ryuu
January 6, 2022, 2:41pm
1
I have a piece of software I need that isn’t working on Whonix 16, but did work in Whonix 15. Running
sudo qubes-dom0-update qubes-template-whonix-15
only gives me the result
Error: Unable to find match: qubes-template-whonix-15
Is it still possible to install Whonix 15 despite the fact that it’s deprecated?
try sudo qubes-dom0-update qubes-template-whonix-gw-15 qubes-template-whonix-ws-15
ryuu
January 6, 2022, 3:07pm
3
That doesn’t work either. Running
sudo qubes-dom0-update qubes-template-whonix-16
doesn’t work either. I must be missing something obvious.
have you enable community repo ? try this
sudo qubes-dom0-update --enablerepo=qubes-templates-community qubes-template-whonix-gw-15 qubes-template-whonix-ws-15
ryuu
January 6, 2022, 3:25pm
5
This worked! Thanks. Do I need to user a sys-whonix based on whonix-gw-15 or will an appVM based on whonix-ws15 work with sys-whonix based on whonix-gw-16
If you never configure anything on your sys-whonix, simply change templates would be okay.
I’m having same issue. App I used in WS-15 won’t work in WS-16. So am I understanding correctly that a WS-15 VM will work with sys whonix GW 16?
enmus
January 7, 2022, 1:24am
8
Why wouldn’t it? It’s just another VM using sys-whonix as netVM.
necker
January 7, 2022, 1:38am
9
Any idea why this doesn’t work on my machine? I am running 4.1 with testing repos. Maybe there a config file I also need to change? (obviously I’m running that as two separate commands)
enmus
January 7, 2022, 10:04am
10
Did you try via qvm-template-gui? What the errors are?
51lieal
January 7, 2022, 10:44am
11
in 4.1 you need to enable ‘community testing’ repo.
necker
January 7, 2022, 12:28pm
12
Thank you!
To clarify for other 4.1 users, the following commands will download the respective templates:
sudo qubes-dom0-update --enablerepo=qubes-templates-community-testing qubes-template-whonix-gw-15
and
sudo qubes-dom0-update --enablerepo=qubes-templates-community-testing qubes-template-whonix-ws-15
necker
January 7, 2022, 12:29pm
13
“not found”
The above commands are required in 4.1
enmus
January 7, 2022, 5:38pm
14
That is why I wrote to you to try qvm-template-gui.
In Index of /repo/yum/r4.1/templates-community/rpm/
there is no whonix-15s anymore.
You run it and at the same time you know what repositories you enabled, and what templates are available there.
