… I have some usb device when i start that says:
sys-usb;5-2 Generic _USB2.0-CRW_456789087 and a bunch of numbers…
Have i unplugged some usb cable or what… I just have issues with usb on this laptop… Any ideas? pulseaudio and usb issues… thanks again!
The best solution would be if i could just get the debian normal template signal commands on here… That would solve the issue… And get signal working, and that one has all of the “drivers” and such…
I could try and copy out them of the post that is written also, but yeah…
If someone feels like typing out the right commands or copy them here instead that would be the easiest solution really… to tired for this now… computers… fcuks sake. Something this easy, taking time… hehe
But i’m doing allot of other stuff at the same time so yeah… that’s that…
Signal could have some Qubes commands on their site also i guess…
“Signals official Qubes install guide.”
Mic issues… yeah i did install signal… but yeah… computers…
Kinda annoying… until you get them to work like you want to… and find a flow… I’m gonna quit re-installing stuff…
I think that you need to have policykit-1 and qubes-usb-proxy installed in order to use camera and microphone. Below is the script that I use to create a debian-minimal template with signal-desktop and dependencies, typed using nano in a dom0 terminal:
The script works on my Librem 14 on the latest QubesOS 4.1.1 release. You can remove curl after installing the public signing key, and if you do not need a file manager, then you can remove the following packages from the script: nautilus qubes-core-agent-nautilus zenity
I hope this is helpful. Thanks to @Sven for the useful information in this forum which helped me to put this script together for myself.
Thank you to everyone in this forum that provides information and help. Learning to use QubesOS would have been a much more difficult experience for me, if not for all of the helpful people here.
Yeah, great bash script… almost like i want to learn to code some sometime, maybe… Much easier with those bash install .sh scripts.
And it worked fine in a normal debian template, but i got usb issues so i’m gonna start another thread about that. But signal works fine now. (To write in anyways… gotta fix some random usb issues where some devices sometimes show up, and most often not…) Noice!
Thanks
Thanks! Yeah but i did use cayce’s script and it worked fine… But it’s good to backup those anyways so i can install signal quick and easy in the future. I prefer the normal debian template over minimal though… Got space.
Yeah thanks for all of the answers in the thread! Enjoy your weekends. Peace out
Thanks for this also! But cayce… Do you know how to fix this issue? I did get the same “error” earlier while trying to install it…
#apt update
Get:1 https://deb.librewolf.net bullseye InRelease [25.2 kB]
Hit:2 Index of /debian bullseye InRelease
Err:1 https://deb.librewolf.net bullseye InRelease
The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY D29FBD5F93C0CFC3
Hit:3 Index of /r4.1/vm/ bullseye InRelease
Hit:4 Index of /debian-security bullseye-security InRelease
Reading package lists… Done
W: GPG error: https://deb.librewolf.net bullseye InRelease: The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY D29FBD5F93C0CFC3
E: The repository ‘https://deb.librewolf.net bullseye InRelease’ is not signed.
N: Updating from such a repository can’t be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
I used your script and got that. Why? How do i fix it? Thanks again
These issues are due to lack of signing key being available to the apt package management system.
Maybe make sure that the file /etc/apt/sources.list.d/librewolf.sources doesn’t exist? If it does, remove it with root permissions or use sudo like so:
rm /etc/apt/sources.list.d/librewolf.sources
This is an artifact from the official librewolf Installation instructions for Debian based which uses different formatting than .list files and, may not be accepted and causing this issue.
Also, to be sure there were no errors or redundancy via running the above steps multiple times, you can safely go ahead and remove these files with root permissions or use sudo like so:
Because we live in times where FUD hype gets the “likes” and, to add some color to the questionable fretting over the installation of libappindicator3-1 …
One (now patched) “dependency” that has been noteworthy within the past year is the LPE in polkit’s pkexec utility:
Hey again… Now i have this wierd issue where the mic don’t work… why? Is it because i have signal in a template? Its a normal template…
Gotta get my mic to work… Neither the inbuilt or an external gave off sound… wierd.
I have not got signal to work other then writing text… which i don’t want…
wanna talk. I managed to switch the mic to the cube… and record. But there where no sound recording
