ISO hit and miss
I’m going through the process of installing ISO for Kali, a Debian ISO (which was previously used for a work script in Virtual Box and I dont seem to simply be able to install the script in our Debian Template Terminal).
Kali went perfectly. Now I’m struggling with the Debian one at the mirror setup stage, is it possible i’m not booting from the complete iso image?
Also I was wondering if there is any way to install CSI Linux in Qubes.
Thank you
Are you using netinst ISO?
If yes then did you configure network properly in the installer?
by properly you mean with the ip, subnet, gateway, dns from the qube? yes
Yes.
I didn’t try to install from netinst ISO, maybe there is some issue with the network configuration.
I’ve just tried it using Debian 12.5 netinst image that I had and it worked for me when I’ve configured the network settings like this:
IP - 10.137.0.x
Netmask - 255.255.0.0
Gateway - 10.137.0.y
DNS - 10.139.1.1
Let me try again with your new info.
still not working. I keep getting that this is not a bootable drive even after installing everything and rebooting. I installed Kali the exact same way, that’s just why Im wondering where I’m going wrong. I have plently of disk space and RAM. Thank you
Did you install system and GRUB on the same disk (e.g. /dev/xvda)?
No on a new partition xvdb. Is that the problem?
You need to install the GRUB on the same disk where you’ve installed your system.
I’ve done it again. GRUB installed on same partition and still getting thatnon-bootable error message after the whole install. Any other ideas whyits’s giving me this? Thank you
I’ve tried installing debian-12.6.0-amd64-netinst.iso on /dev/xvda and installed GRUB on the same disk and it worked for me.
Describe all your installation steps in details to see what did you do wrong.
Hello , why do you want absolutly install netinst.iso and not simply .iso ?
I have tried several linux ( and even Windows 7)and it works good …( in sallone qube of cause).
I could install iso I guess I just wasn’t finding it. I will write down all my steps tonight. Thank you
Sorry for not answering for a little bit, I had gone on vacation. I did try to install the iso and not the netinst.iso. I installed GRUB on the same partition that I was installing the .iso.
Here are my main steps:
1)Build a Standalone Qube and give more than enough RAM and storage. Boot from .iso file that is in another Qube.
2)enter the qubes info that are in settings when asked for network config
Then the rest is pretty much the same steps as I had done to install kali linux without any problem.
Thank you for your help
What ISO did you try to install?
Did you try to install both system and GRUB on /dev/xvda?
Post the output of these commands in dom0 terminal for your qube:
qvm-prefs QUBENAME
qvm-features QUBENAME
Re: Installing CSI Linux on Qubes OS
I remember seeing this post a long time ago and wondering the same thing… my earlier attempts at loading up an old iso just kept failing at the time so the enthusiasm for the topic faded. Only recent noticed that there’s been a lot of work done on the system so just figured it might be fun to revisit the problem and finally got it to work as an HVM through sys-firewall and on the internets.
Took all day but had to convert their latest VirtualBox .vdi file to raw, pipe it into a fresh Debian StandAlone (all 120gigs). Gaining root and wrestling with the networking details taught me a thing or two but in the end a worthwhile challenge.
Hello Bonjour, 1/11/26
Until new version of Qubes os (4.3) i can 't install iso distributions ( for testing for exemple)I don 't know why , I use the same …methode ( creation of stanallone qube, without template)as 4.2.4
Depuis la nouvelle distribution qubes os 4.3.2 j arrive pas installer ( pour tester par exemple ubuntu )par iso , et creation qubes standallone. Merci si vous avez trouvé la solution
hello for exemple antiX 26 ( new interesting version) to test and teach myself
thanks
