In some linux distros, you can drag an application to the left and another to the right to tile them.
When I drag to the left in Qubes, it want to go to another workspace when sometimes I want tiled.
It also tiles, but the moving to another workspace is indeed quite sensitive and it’s easy to go through.
I suppose there must be way to configure that sensitivity, but I haven’t felt the need to. The XFCE documentation or forums should be a good place to start of you’re in a mood for it. ![]()
Edit: on R4.1 things work by default the same as @solene describes in the next post.
On the XFCE shipped in Qubes OS 4.2-RC5 this works out of the box.
This can also be customised in the keyboard shortcuts, I’m used to have the keypad keys + super to move/resize a window to half a screen (horizontal/vertical) or a corner. But that’s not practical on a laptop without a keypad ![]()
This works on the first screen if dragging something to the upper left or border but if you are on screen 6 and have 12 screens it will move it to another screen.
Is there a way to block Qubes from trying to move it to another screen by default?
A lot of times I do not use that first screen.
If you’d rather not have it, you can disable the workspace jumps when you drag windows (or move you pointer) near the edge of the screen in:
Q Menu > System Tools > Window Manager > Advanced > Wrap workspaces when reaching the screen edge
This should be marked as solution for the sake of others searching for the info in the future.
Try Super+[arrow key] for the “takes half the screen” cases and Super+Alt+[arrow key] for the “quarter screen” cases.
