IOMMU Group - GRUB modifications
https://forum.qubes-os.org/t/create-a-gaming-hvm/19000
states that I need to:
  • Boot a live linux distribution - Fedora on another disk
  • In the grub, enable iommu: Add the parameters iommu=1 iommu_amd=on to the linux commandline
    iommu=1 intel_iommu=on for Intel, but done
  • Once you logged in your live linux distribution, you need to retrieve the folder structure of /sys/kernel/iommu_group.
    I have no iommu_group file or folder. I have an iommu_groups folder, but it’s empty
Please can y’all let me know how to get the IOMMU group of my GPU from here?
Weird… Do you have iommu enabled in BIOS?
Intel Virtualization Tech → [Enabled]
Intel VT-D Tech → [Enabled]
Is there something else? Happy to be corrected!
It looks okay, but who knows with these manufacturers…
Maybe there have been a typo in kernel parameters? You can get them on a running system in /proc/cmdline
Also try to find fedora documentation on the topic. What if they’ve changed something and it is more involved than just two parameters?
Did you also tried the helper script shared here:
https://iommu.info/
(keep in mind that it will immediately upload and contribute the result to the online database)
“You can’t see your IOMMU Group when you are using Xen (the information is hidden from dom0).”
says the guide
However…these look like IOMMU groups? Output from qvm_pci
dom0:00_00.0
dom0:00_01.0
dom0:00_01.1
Am I missing something? :confused:
Nope, these are device ids
For example, here’s an entry from iommu.info: PRIME X570-PRO
If you look closely you can see that device ids don’t correspond to groups at all.
Thank you :slight_smile:
