Hello,
Recently I was following documentation at How to upgrade a Fedora template in-place | Qubes OS for upgrading Fedora-40-xfce to Fedora-41-xfce, and encountered the error below at the end.
How do I address and fix this issue? Please help.
[user@fedora-41-xfce ~]$ sudo dnf update
Updating and loading repositories:
Audirvana 100% | 4.4 KiB/s | 2.5 KiB | 00m01s
Fedora 41 openh264 (From Cisco) - x86_ 100% | 4.0 KiB/s | 4.8 KiB | 00m01s
Fedora 41 - x86_64 100% | 6.4 MiB/s | 35.4 MiB | 00m06s
Fedora 41 - x86_64 - Updates 100% | 1.4 MiB/s | 11.7 MiB | 00m08s
Qubes OS Repository for VM (updates) 100% | 2.1 KiB/s | 2.8 KiB | 00m01s
>>> Librepo error: repomd.xml GPG signature verification error: Signing key not
Failed to download metadata (baseurl: "https://yum.qubes-os.org/r4.2/current/vm/fc41") for repository "qubes-vm-r4.2-current"
Librepo error: repomd.xml GPG signature verification error: Signing key not found
Thanks.
Hmm… It does not work for my case… The same error seems to persist.
[user@fedora-41-xfce ~]$ sudo dnf upgrade --enablerepo=updates-testing --refresh --advisory=FEDORA-2025-748bf44daa
Fedora 41 openh264 (From Cisco) - x86_ 100% | 1.2 KiB/s | 989.0 B | 00m01s
Fedora 41 - x86_64 - Updates 100% | 118.9 KiB/s | 27.8 KiB | 00m00s
Audirvana 100% | 5.7 KiB/s | 3.0 KiB | 00m01s
Fedora 41 - x86_64 100% | 126.5 KiB/s | 30.5 KiB | 00m00s
Fedora 41 - x86_64 - Test Updates 100% | 628.4 KiB/s | 2.3 MiB | 00m04s
Qubes OS Repository for VM (updates) 100% | 2.8 KiB/s | 2.8 KiB | 00m01s
I looked the FEDORA-2025-748bf44daa release fix and I read “Updates may require up to 24 hours to propagate to mirrors”, so please retry later…
As it’s a Fedora issue, you could add a comment/question to the #2352958 Fedora issue and/or the FEDORA-2025-748bf44daa release fix.
As an alternative, remember that the preferred way to upgrade a template is to download the new one. So I advice that you download the fedora-41-xfce template with qvm-template-gui, see the related fedora-40-approaching-end-of-life announce.
Hello,
I have confirmed that fresh download and installation of fedora-41-xfce does work without DNF issue. But the amount of modifications that are in place with fedora-40-xfce on the running system, I would like to get in-place option to work out.
It seems that I am going to play a game of time, if the fix gets propagated into downstream earlier or fedora-40-xfce end-of-life arrives earlier…
I need to keep eyes on DNF version (currently 5.2.11.0) of the fresh fedora-41-xfce template frequently, I guess.
Thanks.
Hello!
I have done the in-place upgrade again, and it went fine today.
Repositories loaded.
Nothing to do.
