There are presently no issues listed, and the tracker is showing “100% complete.” I am so excited… I’m ready to hit that sudo qubes-dom0-update -y qubes-dist-upgrade ![]()
I’m on a hype-train of 1 person ![]()
Where my qubeheads @!?
Don’t forget to make backups ![]()
Did you try it? How did it work out?
Qubes 4.2 was tagged for release 3 hours ago:
Announcement post is waiting here too:
Many users are running Qubes 4.2, including myself, and the experience is good.
The new menu system in particular is a lot nicer to navigate.
Yup, been running 4.2 for weeks, no problems here.
Might do a fresh install, just to test the latest installer, but upgrade worked fine too. Running on the latest NovaCustom NV41 laptop (url).
I’m running 4.2 RC5 in an old (7- 8years ) HP-Pav.5, this is my tester.
4.2 is really nice, seems to be faster, and quitter in that old machine 16GB ram.
After the official release I’ll do a clean installation on my work machine.
Great work guys
VM startup is definitely a lot faster on Q4.2 as RAM scrubbing now balloons on demand rather than being completed before boot finishes.
I had a big work project last Friday, so I did not perform the upgrade until today. It went mostly smooth! There was one Standalone Windows VM that I had to exclude from the pre and post boot processes, and then there was a single jammy template from @unman (THANK YOU SO MUCH
) from here: Index of /Templates_4.1, that I didn’t really trust to make the switch, so I Ctrl+c through it’s update/upgrade when it hung too long. The AppVM that it’s based on still works great, and I have several manual menu entries, so those are also working just fine.
Overal 10/10 for the upgrade process ![]()
GREAT JOB QUBES TEAM; thank you for all you do!
Good news …
…but when I do: sudo qubes-dom0-update -y qubes-dist-upgrade
I get: ‘unable to find a match: qubes-dist-upgrade’
I am running rc5 (which is excellent) - is that why I get that message?
If you’re on 4.2rc5 then you simply continue with normal updates as before. The upgrade feature is for those upgrading from 4.1.
Thanks, I wondered about that, but am still a novice with Qubes.
I am running with KDE and am very pleased with both stability and use-ability.
