Hi all,
I am trying to write a salt config to install flatpak in a fedora template and add a remote to flathub.
Flatpak installs just fine however adding the flathub remote is proving troublesome.
Please note, when I set this up manually it works fine.
export https_proxy=http://127.0.0.1:8082/
flatpak remote-add --if-not-exists flathub https://dl.flathub.org/repo/flathub.flatpakrepo
The issue is that I cannot seem to set the https_proxy var in the salt config to be able to add the remote:
# this part works
flatpak_install:
pkg.installed:
- pkgs:
- flatpak
# this doesnt
flatpak_add_flathub:
cmd. run:
- name: flatpak remote-add --if-not-exists flathub https://dl.flathub.org/repo/flathub.flatpakrepo
- env:
- https_proxy: 127.0.0.1:8082
# I also tried something like this - didnt work
cmd. run:
- name: export https_proxy: 127.0.0.1:8082 && flatpak remote-add --if-not-exists flathub https://dl.flathub.org/repo/flathub.flatpakrepo
Thanks.
