No need for chroot. You need to activate LVM on /dev/nvme1n1p3 with vgchange.
OK. I’m going))
not work
simon@debian:~$ sudo vgchange -ay
[sudo] пароль для simon:
56 logical volume(s) in volume group "qubes_dom0" now active
simon@debian:~$ sudo mount /dev/mapper/qubes_dom0-root /mnt
simon@debian:~$ sudo nano /mnt/etc/qubes-rpc/policy/qubes.InputKeyboard
simon@debian:~$ cat mnt/etc/qubes-rpc/policy/qubes.InputKeyboard
cat: mnt/etc/qubes-rpc/policy/qubes.InputKeyboard: Нет такого файла или каталога
simon@debian:~$ cat/ mnt/etc/qubes-rpc/policy/qubes.InputKeyboard
bash: cat/: Нет такого файла или каталога
simon@debian:~$ cat /mnt/etc/qubes-rpc/policy/qubes.InputKeyboard
$anyvm $anyvm deny
sys-usb dom0 allow
anyvm $anyvm deny
sys-usb dom0 allow
Add the sys-usb dom0 allow at the top of the file:
sys-usb dom0 allow
$anyvm $anyvm deny
sys-usb dom0 allow
anyvm $anyvm deny
2 lines delete or no ?
You can delete it but it makes no difference.
I did everything. my friend !!! This does not work
Check the file grub config:
sudo mount /dev/nvme1n1p1 /mnt
cat /mnt/EFI/qubes/grub.cfg | grep rd.qubes.hide_all_usb
If you have rd.qubes.hide_all_usb options there then remove all of them from grub config.
UPD:
Or maybe your keyboard is working already and only your mouse is not working?
The change in /mnt/etc/qubes-rpc/policy/qubes.InputKeyboard only fixed your keyboard but not mouse.
You need to also change this file /mnt/etc/qubes-rpc/policy/qubes.InputMouse to make mouse work.
simon@debian:~$ sudo mount /dev/nvme1n1p1 /mnt
simon@debian:~$ cat /mnt/EFI/qubes/grub.cfg | grep rd.qubes.hide_all_usb
module2 /vmlinuz-5.10.109-1.fc32.qubes.x86_64 placeholder root=/dev/mapper/qubes_dom0-root ro rd.lvm.lv=qubes_dom0/root rd.lvm.lv=qubes_dom0/swap plymouth.ignore-serial-consoles rd.driver.pre=btrfs rhgb quiet rd.qubes.hide_all_usb
module2 /vmlinuz-5.10.104-3.fc32.qubes.x86_64 placeholder root=/dev/mapper/qubes_dom0-root ro rd.lvm.lv=qubes_dom0/root rd.lvm.lv=qubes_dom0/swap plymouth.ignore-serial-consoles rd.driver.pre=btrfs rhgb quiet rd.qubes.hide_all_usb
module2 /vmlinuz-5.10.90-1.fc32.qubes.x86_64 placeholder root=/dev/mapper/qubes_dom0-root ro rd.lvm.lv=qubes_dom0/root rd.lvm.lv=qubes_dom0/swap plymouth.ignore-serial-consoles rd.driver.pre=btrfs rhgb quiet rd.qubes.hide_all_usb
module /vmlinuz-5.10.109-1.fc32.qubes.x86_64 placeholder root=/dev/mapper/qubes_dom0-root ro rd.lvm.lv=qubes_dom0/root rd.lvm.lv=qubes_dom0/swap plymouth.ignore-serial-consoles rd.driver.pre=btrfs rhgb quiet rd.qubes.hide_all_usb
module /vmlinuz-5.10.104-3.fc32.qubes.x86_64 placeholder root=/dev/mapper/qubes_dom0-root ro rd.lvm.lv=qubes_dom0/root rd.lvm.lv=qubes_dom0/swap plymouth.ignore-serial-consoles rd.driver.pre=btrfs rhgb quiet rd.qubes.hide_all_usb
module /vmlinuz-5.10.90-1.fc32.qubes.x86_64 placeholder root=/dev/mapper/qubes_dom0-root ro rd.lvm.lv=qubes_dom0/root rd.lvm.lv=qubes_dom0/swap plymouth.ignore-serial-consoles rd.driver.pre=btrfs rhgb quiet rd.qubes.hide_all_usb
there is no other way? right now 100% grab.cfg will break
grub.log (13.3 KB)
this grub.cfg
thank you friend. Both keyboard and mouse worked. I hit the cube. Now we need to figure out how to add YK
(edited title to make it more explicit, OP feel free to edit it if it’s wrong)
I recently became interested in cubes os. Decided to just install and try. It turned out that this is what I need for my desktop.
- What I didn’t like was the installation - network settings and so on. I think in the future the developers will bring to mind the installation mode.
- It was easy for me to figure out how to create and run virtual machines. It took a little time to understand that the machine template plays a key role. But it took a lot of time to learn how to enable keys to external repositories.
In total, I worked for about two weeks and I really like the cubes ecosystem.
Cubes OS is an ecosystem. A very good idea, and I think it will have a good continuation.
For example, that there are few video instructions. There are bloggers who talk about how good and safe it is, how to run and create virtual machines, and nothing else.
I read that Cubes OS loves OS very much and we will communicate in it.
As for the GUI, I have not seen anything complicated or well described.
I decided to add Yubikey. And that’s when I realized that I could be left without my data at all. And that’s when I realized that there are problems in the system and I need to somehow fix them in order to be able to manage my task.
For example, in Debian everything is clear how to add a device, delete, disable, configure.
Here I found out that there is sys-usb. Where it is - in the description. I am a beginner, I began to read the manual, after which the login to the system broke (the mouse and keyboard did not work). Why did it happen so ? I never found where to find all my USB devices. I just wanted to add Yubikey. Couldn’t do it. In the process, I discovered that if the Yubico is configured incorrectly, it is possible to close the OS. In general, at this point I stayed and decided to leave the presence of Yubico.
Do you have sys-usb?
not
