So, I was clean installing Qube stable ver 4.2.0, and it present me error about FAILED to access PASSPHRASE or invalid passphrase.
step to reproduce on my end:
plug the dd format bootdrive
select " test media … "or “start qubes installer”
after that on disk select option select “Auto” partion then begin install,
the error come on luks open step
Things I tried:
Verify the ISO file again, check hash value again, rewrite with dd then verify again : didn’t work same problem
download the Iso file again then process with prev steps, it didn’t work either,
search in duck about failed passphrase, where its said bcz of prev luks header or something, so I spin up a live fedora then dd it with urandom & zeros but again it didn’t work.
sometime later tried again with qubes iso to find the main problem, on tty where I use cryptsetup luksFormat encrypt work but luks/Open failed " no passphrase available". tried in tmpfs same case, but luks1 work in both. Also fedora 38/39, debian12 iso, memtest & smartctl work without any problem.
so, Is there any solution this problem, plz help !!!
Also if any details needs, willing to share.
Maybe try to boot the Qubes OS installer with kernel latest. Maybe there is some problem with the kernel.
You can also try to boot from Qubes OS 4.1.2 installer and check cryptsetup there for a test.
alright, as luks1 working, I will install qubes with luks1 FDE then will upgrade to luk2 to see if i can get hunt down this problem, if i found somthing will report it later
anyway thanks @apparatus for you valuable support and also others in this thread.
@apparatus It finally work after i swap ram slot & clear CMOS, create boot drive again to another flash drive. it magically fix it, don’t know what the cause is.
anyway, sorry for all the trouble i cause you, and Thank you very much.
