Hello, I bought a x230 (i5-3320M)(SSD) and installed qubes os on it
while starting vms the fans spin loud and the cpu reaches 80c from 50c. Is it normal?
Also while browsing the web, the cpu gets hot randomly while downloading a file. Is this normal behaviour? Or do I need to configure something
It’s most probably a hardware problem.
Try to clean your laptop from dust, replace thermal paste and check if your coolers are working properly.
