Greetings.
I’m using Qubes release 4.2.0-alpha (R4.2).
I have following configuration.
- Gigabyte X570 Gaming X motherboard
- AMD Ryzen 7 3800X 8-Core Processor (which doesn’t have iGPU)
- AMD Radeon RX 6750 XT
I’m trying to setup GPU GUI domain (sys-gui-gpu) according to official guide.
After running
sudo qubesctl --all state.highstate
There was an error about missing fedora-37-xfce template so I installed it
sudo qubes-dom0-update --enablerepo=qubes-template-itl-testing qubes-template-fedora-37-xfce
Next I repeated command
There was warning notification that Blueman applet crashed but I think it’s not critical.
The main output is
[user@dom0 ~]$ sudo qubesctl --all state.highstate
/usr/lib/python3.11/site-packages/_distutils_hack/__init__.py:33: UserWarning: Setuptools is replacing distutils.
warnings.warn("Setuptools is replacing distutils.")
[WARNING ] State for file: /etc/qubes/policy.d/45-sys-gui-gpu.policy - Neither 'source' nor 'contents' nor 'contents_pillar' nor 'contents_grains' was defined, yet 'replace' was set to 'True'. As there is no source to replace the file with, 'replace' has been set to 'False' to avoid reading the file unnecessarily.
local:
Function: qvm.template_installed
Result: True
Comment: Template fedora-37-xfce version 4.1.0 already installed
Started: 10:31:38.121032
Duration: 165.931 ms
Changes:
Function: pkg.installed
Result: True
Comment: All specified packages are already installed
Started: 10:31:39.106974
Duration: 278.714 ms
Changes:
Result: True
Started: 10:31:39.385797
Duration: 15.374 ms
Changes:
Function: file.managed
Result: True
Comment: File /etc/qubes/input-proxy-target is in the correct state
Started: 10:31:39.402543
Duration: 34.36 ms
Changes:
Result: True
Comment: File /etc/qubes/policy.d/45-sys-gui-gpu.policy exists with proper permissions. No changes made.
Started: 10:31:39.436992
Duration: 0.844 ms
Changes:
Function: qvm.exists
Result: True
Comment: /usr/bin/qvm-check sys-gui-gpu None
Started: 10:31:39.437901
Duration: 162.575 ms
Changes:
Result: True
Comment: File /etc/qubes/policy.d/50-gui-sys-gui-gpu.policy is in the correct state
Started: 10:31:39.600863
Duration: 2.196 ms
Changes:
Function: file.append
Result: True
Comment: File /etc/qubes/policy.d/include/admin-local-rwx is in correct state
Started: 10:31:39.603173
Duration: 1.663 ms
Changes:
Result: True
Comment: File /etc/qubes/policy.d/include/admin-global-rwx is in correct state
Started: 10:31:39.604911
Duration: 1.244 ms
Changes:
Summary for local
Succeeded: 9
Failed: 0
Total states run: 9
Total run time: 662.901 ms
debian-11: SKIP (nothing to do)
fedora-37: SKIP (nothing to do)
whonix-gw-16: SKIP (nothing to do)
whonix-ws-16: SKIP (nothing to do)
fedora-37-xfce: OK
anon-whonix-old: SKIP (nothing to do)
backup: SKIP (nothing to do)
debian-11-dvm: SKIP (nothing to do)
default-mgmt-dvm: SKIP (nothing to do)
internet: SKIP (nothing to do)
sys-net: SKIP (nothing to do)
sys-whonix: SKIP (nothing to do)
vault-credentials: SKIP (nothing to do)
vault-gpg: SKIP (nothing to do)
vault-ssh: SKIP (nothing to do)
vault-wallets: SKIP (nothing to do)
vault-work: SKIP (nothing to do)
whonix-ws-16-dvm: SKIP (nothing to do)
sys-gui-gpu: ERROR (exit code 20, details in /var/log/qubes/mgmt-sys-gui-gpu.log)
Content of /var/log/qubes/mgmt-sys-gui-gpu.log
[user@dom0 ~]$ cat /var/log/qubes/mgmt-sys-gui-gpu.log
2023-04-26 10:32:22,846 calling 'state.highstate'...
2023-04-26 10:32:53,124 output: sys-gui-gpu:
2023-04-26 10:32:53,125 output: ----------
2023-04-26 10:32:53,125 output: ID: /home/user/.config/autostart/nm-applet.desktop
2023-04-26 10:32:53,125 output: Function: file.managed
2023-04-26 10:32:53,125 output: Result: True
2023-04-26 10:32:53,125 output: Comment: File /home/user/.config/autostart/nm-applet.desktop is in the correct state
2023-04-26 10:32:53,125 output: Started: 10:32:52.686957
2023-04-26 10:32:53,125 output: Duration: 48.722 ms
2023-04-26 10:32:53,125 output: Changes:
2023-04-26 10:32:53,125 output: ID: /home/user/.config/autostart/xscreensaver-autostart.desktop
2023-04-26 10:32:53,125 output: Comment: File /home/user/.config/autostart/xscreensaver-autostart.desktop is in the correct state
2023-04-26 10:32:53,125 output: Started: 10:32:52.735752
2023-04-26 10:32:53,125 output: Duration: 0.951 ms
2023-04-26 10:32:53,125 output: ID: /home/user/.config/autostart/qvm-start-daemon.desktop
2023-04-26 10:32:53,125 output: Comment: File /home/user/.config/autostart/qvm-start-daemon.desktop is in the correct state
2023-04-26 10:32:53,125 output: Started: 10:32:52.736754
2023-04-26 10:32:53,125 output: Duration: 0.987 ms
2023-04-26 10:32:53,126 output: ----------
2023-04-26 10:32:53,126 output: ID: /rw/config/rc.local
2023-04-26 10:32:53,126 output: Function: file.append
2023-04-26 10:32:53,126 output: Result: False
2023-04-26 10:32:53,126 output: Comment: An exception occurred in this state: Traceback (most recent call last):
2023-04-26 10:32:53,126 output: File "/var/tmp/.root_dd8a91_salt/pyall/salt/state.py", line 2171, in call
2023-04-26 10:32:53,126 output: ret = self.states[cdata["full"]](
2023-04-26 10:32:53,126 output: ^^^^^^^^^^^^^^^^^^^^^^^^^^^
2023-04-26 10:32:53,126 output: File "/var/tmp/.root_dd8a91_salt/pyall/salt/loader.py", line 2105, in wrapper
2023-04-26 10:32:53,126 output: return f(*args, **kwargs)
2023-04-26 10:32:53,126 output: File "/var/tmp/.root_dd8a91_salt/pyall/salt/states/file.py", line 6301, in append
2023-04-26 10:32:53,126 output: if __salt__["file.search"](
2023-04-26 10:32:53,126 output: File "/var/tmp/.root_dd8a91_salt/pyall/salt/modules/file.py", line 3154, in search
2023-04-26 10:32:53,126 output: return replace(
2023-04-26 10:32:53,126 output: File "/var/tmp/.root_dd8a91_salt/pyall/salt/modules/file.py", line 2530, in replace
2023-04-26 10:32:53,126 output: flags_num = _get_flags(flags)
2023-04-26 10:32:53,126 output: File "/var/tmp/.root_dd8a91_salt/pyall/salt/modules/file.py", line 1653, in _get_flags
2023-04-26 10:32:53,126 output: _flag = getattr(re, str(flag).upper())
2023-04-26 10:32:53,126 output: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2023-04-26 10:32:53,126 output: AttributeError: module 're' has no attribute 'RE.MULTILINE'
2023-04-26 10:32:53,126 output: Started: 10:32:52.737792
2023-04-26 10:32:53,126 output: Duration: 3.248 ms
2023-04-26 10:32:53,126 output: Changes:
2023-04-26 10:32:53,126 output: Summary for sys-gui-gpu
2023-04-26 10:32:53,127 output: ------------
2023-04-26 10:32:53,127 output: Succeeded: 3
2023-04-26 10:32:53,127 output: Failed: 1
2023-04-26 10:32:53,127 output: Total states run: 4
2023-04-26 10:32:53,127 output: Total run time: 53.908 ms
2023-04-26 10:32:53,127 exit code: 20
I searched qubes-issues by keyword re.multiline and found this one but it’s closed saying that problem was fixed.
May be this problems are not related.
How could I fix this?
