I am describing an AppVM using qvm.present and qvm.prefs (docs ). I would like to be able to describe something equivalent to the result of:
qvm-volume extend vm-name:root 20g
I have performed an organisation-level search on GitHub for qvm.volume that didn’t yield any Salt-related results. Am I missing something? Is there any Salt state associated with the qvm-volume cli?
unman
April 20, 2021, 12:32pm
2
No - you need to run volume related calls manually with (e.g)
cmd.run.
Rudd-O
April 27, 2021, 1:34pm
3
I have code for that. This is a Salt state module, so you would place it in whichever _states directory your setup uses.
import subprocess
def size_to_bytes(size):
size = str(size)
if size.endswith("G"):
size = str(int(size[:-1]) * 1024 * 1024 * 1024)
elif size.endswith("M"):
size = str(int(size[:-1]) * 1024 * 1024)
elif size.endswith("K"):
size = str(int(size[:-1]) * 1024)
return size
def set_size(name, volume, size):
size = size_to_bytes(size)
ret = {
"name": name,
"comment": "",
"changes": {},
"result": False,
try:
current = subprocess.check_output(
["qvm-volume", "info", "{name}:{volume}".format(**locals()), "size"],
universal_newlines=True,
).rstrip()
except (subprocess.CalledProcessError, OSError) as e:
ret["comment"] = str(e)
return ret
if size == current:
ret['result'] = True
return ret
if __opts__['test']:
ret['comment'] = "Volume %s of VM %s would be resized from %s to %s" % (name, volume, current, size)
ret['changes'] = {volume: size}
ret['result'] = None
return ret
p = subprocess.Popen(
["qvm-volume", "resize", "{name}:{volume}".format(**locals()), size],
stdout=subprocess.PIPE,
stderr=subprocess.STDOUT,
output, _ = p.communicate()
output = output.rstrip()
returncode = p.wait()
if returncode == 0:
ret['comment'] = "Volume %s of VM %s resized from %s to %s" % (name, volume, current, size) + "\n" + output
else:
ret["comment"] = "Failed executing qvm-volume resize\n" + str(output)
return ret
Hi @Rudd-O ! Thank you for sharing this!
I am not very familiar with using modules, so I’ll do some reading.
