I use Qube’s OS 4.1.1. I only get a relatively slow connection to the Internet. I should be able to reach at least 100 Mbps. However, I get a maximum of 20 Mbps download via WLAN and a cable connection. There are no problems with the upload. I tested it using various speed tests on the Internet. What could be the problem?
I have the same problem. My upload is advertised by ISP but my download is 3.5 times slower than advertised, even significantly slower than upload.
On my phone and other Windows laptop, no such issues, so it looks like Qubes specific.
I have even tried dispVM Firefox connected directly to sys-net, and tested it on speedtest. Same as above.
In sys-net it is as declared, almost (but it counts as “up to…”)
Out of sys-net experimented with various RAM amount in various qubes, including sys-xxx’s, but it looks it doesn’t matter. The best I achieved was DL=nominal UL
I have changed the topic subject to better reflect the issue.
(Tried in terminal with curl -s https://raw.githubusercontent.com/sivel/speedtest-cli/master/speedtest.py | python -, it’s OK, and with bittorrent - same issue).
Firefox used with only HTTPS Everywhere. CPU related?
Bit of a necro thread but I have an NBN 100/40 (Australian Broadband Plan) and I typically get around 90+/~34 but on my Windows 11 Pro Standalone Qube with the as installed Realtek RTL8139C+ Fast Ethernet NIC I see about 30 Mbps or less download and the full 30+ Mbps upload speed.
The net VM is sys-firewall (the default)
I am getting full performance from Fedora 40/41 cubes using sys-firewall.
I haven’t installed the Qube Windows Tools in the Windows 11 Qube
Has anyone found a way to get better Download performance from a Windows Qube?
