Is documentation for preloaded dispvms available? Or does the documentation come after the release candidate?
There is a draft announcement for it
Spoilers: The draft has 133 posts and replies (so far). This should show how complicated and involved is the documentation. Usually end users do not need to bother too much about the details. There is easy to use settings for preloaded disposables in installer, global config and individual DispVM settings. I will post some more screenshots in todayâs newsletter.
Documentation says itâs set and forget. Iâve set 5 preloaded vms for my browser DVM. When I start one, I get five notifications of vms starting then five notifications of those vms shutting down. The same process occurs each time I start a new disposable.
Interesting. Is the system fully updated with testing repositories (and is it restarted after update)?
If the error persists, I would recommend opening a new issue.
Everything is updated and Iâve restarted. Still persists.
Then I would highly recommend you to file a new issue. The entire preloaded disposable design is extremely complex. Some bugs might be present at this stage.
They are trying to preload but not being able to.
- Which template are you using? Did you set via the global config or vm settings?
- Start watching the journal: `sudo journalctl -fu qubesd -o cat | grep -v pam_unix
- Set the
maxto0, wait a bit and then set to1
What message is printed on the qubesd logs?
A browser-dvm, based on fedora-42-xfce (upgraded dirty).
First set directly from VM settings. Then tried global override.
Set max to 0 then 1, same issue.
Youâll see in the output below, I set to 2, then receive an error re qubes.WaitForRunningSystem
Output of qubesd logs
INFO: vm.browser-dvm: Received preload event 'start' because global feature was set to 2
INFO: vm.browser-dvm: Preloading '2' qube(s)
INFO: vm.disp6589: Marking preloaded qube
INFO: vm.disp6589: Creating directory: /var/lib/qubes/appvms/disp6589
INFO: vm.disp5201: Marking preloaded qube
INFO: vm.disp5201: Creating directory: /var/lib/qubes/appvms/disp5201
INFO: Updating appmenus for 'disp6589' in 'dom0'
INFO: Removing appmenus for 'disp6589' in 'dom0'
INFO: Updating appmenus for 'disp5201' in 'dom0'
INFO: Removing appmenus for 'disp5201' in 'dom0'
INFO: vm.disp6589: Starting qube disp6589
INFO: Created sparse file: '/var/lib/qubes/appvms/disp6589/volatile-dirty.img~lvadsgml'
INFO: Hardlinked file: '/var/lib/qubes/vm-templates/fedora-41-xfce-OLD/root.img' -> '/var/lib/qubes/appvms/disp6589/root.img'
INFO: Hardlinked file: '/var/lib/qubes/appvms/browser-dvm/private.img' -> '/var/lib/qubes/appvms/disp6589/private.img'
INFO: Renamed file: '/var/lib/qubes/appvms/disp6589/volatile-dirty.img~lvadsgml' -> '/var/lib/qubes/appvms/disp6589/volatile-dirty.img'
INFO: Reflinked file: '/var/lib/qubes/appvms/disp6589/private.img' -> '/var/lib/qubes/appvms/disp6589/private-dirty.img~gdlnx_pw'
INFO: Renamed file: '/var/lib/qubes/appvms/disp6589/private-dirty.img~gdlnx_pw' -> '/var/lib/qubes/appvms/disp6589/private-dirty.img'
INFO: vm.disp5201: Starting qube disp5201
INFO: Reflinked file: '/var/lib/qubes/appvms/disp6589/root.img' -> '/var/lib/qubes/appvms/disp6589/root-dirty.img~hkhersk6'
INFO: Renamed file: '/var/lib/qubes/appvms/disp6589/root-dirty.img~hkhersk6' -> '/var/lib/qubes/appvms/disp6589/root-dirty.img'
INFO: vm.disp6589: Setting Qubes DB info for the qube
INFO: vm.disp6589: Starting Qubes DB
INFO: Created sparse file: '/var/lib/qubes/appvms/disp5201/volatile-dirty.img~0ct9lsqf'
INFO: vm.disp6589: Activating qube
INFO: Hardlinked file: '/var/lib/qubes/appvms/browser-dvm/private.img' -> '/var/lib/qubes/appvms/disp5201/private.img'
INFO: Hardlinked file: '/var/lib/qubes/vm-templates/fedora-41-xfce-OLD/root.img' -> '/var/lib/qubes/appvms/disp5201/root.img'
INFO: Reflinked file: '/var/lib/qubes/appvms/disp5201/private.img' -> '/var/lib/qubes/appvms/disp5201/private-dirty.img~7torg_a3'
INFO: Renamed file: '/var/lib/qubes/appvms/disp5201/private-dirty.img~7torg_a3' -> '/var/lib/qubes/appvms/disp5201/private-dirty.img'
INFO: Reflinked file: '/var/lib/qubes/appvms/disp5201/root.img' -> '/var/lib/qubes/appvms/disp5201/root-dirty.img~knkqnpma'
INFO: Renamed file: '/var/lib/qubes/appvms/disp5201/root-dirty.img~knkqnpma' -> '/var/lib/qubes/appvms/disp5201/root-dirty.img'
INFO: Renamed file: '/var/lib/qubes/appvms/disp5201/volatile-dirty.img~0ct9lsqf' -> '/var/lib/qubes/appvms/disp5201/volatile-dirty.img'
INFO: vm.disp5201: Setting Qubes DB info for the qube
INFO: vm.disp5201: Starting Qubes DB
INFO: vm.disp6589: Preload startup waiting 'qubes.WaitForRunningSystem' with '60' seconds timeout
INFO: vm.disp5201: Activating qube
ERROR: vm.disp6589: Start failed: Error on call to '$(PATH="/run/qubes-rpc:/usr/local/etc/qubes-rpc:/etc/qubes-rpc" command -v qubes.WaitForRunningSystem)' during preload startup
INFO: Removed file: '/var/lib/qubes/appvms/disp6589/private-dirty.img'
INFO: Removed file: '/var/lib/qubes/appvms/disp6589/volatile-dirty.img'
INFO: Removed file: '/var/lib/qubes/appvms/disp6589/private.img'
INFO: Removed file: '/var/lib/qubes/appvms/disp6589/root-dirty.img'
INFO: Removed file: '/var/lib/qubes/appvms/disp6589/root.img'
INFO: vm.disp6589: Automatic cleanup removes qube from preload list
INFO: vm.browser-dvm: Removing qube(s) from preloaded list: 'disp6589'
INFO: vm.disp6589: Removing volume root: appvms/disp6589/root
INFO: vm.disp6589: Removing volume private: appvms/disp6589/private
INFO: vm.disp6589: Removing volume volatile: appvms/disp6589/volatile
INFO: vm.disp6589: Removing volume kernel: 6.15.7-1.fc41
INFO: Removed empty directory: '/var/lib/qubes/appvms/disp6589'
INFO: Removed file: '/var/lib/qubes/appvms/disp5201/private-dirty.img'
INFO: Removed file: '/var/lib/qubes/appvms/disp5201/volatile-dirty.img'
INFO: Removed file: '/var/lib/qubes/appvms/disp5201/private.img'
INFO: Removed file: '/var/lib/qubes/appvms/disp5201/root-dirty.img'
INFO: Removed file: '/var/lib/qubes/appvms/disp5201/root.img'
INFO: vm.disp5201: Automatic cleanup removes qube from preload list
INFO: vm.browser-dvm: Removing qube(s) from preloaded list: 'disp5201'
INFO: vm.disp5201: Removing volume root: appvms/disp5201/root
INFO: vm.disp5201: Removing volume private: appvms/disp5201/private
INFO: vm.disp5201: Removing volume volatile: appvms/disp5201/volatile
INFO: vm.disp5201: Removing volume kernel: 6.15.7-1.fc41
INFO: Removed empty directory: '/var/lib/qubes/appvms/disp5201'
ERROR: Task exception was never retrieved
future: <Task finished name='Task-52553' coro=<Emitter.fire_event_async() done, defined at /usr/lib/python3.13/site-packages/qubes/events.py:211> exception=ExceptionGroup('unhandled errors in a TaskGroup', [QubesException('Error on call to \'$(PATH="/run/qubes-rpc:/usr/local/etc/qubes-rpc:/etc/qubes-rpc" command -v qubes.WaitForRunningSystem)\' during preload startup')])>
+ Exception Group Traceback (most recent call last):
| File "/usr/lib/python3.13/site-packages/qubes/events.py", line 243, in fire_event_async
| effect = task.result()
| File "/usr/lib/python3.13/site-packages/qubes/vm/mix/dvmtemplate.py", line 329, in on_domain_preload_dispvm_used
| async with asyncio.TaskGroup() as task_group:
| File "/usr/lib64/python3.13/asyncio/taskgroups.py", line 71, in __aexit__
| return await self._aexit(et, exc)
| File "/usr/lib64/python3.13/asyncio/taskgroups.py", line 173, in _aexit
| raise BaseExceptionGroup(
| ...<2 lines>...
| ) from None
| ExceptionGroup: unhandled errors in a TaskGroup (1 sub-exception)
+-+---------------- 1 ----------------
| File "/usr/lib/python3.13/site-packages/qubes/vm/dispvm.py", line 346, in on_domain_started_dispvm
| await asyncio.wait_for(
| ...<6 lines>...
| File "/usr/lib64/python3.13/asyncio/tasks.py", line 507, in wait_for
| return await fut
| File "/usr/lib/python3.13/site-packages/qubes/vm/qubesvm.py", line 1929, in run_for_stdio
| raise subprocess.CalledProcessError(
| p.returncode, args[0], *stdouterr
| subprocess.CalledProcessError: Command '$(PATH="/run/qubes-rpc:/usr/local/etc/qubes-rpc:/etc/qubes-rpc" command -v qubes.WaitForRunningSystem)' returned non-zero exit status 1.
| During handling of the above exception, another exception occurred:
| File "/usr/lib/python3.13/site-packages/qubes/vm/dispvm.py", line 563, in from_appvm
| await dispvm.start()
| File "/usr/lib/python3.13/site-packages/qubes/vm/dispvm.py", line 642, in start
| await super().start(**kwargs)
| File "/usr/lib/python3.13/site-packages/qubes/vm/qubesvm.py", line 1536, in start
| await self.fire_event_async(
| "domain-start", start_guid=start_guid
| File "/usr/lib/python3.13/site-packages/qubes/vm/dispvm.py", line 360, in on_domain_started_dispvm
| raise qubes.exc.QubesException(
| "Error on call to '%s' during preload startup" % service
| qubes.exc.QubesException: Error on call to '$(PATH="/run/qubes-rpc:/usr/local/etc/qubes-rpc:/etc/qubes-rpc" command -v qubes.WaitForRunningSystem)' during preload startup
Some service is failing to start on browser-dvm or its template:
From dom0:
qvm-shutdown browser-dvm
qvm-run --service browser-dvm qubes.StartApp+qubes-run-terminal
From browser-dvm:
systemctl --wait is-system-running
systemctl --failed
Seems youâve found the cause: `efi.mount` unit fails · Issue #8954 · QubesOS/qubes-issues · GitHub
This is in F42, though again this was a dirty upgrade.
Works fine with freshly-downloaded F42-xfce template.
How exactly does it relate to sys-firewall and sys-net? I do not see any option to set the number of preloaded disposables. However, I noticed that if I tried to shut down those qubes, it would warn me that a couple preloaded disposables are open. But if I restore sys-firewall-renamed and sys-net-renamed from a backup and shut them down, I donât get any warning of preloaded disposables running.
Overall, preloads do speed load times about 30-50% for my setup.
edit: I figured it out. On a clean install I believe some appvms using sys-firewall were setup preloaded. All my appvms use sys-vpn or sys-whonix and were not setup preloaded.
Take a look at this pending pull request to the documentation:
NetVM dependency is being fixed:
Is it possible to install RPC âqubes.WaitForRunningSystemâ on non-standard templates? Is it as simple as adding a script to the template?
Please always share full information. It is not just a non-standard template, it is Alpine. I will respond the other thread.
Iâm also getting a WaitForRunningSystem error after upgrading to 4.3, using the default config. I just disabled preloaded templates entirely (set to 0) in Qubes global settings.
@tetrahedra Can you do as instructed in the desktop notification? Open a non-preloaded disposable and run:
systemctl --user is-system-running
systemctl --user --failed
systemctl is-system-running
systemctl --failed
user@disp5000:~$ systemctl --user is-system-running
systemctl --failed
running
UNIT LOAD ACTIVE SUB DESCRIPTION
0 loaded units listed.
running
Strange. I justed tested on fedora-42-xfce and fedora-43-xfce and it is working. Which template did you use? Can you try updating dom0, updating the template and enabling preload again?
Iâm using fedora-42-xfce. I just updated to r4.3 so all templates and dom0 have been very recently updated, and the system rebooted.
